Help!! olympia cm 1736 register displays log ----?? cant clear back to normal display please help
    Problem Solver:
  • 28 Answers
There might be a reset or clear button, not sure though
Posted on Aug 07, 2009
I have a Royal 9155SC register. The display shows 0.00 and no key is working with continuous beeping. Please help.
Half Sysem Clear
a. Turn the key to the "PRG" position.
b. Unplug the cash register from the power source (pause
for 10 seconds) and replug the cash register.
c. Continue with normal operations.
Full System Clear
!!! THIS WILL ERASE ALL PROGRAMMING AND DATA!!!
a. Turn the key to the "PRG" Position.
b. Unplug the cash register from the power source and wait
at least 15 seconds.
c. While holding down the [CLEAR] key, replug the cash
register.
d. Re-program the cash register.
e. Continue with normal operations.
Oct 28, 2014 | Royal Office Equipment & Supplies
New g.e. Dryer displays a fault code e61 on screen and will not power on or clear...this dryer is brand new...straight out of box with this fault code...
Sorry to read about your problem, I hope this helps you out.
you should have a electrician work on your wiring, with luck no further damage has happened, E61 means you have the neutral and the L2 wire either reversed or in the wrong position.
ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect the power for 30 seconds.
2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.
3.Press the "SIGNAL"button.
4.Press the "DELAY START"button.
5.Press the "SIGNAL"button.
6.Press the "DELAY START"button.
Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE DBVH512EFWW Dryer
TEC MA-1650 Cash Register It appears the register has been put into a sub programming mode somehow and we are unable to get register functional again. When Register is switched to Set there is a P...
Perform a status clear.
turn key to blind(must be S key not mgr key) while holding zero key down turn reg on with power switch on right side.
reg will beep once & print reciept saying status clear.
this wil not clear programs or totals.
Dec 12, 2010 | Office Equipment & Supplies
I have olympia cash register cm812 it says :paper: on screen nothing else works please help
Make sure paper is loaded in printer, press the clear button.
If still problem try reset.
Key to PGM mode, disconnect power, hold CLEAR & 7, connect power. Should be ok.
Dec 02, 2010 | Computers & Internet
Instruction manual for olympia cash register cm 726 plus
you can get the manual from the below link:
pls rate me. thanks
http://www.tillservices.co.uk/acatalog/Olympia_cm_726_plus_Instruction_Manual.html
Oct 30, 2009 | Casio Parts Cash Register PC Desktop
TE-2400 error E004
Hi.
This is very serious. It means the register is about to completely clear everything (or may have done so already). If it has been sitting for a long time without power, or new out of the box, then this is normal. We can try to jump it back out of the init mode.
Follow these steps very carefully:
Turn the power off at the wall.
Turn the key to PROGRAM mode.
Hold RECEIPT FEED button down.
Turn power on at wall.
When you see the display change to 'FFFFFFFFFF' let go of RECEIPT FEED.
Press SUBTOTAL
Turn the key back to REG mode and try it. If you get error 8, then you may need to log a clerk back on.
Let me know if you have problems.
Mark
Oct 02, 2008 | Casio Parts Cash Register PC Desktop
Casio CE 2350
Hi.
It depends what is causing the lockup.
If you don't have anything on the display, then it is probably a printer jam. If you have anything at all on the display, then you can try a flag clear:
Turn the key to Program mode.
Hold down RECEIPT FEED button while turning on at the wall.
Wait 5 seconds
Let go of RECEIPT FEED
You should see 'FFFFFFFFF' on the display.
Press SUBTOTAL
Turn the key back to Reg mode, and try it. You might have to log on to the machine if you normally use logon codes.
Mark
Jul 10, 2008 | Casio Parts Cash Register PC Desktop
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
