Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Canon Imageclass MF4370dn constant paper jam errors
A brand new printer out of the box but every time I print a single page, it gives me a paper jam message and stops printing. There is no paper jam. I open the cover as it suggests, open the back, open the front take out the toner, etc. It finally clears and when I print another page, I get the same error message.
  • candjservice Apr 04, 2014
    Check your papaer size setting
    Master:
  • Canon Master
  • 551 Answers
Dear
Inside the back panel there are paper sensors attached to lever, a small spring connected to lever to keep its home position, the spring may dislocated from its position or the lever sticked to the base. some times a small piece of paper sticked at this may cause the problem.
Thanks.
Posted on Mar 08, 2015
SOURCE: Canon ImageClass MF 6550 Error Toner Low- Prepare New Toner
There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
Posted on Apr 26, 2011
PA8558
  • 28 Answers
SOURCE: Paper jam message
Check to see if you have a door in the back of the printer. Your jam could be there.
If this helps you, please rate me. Thanks, Patty
Posted on Dec 30, 2007
  • 59 Answers
SOURCE: PAPER JAMS CONSTANTLY
Well, it might be theres something stuck in there. Pick it up and give it a few shakes. I work on printers, and not too long ago I found a wedding ring, paperclip, banana sticker and other things in printers. If that doesn't work, try going to staples and getting a laser cleaner kit. They're basically sheets coated to pick up any paper dust, or bits of paper that might be clogging the path
Posted on Mar 11, 2008
  • 99 Answers
SOURCE: My canon mf3240 printer jamed, then a b5 paper size error message
You must be set you machine from program key
1> press menu>paper size>A4/Letter/set OK
after print or copy your requirement size.
Posted on Dec 12, 2009
AndreaBl
  • 218 Answers
SOURCE: i want a driver canon imageCLASS MF4380dn/MF4370dn
hi there,
go right here or here.
Posted on Jun 15, 2010
Pick up roller rotates twice even if when gives single page print command and creates paper jam.
I do not know for sure on the Samsung but on HP's this problem is often caused by the pickup solenoid sticking. There is usually a foam bumper on the pickup solenoid which breaks down over time and then the adhesive stops the solenoid from releasing properly. You can clean it off all the old foam and adhesive and run without it, just make printer a little noisier. The solenoid will usually be on the right side.
Aug 30, 2016 | Samsung Ml-1675 Laser Printer 17ppm...
Canon MF4370dn says "set paper
I can find no reference to this error but presume your paper is being drawn in then stops so you have to remove the toner to get the paper out.
What can happen on this model is the black plastic clip for the output tray falls off onto the paper and gets drawn into the paper feed area of the machine. it then jams the lifter and consequently stops the paper. Take out the toner and have a good look in the paper feed roller area to see if there is something stopping it.
repost if you still have the problem.
Jul 15, 2011 | Canon ImageCLASS MF4370dn Laser All-in-One...
I have a mf4370dn all-in-one printer keep getting error code 6a00 thank
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 17, 2010 | Canon ImageCLASS MF4370dn Laser All-in-One...
ImageCLASS 2300 not printing, check printer cover message
Had the same problem spent 2 hours opening and closing everything trying to reset turn off and on etc. Here is how I fixed it, slammed all the doors on left side starting with above cartridge to cartridge door and 2 little doors by paper hard - and I mean hard - and whammo error cleared immediately. Sensors that check for open door obviously stick and report they are open when they are really closed. I am sure this saved me an expensive service call.
Apr 05, 2010 | Canon imageCLASS 2300 All-In-One Laser...
In Win Vista my new Canon mf4370dn is being reported as offline.
Go to this canon site and install the firmware update. This was happening to me all the time until I installed this firmware update and now I can print to it all the time. I used to have to turn the printer off and back on just to get the printer to wake up.
http://canoncanada.custhelp.com/app/answers/detail/a_id/20228/~/imageclass-mf4370dn-firmware-update
Jan 13, 2010 | Canon ImageCLASS MF4370dn Laser All-in-One...
Scanning Multiple pages into one pdf
Scanning a multi-page document as a .pdf file reverts the settings for rotation, selected area, etc. to default for any pages after the first page. This applies to Mac OSX 10.3, 10.4, & 10.5. A simple, but tedious work-around is to scan each page as a separate file and easily recombine them using OSX Preview. Just open the first page, view the Sidebar, and drag-drop the additional page files into the sidebar. Save and it's all one multi-page .pdf.
Jun 26, 2009 | HP Photosmart C5280 Printer
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
1,184 people viewed this question
old marine
old marine
