Question about Denon AVR-2700 Receiver
Unit worked flawlessly 1 hour ago
The unit now displays a standby lite continuously. The unit was working until wife hit a button in dark. cannot get unit to function
    Novelist:
  • 98 Answers
Hi Ernietex,
Dont blame your wife.
Your receiver is basically going into protect mode.
The Denon AVRs contains a microcomputer for signal processing and control functions. In an unlikely event, it may cause it to lock up. Unplug the power cord from the wall outlet, wait for 10 to15 seconds and then plug it back again.
But, before you do than, please also check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If you still can’t resolve the issue yourself, try resetting the AV receiver/AV amplifier before going on to opening the Receiver.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck. Thanks for using FixYa!
Posted on Apr 21, 2009
Hı sharp xg xv2e lamp tımer reset?thanks
hi
Do the following for resetting the lamp hour
1.Attach the power cord to the projector and plug it into an electrical outlet.
2.Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button. 3.Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
ok
Feb 04, 2011 | Sharp Office Equipment & Supplies
I have a gpx hm3817dtblk shelf system and i was wondering if you can get the alarm to play a cd instead of the radio or if you can do either one and how? Or does it even have an alarm?
The manual:
http://www.retrevo.com/support/GPX-HM3817DT-manual/id/1183ag710/t/2/
Page 6>>>>
Setting the Clock
a. Press the STANDBY button until the unit is in standby mode.
When the unit is in standby mode, the STANDBY button will be red.
b. Press the CLK ADJ. button. The time will begin to blink.
c. Press the HOUR and MINUTE buttons to adjust the hour and minute.
d. Press the CLK ADJ. button to set the adjusted time.
Setting the Alarm
b. Press the ALARM SET button. The time will begin to blink.
c. Press the FUNCTION button to seleect CD, Radio, AUX, or Buzzer.
For Buzzer mode, the display will not show any indication.
d. Press the HOUR and MINUTE buttons to adjust the hour and minute.
e. Press the ALARM SET button to set the adjusted alarm time.
An alarm clock icon will appear on the LCD Display when the alarm is set.
Jan 03, 2011 | GPX HM3817DTBLK Shelf System
I DON'T KNOW HOW TO PROGRAM THE TIMER I'VE LOST THE MANUAL. I NEED TO SET IT MON- SUN FROM 7PM TO 12PM IT SHOWS: 1 ON THIS IS WHERE I HIT HOUR & PUT 7:00PM THEN I HIT PROGRAM IT SAYS 1 OFF I HIT...
You posted under Intermatic HB88RC timer
If you have different timer, add a comment
HB88RC timer manual:
http://waterheatertimer.org/pdf/hb88rc.pdf
Here's HB88RC programming from the top:
Remove batrery from back of timer to reset timer and clear everything.
Re-install AA battery in timer so display will show, and you can program
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
If you want all week long, then press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 7pm shows >> this is event1 ON
Press Min button until :00 displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Match days with ON time: so press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 12pm displays >> this is event1 OFF
Press Min button until :00 displays for event1 OFF
When programming is finished, press clock button to display current time
When programming is finished, press MODE button to select MODE > you want AUTO for timer programs to operate
Press MODE button once and this is manual override, and lights come on.
Press MODE button again and RDM displays, this is for random timer operation
Press MODE button 3rd time, and timer is set to AUTO
After setting MODE to auto, press clock button to display current time.
Plug timer into receptacle.
Plug lights into timer.
Add a comment any time.
A lot of folks have written in about this timer going bad and they have been unable to program the timer. Of course most timers work perfectly fine.
Dec 18, 2010 | Intermatic HB88RC - 7-Day Programmable...
Time and outdoor temp not functioning
You probably need to set the time zone. Hit the set button until it shows the time zone (ie -7 MST), then hit the "+" button until it shows your time zone and the correct time. Continue hitting the set button to cycle through to the end of the settings.
Jun 24, 2010 | SkyScan 86709 Atomic Wall Clock
Tripp Lite OMNI 1000 LCD will not stay on
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Feb 19, 2010 | Tripp Lite OMNIVS1000 UPS System
Setting alarm
Alarm can only be set or disabled when the power in "Standby" mode. The manual refers to it as power "off" mode, but the LCD display will still be readable only darker. To set the alarm push the Standby button until the sound stops and the LCD is dark. Then push the AL SET button (which doubles as the volume down button when the power is "on"). The hour should start flashing. Adjust the hour by using the two buttons at the bottom on the right side just above the IR sensor. Once you've set the hour, push the AL SET button again and similarly adjust the minutes until you have the right time that you want the alarm to go off. Now push the AL SOURCE button (which also doubles as the function button when the power is "on") to toggle between Radio, CD, iPod or buzzer for your alarm. After you're satisfied that the time is right and the source is right push the AL SET button again. The LCD should still be dark, but should also show the word "ALARM" in the upper left hand corner.
To set the unit so the alarm doesn't go off push the "Standby" button until the sound stops and the LCD is dark. Push the AL SET button until the hour is flashing. Don't bother to adjust the time, just push the AL SOURCE button until none of the following appear: CD, iPod, Radio, Buzzer. As you push the AL SOURCE button it will toggle between these options. Once you're sure none of them appear on the left of the display, click the AL SET button again. The LCD should still be dark, and you should not see the word "ALARM" in the upper left hand corner.
Jul 04, 2008 | GPX HI2817 Shelf System
Unable to turn off DEMO MODE
1. Turn Radio On
2. Change Source input to Stand-By
( Puts radio in display only Stand By mode.)
3. Press Menu Button
( Gives you standby menu)
4. Toggle display with control knob until DEMO ON appears
5. Hold control knob in until DEM0 OFF appears
6. Press Menu Button
7. Change source back to music.
All done. same as other Fixes - Just step by step!
Sep 09, 2007 | Kenwood KDC-MP435U CD Player
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
XV-N322 - Lock will not unlock
My problem was fixed by...having the DVD powered off, holding down the stop button on the player and hitting the power button on the remote.
Good luck!!
Jan 22, 2006 | JVC XV-N320 DVD Player
259 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
