Question about Tally T2250 Matrix Printer
Sub : TALLY 7.2 error
I have a problem in Tally 7.2 version. When I select a particular company and try to insert a voucher or try to modify a voucher an error message appears "Error! Exiting Tally! File Name C:\tall\data\003\Tr01310.500 Size 65024 Position 65024 Chars 128 (Done 0). Please help me solve this problem.
Avijit Chowdhury, Siliguri
  • 1 more comment
  • Anonymous Mar 18, 2014
    not able to restore tally back up in tally 9
  • Anonymous Mar 27, 2014
    While creating new voucher I want size of the name of voucher Font small in size what should i do?
  • Anonymous Mar 30, 2014
    voucher date change solution in tally erp 9 3.6 version
Exiting tally! \r\ninternal error
software exception c0000005
(memory access violation)
Posted on Jul 17, 2009
How restore the backup data in selected company
Posted on May 28, 2010
How i change change voucher date in 7.2 tally
when i trying to enter date active only 1 & 2 day i just try to enter eg 3.4.2009 or 53.5.9, 3.6.9 not entering what i do. pls solve the problem.
Jul 17, 2009 | Tally T2250 Matrix Printer
Tally Data Problem
EXITING TALLY!!
INCORRECT VERSION.
DATA OF INCORRECT VER.(10)
CAN ONLY RUN VERSION 9!
Jun 27, 2009 | Tally T2245 Matrix Printer
How to find tally 9 short-cut keys
Tally 9 short-cut keys appear on the right-side of the tally screen. see the button names in the button bar.
few short-cuts:
Keys
Functions
Alt + 2
To Duplicate a voucher
Alt + A
To Add a voucher
To Alter the column in columnar report
Alt + C
To create a master at a voucher screen (if it has not been already assigned a different function, as in reports like Balance Sheet, where it adds a new column to the report)
To access Auto Value Calculator in the amount field during voucher entry
Alt + D
To delete a voucher
To delete a master
To delete a column in any columnar report
Alt + E
To export the report in ASCII, HTML OR XML format
Alt + I
To insert a voucher
To toggle between Item and Accounting invoice
Alt + N
To view the report in automatic columns
Alt + P
To print the report
Alt + R
To remove a line in a report
Alt + S
To bring back a line you removed using ALT + R
Alt + U
To retrieve the last line which is deleted using Alt + R
Alt + W
To view the Tally Web browser.
Alt + X
To cancel a voucher in Day Book/List of Vouchers
Alt + Y
To Register Tally
Ctrl + A
To accept a form – wherever you use this key combination, that screen or report gets accepted as it is.
Ctrl + Alt + B
To check the Company Statutory details
Ctrl + G
To select the Group
Ctrl + Alt + I
To import statutory masters
Ctrl + Q
To abandon a form – wherever you use this key combination, it quits that screen without making any changes to it.
Ctrl + R
To repeat narration in the same voucher type
Ctrl + Alt + R
Rewrite data for a Company
May 30, 2009 | Computers & Internet
Problem in tally 7.2 version
you need to rewrite the data please shut the company first and then press ctrl+alt+r and then select the company to rewrite data might lost not complete but few so please take the back up of the company first before doing it. The other thing you can try is to delete the tsm files from the data folder by providing in the search box *.tsm these are the temp files of tally
Apr 22, 2009 | Computers & Internet
ERROR ! EXITING TALLY!
Error! Exiting Tally! File Name C:\tally\data\004\Tr01320.500 Size 196608 Position 196608 Chars 128 (Done 0).
Apr 21, 2009 | Computers & Internet
Tally 7.2 Data Corrupt
1)Start Tally and at Company Info Screen press Ctrl + Alt + R then select the corrupt company and press enter to start rewrite process.
2)If it does not worked then there is another method for rewrite:-
Click Start > Run > Type ’C:\(Tally 7.2 directory name)\Tally72.EXE C:\(Tally Data path)[space]/
then press enter
for Eg: c:\tally7.2\tally72.exe c:\tally7.2\data /
after pressing enter tally will get open and at company info screen press Ctrl + Alt + R then select the corrupt company.
Nitin Bankar, Pune
Mar 23, 2009 | Tally T2250 Matrix Printer
Software Exception c0000005
to solve this type of problem first of all take backup of your tally data then right click on ur tally icon on desktop go to properties then click on findtargate open ur tally configuration file see the line
load comony=yes (change yes into no) save the file & exit start ur tally pres ctr+alt+r selct the company which was giving error press enter tally will ask to rewrite the company press y to yes let the finish rewrite task then start working on tally
try this this works
RAKESH RANA
98682225794
Feb 02, 2009 | Computers & Internet
ERROR IS (MEMORY ACCESS VOILATION C0000005)
I AM FACING LOT OF PROBLEM DUE TO ABOVE SAID ERROR ALL THE OTHER SOFTWARE IS RUNNING PROPERLY EXECPT TALLY 7.2
TALLY IS OPEN UPTO SELECTION OF COMPANY AFTER THE COMPANY SELECTION AT GATEWAY OF TALLY IT SHOWS THE ERROR MEMORY ACCESS VOILATION C0000005
Nov 12, 2008 | Tally Line Matrix T6050 Printer
Corruption of tally 7.2file
Exiting Tally!
File Damaged
File:C':Tally7.2\Data\009\manager.500
Size 180180
Position: 180352
Charj : 128 (done128)
Jul 04, 2008 | Tally T2250 Matrix Printer
Recover tally data
Dear Sir/Madam,
I am getting the following error,
Existing TALLY file damaged File:C:/Tally/0001/Tr01298.500
Position:149760
Chars:128(done 128)
Please give me a solution to get my data and I am using Tally7.2 version...
Thanks & Regards,
S.Prasada Rao
Sep 10, 2007 | Tally T2250 Matrix Printer
Tally T2250 Matrix Printer Logo
647 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
