Question about Samsung SGH-D900 Cellular Phone
D900 won't turn on , But battery is ok
I have a samsung D900 ultra edition . It will not turn on or show the charging screen . The battery is ok as i checked it with a Voltmeter
    President:
  • 625 Answers
Your charging port may have broken. I am seeing more and more of this type of problem. Did you try a different charger? If it is the charge port, You have 3 options when the charge port breaks.
1. Get it repaired, under Warranty if possible. About 60 dollars
2. Get a new one, runs sbout 75 dollars
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebayD900 won't turn on , But battery is ok - 2.gif.
For more information and links to the parts check the following link below.
Samsung SGH-D900 not charging problem repairs
Posted on Aug 18, 2009
Samsung transform ultra "charging" while not on charger
I had the same problem and eventually my phone just wouldn't charge at all. I took an old tooth brush n was cleanin the charging port with it then id blow it out n repeat and honestly after bout a half hour of doing this it is now finally charging.
Apr 16, 2012 | Samsung Transform Ultra
No display, but i am able to receive incoming calls. Can I get a spare display unit?... Thanks in advance. My model no. is SGH-D900
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Aug 10, 2010 | Samsung SGH-D900 Cellular Phone
What is the security code for samsung SGH-D900
hi try these codes
*#06# Show IMEI *#9999# Show mobile Software Version *#0837# Show mobile Software Version (instructions) *#0001# Show Serial Parameters *#9125# Activates the smiley when charging *#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature) *#9998*246# Program status *#9998*289# Change Alarm Buzzer Frequency *#9998*324# Debug Screens *#9998*364# Watchdog *#9998*377# EEPROM Error Stack - Use side keys to select values *#9998*427# Trace Watchdog *#9998*523# Change LCD contrast *#9998*544# Jig detect *#9998*636# Memory status *#9998*746# SIM File Size *#9998*778# SIM Service Table *#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error *#9998*786# Run, Last UP, Last DOWN *#9998*837# Mobile Software Version *#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated *#9998*862# Vocoder Reg - Normal, Earphone or Carkit *#9998*872# Diag *#9998*947# Reset On Fatal Error *#9998*999# Last/Chk *#9998*9266# Yann debug screen (Debug Screens?) *#9998*9999# Software version *0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1) *0002*?# unknown Samsung's comand *0003*?# unknown Samsung's comand For Mobile phones SGH (R210, T100, A300...) if Samsung code is in format *#9998*xxx# try write in this *#0xxx# SGH-600 SGH-2100 *2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0 *2767*2878# Custom EEPROM Reset Samsung mobile phone codes: Samsung E700 *2767*688# remove USER CODE and SIMLOCK Samsung mobile phone codes: Samsung V200 Unlocking: Power on the mobile phone without SIM card and type these codes: *2767*63342# and press green button *2767*3855# and press green button *2767*2878# and press green button *2767*927# and press green button *2767*7822573738# press button Phone will be unlocked, but all trims are reseted !!! Mobile phone must be fully charged Samsung mobile phone codes: Samsung S500 Unlocking *2767*MVT# (*2767*688#) E2P MVT Reset *#SIMLOCK# (*#7465625#)
May 15, 2010 | Samsung SGH-D900 Cellular Phone
Can't turn on my d900 with cable plugged in...
It is probably is the charging port. Have you tried a different charger?
If it is the charger port on you SGH-D900, You have 3 options.
1. get it repaired, under warranty if possible.
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay.
Samsung SGH-D900 will not charge
Jul 11, 2009 | Samsung SGH-D900 Cellular Phone
My phone samsung d900 is charging up witout charger installed
The charging port on your D900 may be broken. Have you tried a different charger first?
2. Get a new D900
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on Ebay.
Fix for Broken Charge port on Samsung SGH-D900
Jun 03, 2009 | Samsung SGH-D900 Cellular Phone
Issues starting it up.
try to get a new battery or get a new phone
Mar 31, 2008 | Samsung SGH-D900 Cellular Phone
BLUE TOOTH CONECTION PROBLEMS
take it to the store where you bought it from and ahve them assist you with it.
Mar 03, 2008 | Samsung SGH-D900 Cellular Phone
Sansung d900 wont work
Take The Battery Out,Give It A Wipe Inside,Take The SIM Out And The Put It All In A Again And See If It Works.
Otherwise See If It Can Be Repaired By Warrenty?
Good Luck :)
Regards,
Sophiee.
Mar 02, 2008 | Samsung SGH-D900 Cellular Phone
Wont open
try to replace your batter.
Feb 04, 2008 | Samsung SGH-D900 Cellular Phone
Samsung D900 wont charge or switch on..
your phone hardware might be dead , there is no way u can start it , u need to go for a service of your phone and they will flash the entire hardware and reinstall the software
Dec 28, 2007 | Samsung SGH-D900 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
379 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
