Question about Brother IntelliFAX 2800 Laser Fax
Stuck in print mode.
My machine accepted a fax transmission but is stuck in print mode. It starts to print but then stops and starts over again. None of the key pad keys work during this process. I had to unplug the machine.
  • 163 Answers
Please check the telephone line may be not giving complete tone if telephone line is OK then there is the fault in the electronic board
Posted on Sep 21, 2007
SOURCE:
I think my printer is stuck in fax mode how to i start printing again
Leave it unplugged for a night and replug the maching. Go through the setup menu again and just try copying something. This should clear the fax buffer. Then retry the fax.
Oct 07, 2014 | Brother Lc1240 / Lc1220 Set Of 4 Compat...
Hi, My SF 360 keeps flashing up " clear cartridge channel/paper jam and press start. Every time this is done/sorted, the cartridge goes onto "printing" then stops in the middle of the carriage - the the...
In your fax machine is a thin shaft. Clean it with a dry cloth to take away the dirt to prevent from getting stuck or if that does not work,try another cartrige. If that also not work,then there is somthing wrong with the print head.
Aug 25, 2009 | Samsung Office Equipment & Supplies
My brother fax-510 is stuck on stop do not know
pretty sure its fixed
just pulled out all the plugs turned it off and left it for a day then started it up again all seems well so far.
Feb 28, 2009 | Brother Office Equipment & Supplies
Says Printing & Online Stuck
when this happens, unplug machine, hold down the "stop/exit" key while plugging machine in. continue holding the stop/exit key for 5 seconds. display should return to the regular date and time screen. if it doesn't, contact brother customer support. this problem is caused by a fax stuck in memory.
hth,
razors
May 13, 2008 | Brother IntelliFAX 4100 Laser Fax
Will not stop faxing the same document
There should be a memory clear procedure in the menu to stop that.
You will have to reenter the time date, your phone and business name once you clear the memory.
I dont have a book for that particular machine, but faxs do have a memory clear feature for lock ups like that.
Mar 05, 2008 | Panasonic PANAFAX UF-6000 Fax
Imagistics 2500 fax stuck in the "printing" mode. Need to reset.
Yes that worked!! I unplugged it, and kept the red stop button push in while plugging back in and it cleared it out! THANK YOU!
Jan 28, 2008 | Brother MFC-8220 Fax
Beeping
Button stuck or not in fax mode, check mode and press all buttons
menu * 2 8 6 4 then 99 is a rest code must be done very fast
Nov 30, 2007 | Brother IntelliFax-2820 Laser Fax
Brother Fax 8360p Stuck in Printing
TURN MACHINE OFF HOLD DOWN STOP KEY AND THEN TURN ON OR PLUG IN ...worked for me
Nov 28, 2007 | Brother Office Equipment & Supplies
Brother IntelliFAX 2800 Laser Fax Logo
66 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
