Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Garage door opens by itself
I have come home now a couple of times to find my garage door opened by itself. It was closed when I left the house. Am I on a similar frequency to my neighbors? or is something shorting? We can come home and find the garage door all the way open or open just 6" or so. Hitting the wall switch closes the door. This occurs intermittently.
  • 10,515 Answers
Hi Ssts,
This has been discussed many times :).
Let's check the solution offered by one of the experts and best till now.
http://www.fixya.com/support/t212598-garage_door_opens_itself
I found the below mention link on outer world ( Internet ), very useful one.
http://www.geniedoor.com/content/troubleshooting-guides.htm
I hope you would be able to fix this once you go though all the links.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Posted on Apr 20, 2009
Liftmaster 3265M Garage Door Opener opens on its own
Sounds like one of your neighbors may have recently replaced their own garage door opener and it coincidentally operates in the same frequency band as yours. One of them may also have purchased a new car and recently programmed it to open their door, but it inadvertantly interferes with yours. Depending on the quality of your door opener's receiver and how old it is, some receivers are not as good as others in their ability to discriminate against similar transmitted codes in the same frequency band. When the door opens by itself immediately go outside and see if a neighbor's door has just been opened (or closed) at the same time. Does your door open by itself at similar times during day? Like when a neighbor might be leaving or returning home from work? When someone uses a remote to close their garage door when leaving home, they (and the remote) are usually located in their driveway, but when they use it to open the door upon arriving home, they might be located right in front of your house.
Nov 25, 2012 | Home Security
How do i program my garage door to open with my car garage opener button
Push and hold the two outer buttons until the LED flashes fast Approx (15 seconds) then hold your garage opener up to the mirror or visor and push and hold any button 3 or 4 seconds on the opener Now the Home Link is programed. With the car safely away from the closing garage door find and push the garage openers red programming button (on the motor assembly somewhere that gives you about 30 seconds to push your cars home link button so the garage opener learns the button you want to use for that door the other two buttons can be programed for other doors or house light controler gate opener in the same manner
Jan 03, 2012 | 2004 Nissan Maxima
I closed my garage door but when i came back home it was open. i just noticed it again after i left that the door opened by itself after i had closed it? The wall unit is Wayne Dalton model number...
Watch the door when it closes. If it is traveling too far and hits the floor the safety will cause it to reverse to the open position. This is a common cause. Also your door sensors may need adjusting. Make sure they are pointed at one another and the small light on each one is lit and not flickering.
Dec 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
My mom & I each have a Craftsman garage door opener at our respective homes & live @ 15 minutes apart. Our openers are about 13 to 14 yrs old. The past two yrs. we've both had the same problem. ...
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure both lights on the sensors stay on and don't flicker while the door is moving and the sensors are firmly attached so they don't move. Tweak them just a bit.
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Trying to clear the codes from my Garage Door opener. 41A3615, 139.53615SR, Grey Learn Button, '92 mfg date. I added a Klick universal wireless wall pad and a Klick universal remote and now my neighbor's...
In most cases, when a garage door opens or closes by itself, or when you find your door open, upon returning home, the problem is due to a short somewhere. This short is most likely to be in one of two places: either in one of your transmitters or in the wall button or its wiring.
When there is a short in your garage door transmitter, you will often find the garage door is up upon returning home, even though you know you closed the door when you left the house. A short in your transmitter causes a continues signal to be sent. As you are pulling out of the driveway the garage door closes fully and appears to stop, but as the carriage and arm run past the down limit and hits the header bracket it reverses, and the door begins to open, just as you start driving off down the road. You come home to find the garage door is up, as if someone else had opened your door. The best thing to do to troubleshoot the garage door problem is remove the batteries from your transmitters and try operating the door from the wall button. If the problem is intermittent, you may want to do this for a day or two to eliminate the transmitters as the culprit.
If the problem persists, try removing the wall button wire at the motor head to ensure it is not a short in the wire to the button, then try operating the garage door with the transmitters only. If it stops the problem, replace the wires and test the wall button. It is a process of elimination.
Mar 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens whenever it wants to
In most cases, when a garage door opens or closes by itself, or when you find your door open, up returning home, the problem is due to a short somewhere. This short is most likely to be in one of two places: either in one of your transmitters or in the wall button or its wiring.
When there is a short in your garage door transmitter, you will often find the garage door is up upon returning home, even though you know you closed the door when you left the house. A short in your transmitter causes ta continuous signal to be sent. As you are pulling out of the driveway the garage door closes fully and appears to stop, but as the carriage and arm run past the down limit and hits the header bracket it reverses and the door begins to open, just as you start driving off down the road. You come home to find the garage door is up, as if someone else had opened your door. The best thing to do to troubleshoot the garage door problem is remove the batteries from your transmitters and try operating the door from the wall button. If the problem is intermittent, you may want to do this for a day or two to eliminate the transmitters as the culprit.
If the problem persists, try removing the wall button wire at the motor head to ensure it is not a short in the wire to the button, then try operating the garage door with the transmitters only. If it stops the problem, replace the wires and test the wall button which can also go bad. It is a process of elimination.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Close garage when leaving house but come home and the garage door is up
if you or your neighbors have a cable booster this is a garage door openers worst enemy try to reprogram remotes or change dip switchs if this is an old operator. make sure you watch door close all the way before you leave and it is not getting hung and coming up add a little pressure if thats all it is...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sounds like the Logig board is going bad in your unit.
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Opens when we're not at home
Here is the manual, so you can change your code. This should FixYa:) Let me know if you need more help!
http://lib.store.yahoo.net/lib/aaaremotes/976LM-manual.pdf
Thanks!
Nov 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
252 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
