Question about Epson TM 300PA Matrix Label Printer
From where i can found the driver of TM-300PA Printer
Hi every body hopefully u all will be fine, my problem is i have purchased used Epson TM-300PA printer and looking for its driver for windows 2000 it is very urgent. please tell me from where and how i can get the driver of this device. thank you
  • Anonymous Dec 03, 2007
    Please, share the driver with me (if you found) ASAP!!!
    Novelist:
    Champion:
  • 254 Answers
Look here: https://www.epsonexpert.com/login.htm You must register first. I didn't see your exact model. They do list a couple of TM-U300 models, but didn't see drivers, just documentation, and a utility. Are you attempting to use this on a standard desktop/laptop PC or a POS terminal? Perhaps these printers are specifically intended for the POS machines? check through the listing at epsonexpert, see if any of the others have drivers. Maybe they would work for yours.
Posted on Sep 21, 2007
  • Anonymous Sep 21, 2007
    Also check their Technical FAQ TM section. It says here that windows has the drivers built in.
SOURCE:
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
Tm u220pd detected tm-p2.01 how to be default
Hi!
You can set the TM-U220 as your default printer by following the steps below:
For XP OS
-Go to Control Panel and click on Printers and Faxes -Right click on TM-U220 printer driver icon and on drop-down select Use as Default.
Hope this helps. Cheers!
Jan 05, 2011 | Epson TM U200PD Matrix Printer
Need drivers for epson tm-t88111 printer
Epson TM-T88iii Receipt Printer - This product has been discontinued. It is replaced by the Epson TM-T88iv.
Epson TM-T88iii Printer -> Drivers download
Hope it helps.
Nov 09, 2010 | Computers & Internet
Printer prints garbage...
Hi
make sure it is configured to the right port and using the epson driver. go to printer and faxes and properties then ports. check of the correct printer driver is check. what type of cable are you using anyways? com for serial, LPT for parallel.
Hope this help
Jan 02, 2009 | Epson TM-U220 Matrix Printer
TM-U220PD oN WINDOWS VISTA STARTER
Hi, you should try these drivers for Vista...has a preety nice install wizard (works on vista for me).
http://rapidshare.com/files/167170222/TM-http://rapidshare.com/files/167170222/TM-U220.zip.htmlU220.zip.html
good luck
Nov 17, 2008 | Epson TM-U220 Matrix Printer
Driver TM-L90
Hi...here is the European download page for this model, ...hope it helps!
http://content.epson.de/en/rsd/service/index.1022.htm
Jun 03, 2008 | Epson TM-L90
Epson TM-T88#P thermal printer driver for windoze vista
You can use windows 2000 drivers on Vista for this printer, according to this article:
http://www.prophetline.com/node/141
Jan 14, 2008 | Epson TM-T88III Thermal Printer
Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Nov 27, 2007 | Epson TM-U220 Matrix Printer
Epson TM 300PA Matrix Label Printer Logo
981 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
