Question about Texas Instruments TI-5045 SVC Calculator
Casio DR-210HT Calculator
Went to change ribbon - now will not print or feed paper. get an "E" when I try to print. The gears should move by hand but don't. Opened another working unit to compare and now they both don't work. There must be a gear release that became locked on both machines. How do I release it. Thanks
  • Karen Burton
    Karen Burton Mar 16, 2008
    Adding machine worked fine yesterday. Today I have and Error message that has the machine totally locked up. I cannot get it to do anything. Is there a reset button somewhere?
5 Suggested Answers
  • 279 Answers
SOURCE: Calculator will not print
I don't think you'll find parts for this, however I did find a used one, buy it now, for less than $20, shipped: http://cgi.ebay.com/Texas-Instruments-Electronic-Printng-Calculator-TI-5045_W0QQitemZ160148715050QQcmdZViewItem Buying a used unit and either replacing yours or using it for parts is probably your best bet.
Posted on Sep 20, 2007
SOURCE: E shows on display screen and my 5045 SVC calculator won't work n
Mine did the exact same thing, only when I would multiply or add 5 and 5, when I hit = it showed up 555. I just put it on POWER IC for about 15 minutes. Then hit the clear button at the same time as I turned off the power. When I turned the POWER ON there was no longer an E or the crazy triple digits. Hope yours does the same. GOOD LUCK!!!!!!
Posted on May 14, 2009
SOURCE: I have a TI-5045 II Calculator that wont print
I have the exact same problem (just happended recently) with my TI-5045 II after 25 years of good service. My solution? I just bought another model: Sharp EL-1801V at Stapels for about $31.00. To get the old one fixed will probably cost me $25.00-30.00 just to diagnose, plus shipping and parts and labor. And that assumes I can find a shop to do it, or that TI still stocks the part(s) gone bad. Same old problem with all technology.
Posted on Oct 12, 2009
  • 102366 Answers
SOURCE: How I load the paper roll in my TI-5045 II A
Follow the (somewhat) illustrated instructions in the guidebook available on the manufacturer's web site at
http://education.ti.com/downloads/guidebooks/printer/5045svc/5045svc.pdf
Posted on Jul 20, 2010
How do i change the ribbon in casio dr-250hd
Hi, you can download the user guide here, which should tell you how to replace the ribbon:
http://www.helpowl.com/manuals/Casio/DR250HD/40705
Sep 17, 2014 | Casior Dr-250hd Printing Calculator
I replaced the roll of paper and now it will not
The Casio DR-T220 does not use regular adding machine tape, it requires a thermal tape since it is a thermal printer. There is no ink or ink ribbon in this caculator, it is heat activated and it is the special paper that make the numbers appear. Thermal tape is available at all office supply stores.
Oct 05, 2009 | Casio DR-T220 Calculator
How to load the paper into casio hr 100T . My son just came home with this old model. It has paper provided but no instructions. How do we get the paper to feed and in what directions does it need to be...
I have a casio HR-100 TM. After spending over an hour, and scouring the casio website which had an obscure spot that covered a totally different calculator!.... I found a slot in the back of the machine that when I folded the paper into an arrow, FINALLY went in! You may have to try a few times, but it will go in just keep holding down the feed button as you push and jiggle the paper.
Jun 20, 2009 | Canon P1-DHV Calculator
Reloading tape roll on a Casio DR-T120
Place the tape between the two posts; then put back portion of cover down followed by the removal front portion - press feed button and it should feed. Remember it will only print on thermal paper ----
Dec 08, 2008 | Casio DR-T120 Calculator
HOW TO LOAD THERMAL PAPER IN DR-T120 CALCULATOR
Simply place the paper between the plastic posts. Put top portion down; feed paper up slightly - put smaller front plate back in place and press feed button.
Dec 02, 2008 | Casio DR-T120 Calculator
Changing the % tax setting on calculator
First hit "CA" Key. Then hold down the "%" key for 3 seconds. Then input the tax rate. Next hit the
"TAX +" . Then hit the "%" again. You are done. make sure the printer is on.
Nov 15, 2008 | Casio DR-210HT Scientific Calculator
Casio DR-T220
Turns out the incorrect type of paper was being used. The paper needed is the paper that is sensitive to pressure and this paper was not.
Jul 22, 2008 | Casio DR-T220 Calculator
I NEED TO FIND A FREE DOWNLOAD INSTRUCTION MANUAL
I wonder if you can send me the User Manual of Casio Calculator P100-DH. Because I Have the machine, but I do not have the User Manual. I am located in the city of Bogota, Colombia.
Thank you.
Esteban Guerra P.
Jan 23, 2008 | Casio DR-210HT Scientific Calculator
Jammed gears
Alignment of the gears is needed to solve this case. Although only authorized technician can only align these gears because it is too complicated.
Sep 20, 2007 | Casio DR-210HT Scientific Calculator
Texas Instruments TI-5045 SVC Calculator Logo
97 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
