Question about Kenmore Elite 45986 Front Load Washer
Didn't start washer, but there is water in the tub!!
I just loaded clothes into my Kenmore Elite front loader only to find several inches of water already in there!
The last load emptied completely, and the washer has not been run since then.
Does anyone have a suggestion as to my problem?  I'm a little wary to attempt to run the drain cycle for fear of overflowing.
Thanks!
  • jrowlo Apr 22, 2009
    Same problem. If washer is not used for a couple of days, there will be water in the drum which must be drained out. Started about a month ago when putting cloths from washer to dryer only to find about 2" of water still in machine. Washer is about 5 years old
  • sharbum1 Apr 23, 2009
    I have had several instances where water started filling my washer and spilled out onto the floor. This was after I ran a load.
    It doesn't happen all the time but enough to be a problem.
    Any suggestions? Do I need to replace the drum?
    We've had ours for about 6 years now.
I had similar problems. If there is no power, first try to unplug the washer for five minutes and then plug it back in. If there is still no power, unplug the washer, unscrew the back panel and make sure the white and black wires, coming from the power cord, did not come loose or are disconnected. If the door is locked shut, open the bottom panel. If you reach way up by where the door latches, there is a little tab you can pull down to open it. Also, you may want to check the filter. There is a big round cap, where the tub drains into before it reaches the pump. Unscrew it, but have a wet/dry vac ready to **** up any water remaining while you open it. Clean the filter and then screw it back in.
Posted on Apr 22, 2009
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite QuietPAK2 HE3 noise problem and rubber seal issue
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For the shaky washer:
Adjust your washer's front legs and lock the nut, it has another nut to do this. After you hav locked the legs, try to rock the washer with your hands, it should not rock. Another thing to check will be inside your washer, after taking the power off the wall socket. Check to see if some springs or the shocks (dampers) have come loose. This normally happens when the load is not even, that is when you hav a big sheet in one part of the washer tub. Spread out the clothes evenly before you commence the wash. To see if washer is firm: hold the front portion of the washer, the 2 corners and try to shake it, if it does not move, it is fine.
Pump: If you are handy at all this is simplicity itself. Check the pump - slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. (make note where wires go) Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble.
Washing a full load is better than 2 or 3 small loads, saves electricity, etc. But if there is a loud spin noise, means that your bearings are wearing out. Is your belt too tight?
For the smelly washer:
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
http://ezinearticles.com/?Cleaning-Your-Washing-Machine&id=109993
For most front-loaders: rubber boot, seal
Remove the top, screws behind the top lid. Slide an inch away from you & lift up. Remove old seal. Lubricate the slot which fits over the tub with washing-up fluid, if you find resistance. Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange. When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. This is quite difficult and you may need another pair of hands. Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps)
Try these sites for spares
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl rate me ‘very helpful’ for the free help. Thnks!
May 06, 2010 | Samsung WF328AA Front Load Washer
Kenmore front loader tub fills with water when not in use
your water fill valves are leaking severely,you should see water dripping in there all the time if its this bad and your clothes should still be wet,not damp even after a good spin after the final spin
Mar 23, 2010 | Kenmore 43142 Front Load Washer
Water in tub
More than likely your water inlet valves aren't closing shut. I would check that first
Sep 08, 2009 | Kenmore Elite 45986 Front Load Washer
Not getting clothes clean
Check your drain hose for siphoning. this is a common problem, make sure only about 8 inches is sticking into the drain, and the drain line is higher then the mid point of the washer, ex: drain hose must not leave the washer and head directly to the floor, must make a loop upwards, then enter a drain appx. 3+ft high. Drain hose from washer not to enter drain plumbing more then 8".
Jun 25, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Front loader washer doesn't spin clothes as dry as before
The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Door won't open
disconnect power , remove bottom panel, reach up inside where latch asm is and you can feel tab on bottom of door latch pull down and door will open drain water out of tub and check your drain pump for obstructions. be careful of water left in pump have some towels ready
Dec 12, 2008 | Kenmore Elite 45986 Front Load Washer
Font loader washer water does'nt shut off
remove top replace fill valve left rear be sure not to remove the screens inside valve except to clean but be sure to reinstall or trash may get into valve and not allow proper shutoff
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
the drain pump on this unit has a clean out. There is probably debris in the pump. remove the lower front cabinets. There are three screws almost at floor level that hold it in place and open the drain pump it has a handle on the drain pump that you can twist to remove.
Nov 04, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
101 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
