Question about Homelite Mighty Lite Lawn Trimmer
HOMELITE HLM140HP lawnmower
Need help with this please.Have just bought this and im having trouble with the pull cord, it wont come out of its housing further than a couple of inches?Appreciate any help.
2 Suggested Answers
  • 420 Answers
SOURCE: I cant start it due to the pull cord not coming out further than 5-6 inches??
Sounds like the cord may be wrapped outside of the recoil pulley and may be spinning the motor backwards. The cord can backlash especially if the trimmer kicked a bit during starting.
Posted on May 14, 2009
Pull cord wont recoil homelite xl 12
You will need to take the cover off to get to the recoil, then remove the pull handle do not let go of the cord! Now ease the cord into the reciol but do not let the cord go, now while holding the cord and the recoil spool rotate the spool 1 revelution clockwise, send the cord back up through the case hole and through the pull handle tie the knot in the cord and replace the case if this still isn't enough repeat the process.Dennis
Oct 31, 2012 | Homelite Garden
Homelite hlt25cs, pull starter cord, wont engage starter clutch, cant find how to access it
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. ``
Feb 02, 2012 | Homelite Garden
I had to fix the pull cord and know the cord will not return to the housing i cant figure out how to fix
you need to untie the pull cord from the handle... and wind up the srping the wile holing it there fish out the end of the pull cord and retie it to the handle
Dec 13, 2010 | Homelite Garden
How do I replace pull cord on a Mightylite UTO 8580 blower. Seems like no one has answered this question except to say to bring it into a lawnmower shop. Thanks for your help.
You can do it yourself if you have a little mechanical ability. If not, you know the options.
Here is a breakdown of the parts to your machine. Dis-assembly will be required;
http://www.ereplacementparts.com/homelite-ut08580-26cc-blower-parts-c-18807_18808_18812.html
You will need to disassemble it to the point where you reach the engine cover housing in which the starter/recoil unit is housed. Most all of these machines use Torx-head fasteners. Some people call them "star" fasteners. Take time and pay close attention to how everything is removed. It is not that difficult. Once you have the pulley for the starter isolated, you can inspect and/or repair it.There is a spring steel spring coiled under the rope pulley in the recoil unit. Untie, the old rope. You will then have to "preload" the spring's tension on the pulley so it will draw your new rope in. Turn it to tighten it about 5 to 7 revolutions and then jam it in place with a screwdriver or pair of vise grips or whatever you have available to hold it. One person can even hold it for you while you thread the new rope into in and tie it off. I suspect a new pull cord should be about 30" or so long. There is a limited amount of room on the pulley itself to house new rope. After the rope is on, make sure you thread it through the hole in the housing cover and tie the pull handle off to the other end. Then you can release whatever you had holding it. Reinstall all the parts you removed and you are done. Lay the parts out in the order you take them off to avoid confusion when you put it all back together. It's not a bad job and you just might learn something from doing it. Post back with any more questions.
Nov 20, 2010 | Homelite Consumer Products Backpack...
I have a Homelite Mighty Lite 26cs gas weed **** and the starter cord will not retract into the weed ****. How can I get it to retract so it can be pulled to start the weed ****?
This is somewhat common in the the "zip start" machines. The recoil pulley is 2 plastic housings with a round coil spring between them. It is designed to need less effort to pull and start the machine. When pulled on with great effort/frustration, the middle spring bends and damages the upper housing. The only semi-permanent solution is to replace the pulley assembly. The part is relatively cheap thru Homelite.com. If you can do it yourself, go for it. A repair shop will most likely charge you $20 to $40 in labor to do this.
Aug 05, 2010 | Homelite Consumer Products MightyLite...
Alini pocket quad wont move
Have a look at the choke lever. From the starting position, move the lever about 10mm up until you hear a slight click. If not then the clutch plates are not responding to the throttle input. Any lawnmower repair garage will be able to help you more. The 2 stroke works on centrifugal clutch, that is the clutch plates move outwards when throttle lever is pulled. It is a bugger to start. I've got blisters on blisters from the pull cord. My son is 10 and he may well be a little big for his but when it goes, it is fast enough to start kids off with motor bikes. Hope it helps.
Jan 06, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Pull Rope Broke... How do I replace it and still have it retract?
with the cover in your hand pull the cord out with a pair of needle nose pliers or a little screw driver and where the cord go through the case and before the wheel. pull 5 to 10 inches out and wrap the cord around the wheel turning the wheel but not winding the cord on., do 3 or 4 wraps then pull the handle to get all the cord out and let it retract. if not enough rewind just repeat with 2 wraps
Jul 22, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Apr 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Trimmer Pull Start Cord
The part no. for the Spring and container is A98773A. You can Google the PN and find many sources. Expect to pay between $10.00 to $15.00. I like m-and-d.com If they have it in stock you will normally get it in 3 to 4 days.
Mar 25, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
333 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
