Question about Compaq Presario 700 470024-192 Notebook
PRESARIO 700 ERROR ON BOOT Hello! Every time when I switch on my presario 700, on the screen show: ERROR PCI on motherboard, device 09, F1(boot) and F10 (setup). OS is XP pro. What is wrong?
  • 679 Answers
If you know how to set up the bios hit f1, if not hit f10, it will boot up and you will need to reset the time and date as they will be wrong. The PCI error refers to a PCI slot, which for some reason isn't functioning properlly. If you run the disk with your motherboard settings that may have come with your motherboard it may just be a driver. If you hit f1 then you will be in the Bios screen. There the keyboard is used to navigate. The mouse won't work, Arrow keys for up down and side to side, and the escape key to get out of a menu or menu item, and enter to select an item. So on the first screen, you will need to adjust the date, time, and year. each time you do this you must hit enter to proceed to the next item. once you get all of the settings right hit f 10, and enter to reboot. So I gave you both ways. If you still have the problem, check the cards that are in your motherboard, there may be a loose one, also try to pop out the battery inside the case, not the laptop battery, if it continues to happen, you may have to pop that little battery that controls the settings for startup, it will reset your saved motherboard startup settings, and once in a while the battery may be bad, which can also cause the kind of problem you describe.
Posted on Apr 20, 2009
Testimonial: "Thank you very much dear Bill"
Resource conflict error
I would run chkdsk/f on your hdd as errors like this can be caused by system file issues. Go to my computer, right click on drive C and choose properties than tools and then click Check Now. After that run ASC from iobit, a free registry cleaner that actually works!
Mar 23, 2014 | Computers & Internet
Resource Conflict - PCI on Motherboard. Bus:08, Device:09, Funtion:00 / 01 / 02 / 03 / 04
well basically there is something wrong with the system a bus on the mother board is malfunctioning ,well try reinstalling the windows that would usually start the system completely over
Jul 02, 2013 | HP Computers & Internet
Hello. I got given a compaq presario 700
motherboard is not alright. there are failing compaonents on the motherboard( capacitors, resistors e.tc). however, try to go to bios and stay there for some time and see if the same will happen.
Regards
Feb 11, 2010 | Compaq Computers & Internet
ATI 700 pro cannot be shut down not start.
IF YOU ARE SHARING THIS DEVICE WITH ANY OTHER DEVICE YOU WILL CONTINUE HAVE THESE PROBLEMS OR BURNING THAT DEVICE CONTROL ON THE MOTHER BOARD. YOU MAY HAVE TO DISABLE IT I DEVICE MANAGER OR UNINSTALL IT.
YOOU MITE EVEN CORRUPTED THE BOOT SECTOR ON THE DRIVE AND LOOSE EVERYTHING ON THE DRIVE
ROD
Mar 01, 2009 | ATI RADEON X700 PRO, (256 MB) PCI Express...
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Jul 19, 2008 | Toshiba Satellite A105 Notebook
Compaq presario 700 problem in booting
when starting press f1 or del it will enter into the bios there kept bios default settings and exit the bios and then see the system , till the same problem try to clear cmos
Mar 27, 2008 | Compaq Presario 700 470024-192 Notebook
945GZT M V1.0
David i take it you mean you played with the bios screen ?
if so you can remove the power cord then open the side of the computer and remove the bios battery (big silver watch type battery on the mother board) leave it for around 15 mins replace the battery then the power cord you will find an error screen when you switch on.
its normally f1 to load default settings and continue the boot
that should solve it
Mar 22, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Error message, need help
1. Turn off laptop, unplug all devices and cables.
2. Flip laptop upside down on towel (avoids scratches)
3. Open the PCI panel (you need screwdriver to fit screws)
4. remove the PCI card inside (probably 3rd party WIFI card)
5. reattach AC/PSU cable and start laptop
6 If it starts properly now, you either had a bad PCI card, or it was improperly installed. You can try installing it again (turn everything off first). Sometimes this error is just from the card getting loose, or oxidation on contacts. Insert and remove it 2-3 times to see if it works then. Let me know.
Feb 12, 2008 | Acer Aspire 5100-5022 Notebook
Compaq Presario 700 470024-192 Notebook Logo
134 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
