My kenmore washer won't go to spin cycle.I've checked the lid switch and it engages but acts like it's bound up or stuck.
    Sergeant:
    Champion:
  • 289 Answers
Hi..probably the belt is slipping, could be worn
or stretched.
check it out..
thank u..
rate me..
Posted on Apr 20, 2009
  • Hariharanath V Apr 20, 2009
    hi..if your washer is new check out the clutch
    first.
    check it out..
    thanks..
After rinse cycle won't washer won't spin
Sound like it could be a lid safety switch.
May 24, 2014 | Kenmore 22422 Top Load Washer
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Kenmore Washer 70 series Model #110.22722100 won't spin
Click if helped.
Feb 25, 2013 | Washing Machines
My kenmore ad 80 series washing machine won't spin
The lid switch is probably out. Bypass it and see if she magically comes to life. Their are 3 wires to the lid switch 2 of which are live wires. Jumper them 2 live wires and see if she runs in spin.
My home video: Washer won't spin It's a doozy
Jul 20, 2012 | Kenmore Washing Machines
My washer will not rince, spin, or drain the water, but will fill and wash cycle works.
check the lid safety switch, if its not engaging, it won't do the things you've mentioned, you can jumper it to check it,, just use a wire to connect both wires together at the plug in connection, unplug the switch and replace it with a wire to each connection point
Jul 25, 2011 | Kenmore Washing Machines
I have a Kenmore 60 series heavy duty washer. It will wash and drain in all cycles just fine, but it won't spin. It sounds like it wants to spin but it wont.
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 22, 2011 | Kenmore 24032\24036 Top Load Washer
Washer won't do spin cycle....and won't start any cycle
Kevin
Jul 15, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Washer does not complete spin cycle. Have to open and close lid to get it to restart.
Your lid switch is acting intermittently. Replace the lid switch.
Oct 05, 2009 | Kenmore Washing Machines
Kenmore washer mdl#110.23832100 spin cycle motor
Hello, looks like your lid switch is on it's way out, replace it...you will find it normally about half way down under the lid. If not there you will find it in the control panel on the right side next to the water level control. The reason it works some times and not others is because some times it fails to push the lid switch down far enough to engage. the lid switch is a safety divice inteneded to stop you opening the lid while in a high speed spin. If you have any other questions please feel free to comment again. Mike
Oct 01, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
