Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Cannot add printer to PC on network
I have a desktop PC running Vista Home Premium. A Kodak 5300 AiO printer is connected locally to this PC and printing is set for sharing. Printing works fine from this printer. I also have a laptop with Vista Home Premium and another desktop PC with XP SP3, all networked through a Belkin wireless router. From the XP machine, I can find, add, and use the printer. The laptop used to be able to print, but at some point it lost contact with the printer. I cannot add to printer on the laptop. When browsing the network on the laptop, I cannot even see the printer connected to the Vista desktop.
  • 107 Answers
Heres a link for drivers for your machine.....download the proper driver for each individual system and run setup application
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9106&product=EKN033540
Posted on Apr 20, 2009
Kodak 5300 all in one printer will not scan. Cannot get on line with 5300 a10 home center program, tells me printer is not connected
try to unplug replug the usb cable of the printer.
You may also go to control panel printer and faxes and look for the printer of your 5300 now if you see 2 icons delete them both then exit to printer and faxes. and unplug/replug your USB cable then restart computer.
If this issue not solve try to uninstall the software and download the clearutility kodak.com/go/clear. then after doing this restart computer.
Nov 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak esp 3 all in one printer home center wont work
hello,
Run the clear utility. Go to www.kodak.com/go/clear
Step by step instructions are provided in that website.
after that uninstall the AIO Home center.
In the Control Panel, select Add or Remove Programs (WINDOWS XP OS) or Program and Features (WINDOWS VISTA OS).
Choose KODAK All-in-One Printer Software
Click Remove (WINDOWS XP OS) or Uninstall (WINDOWS VISTA
OS).
When the Install Wizard appears, click Next.
Select Remove from the drop-down menu for the Kodak All in One Printer, then click Next.
Click Next.
Click Continue.
Thanks
Neerak21
Sep 25, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak printer not detected
Check in your Control Panel (Printer & Faxes) if the printer is OFFLINE. Via wi-fi network, obtain the IP Address both of Printer & your computer.
Aug 06, 2009 | Kodak ESP 5 Printer
The kodak aio home center won't open getting error 1--2010 esp3 printer
if using vista try this:
Right-click on the Home Center icon.
Select Properties.
Select the Compatibility tab.
Click Run this program as administrator.
Click OK.
reply if does not work.........
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Can I use my Kodak 5300, installed as my network printer on a desktop running Windows XP with my new laptop running Vista? If so, do I run the install disk (with Vista drivers) on the laptop or what?
you should be able to as long as there are Vista drivers available.
make sure you first share your printer from the desktop it is attached to. then on the Visa laptop try to Add Printer choosing network printer (as opposed to local printer) and browse for the shared printer. Vista should tell you it has to install software so allow it to. Have the disk ready (does it have Vista drivers on it do you know?).
Word of caution: Vista's a little quirky with networked printers so you may have to delete the printer on the laptop and add it back if it doesn't work the first time (I had to do that even though all machines involved were Vista :/ ).
Cheers.
Mar 31, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Dell 3300 Printer Adapter and Vista
Vista is tricky when adding networked printers.
Add printer by using a local device, not a networked device.  Assume the printer is connected locally to the machine.
Feb 01, 2009 | Dell Inspiron E1705 Notebook
Video display with Kodak AiO Home Center
Make sure that your screen resolution is 1024x768
Jun 27, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak AIO Easyshare 5300 scanning problem
Could be USB connection if you have another cable try it. Try connecting to different USB ports on your PC. If you have a Powerd USB hub lying around try connecting the printer to the PC through that.
Also try disconnecting all USB devices including the printer. Reboot your PC. Connect only the printer and try and scan.
Some times multiple USB devices dont work when they are both connected to the same PC.
Hope this helps!
SDtester
May 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EasyShare 5300
Sorry to hear about your trouble. Since I am not sure of the details, let me offer a long review and suggestion. It may work for you, especially if the AiO software is not installing correctly.
If the KODAK AiO Home Center software fails to start or an error message appears, there may be a problem with the Microsoft .Net Framework 2.0 installation. To resolve this condition:
1. Open the Control Panel.
2. Double-click Add / Remove Programs (for Windows XP) or Programs and Features (for Windows Vista).
3. Select Microsoft .NET Framework 2.0.
IMPORTANT: If other versions of Microsoft .NET Framework are listed, do not perform this operation on those other versions. Follow this procedure ONLY for Microsoft .NET Framework 2.0.
4. Click Change / Remove (for Windows XP) or Uninstall (for Windows Vista).
5. Select Repair, and click Next.
NOTE: A progress bar shows the repair progress.
6. After the repair is complete, make sure the Restart the computer check box is selected, and click Finish.
7. After the computer restarts, start the KODAK AiO Home Center software.
IMPORTANT: If the KODAK AiO Home Center software fails to start or continues to display an error message, completely uninstall Microsoft .NET Framework 2.0 and do a clean reinstall KODAK AiO Home Center software. The Microsoft .NET Framework 2.0 will also be reinstalled with the KODAK AiO Home Center software.
1. Follow steps 1 - 4 above.
2. Select Uninstall, and click Next.
IMPORTANT: Uninstall ONLY Microsoft .NET Framework 2.0. If other versions of Microsoft .NET Framework are listed, do not uninstall them.
3. Restart the computer.
4. Perform a clean re-installation of the KODAK AiO Home Center software:
a. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
NOTE: Do not disconnect your mouse or keyboard.
b. Uninstall the Kodak EasyShare 5000 series all-in-one software:
1. In the Control Panel, select Add or Remove Programs (Windows XP) or Program and Features (Windows Vista).
2. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
Kodak EasyShare software
Kodak all-in-one printer software
3. Click Change or Remove (Windows XP) or Uninstall (Windows Vista).
4. When the Install Wizard appears, click Next.
5. Depending on the issue(s) you are experiencing, do the following:
- If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
- If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
6 In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
vii. In the Ready to remove the program window, click Next.
viii. In the Uninstall Complete window, click Continue.
ix. Restart the computer.
c. Delete the files and folders that can interfere with the installation.
For Windows XP, delete:
i. Printer folder in C:\Program Files\Kodak
ii. Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
iii. Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
iv. Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
For Windows Vista, delete:
ii. Eastman Kodak Company folder in C:\ProgramData
iii. Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
d. Run Disk Cleanup.
i. Open My Computer.
ii. Right-click Local Disk (C:) and select Properties.
iii. Click the Disk Cleanup button.
iv. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
v. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
vi. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
e. Shut down all background applications.
i. Select Start > Run.
ii. Type msconfig in the Open field, and click OK.
iii. Select the Startup tab.
IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
iv. Click Disable All , then click OK .
v. When prompted, restart the computer.
f. After the computer restarts, insert the KODAK EASYSHARE 5000 Series All-in-One Software CD into the computer CD drive to begin the installation.
g. During the installation process, when prompted, select to search for an updated version of the software on the Kodak Web site and install the updated version.
h. Before restarting the computer again, turn on the background applications.
ii. Type msconfig in the Open field and click OK.
iv. Under Startup Items:
- If only some items were originally selected, select the check box in front of the items that you noted in Step e-iii.
- If all background items were originally selected, click Enable All, and click OK.
i. Restart the computer.
Jan 31, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Home Center will not open...Can't scan
I needed to reload my AiO Home Center software and no one seemed to have the correct procedure. Maybe if you remove & reinstall yours it will resolve your problem. This procedure worked for me on my XP-machine:
1. got to Control Panel/Printers&Faxes and delete the printer
2. go to your Hardware/Device Manager/Universal Serial Bus Controllers, right-click on USB Composite Device and select Uninstall
3. go to Control Panel/Add/Remove Software and remove the EasyShare software
4. disconnect the cables from the Printer
5. download from Kodak.com the program "install_aio.exe"; run the program
(I selected only AiO+EasyShare+Software Updater to load)
6. followed the prompts after the sw installed to reconnect the Printer cables
7. rebooted
WORKED for ME !
Jan 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
217 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
