Question about Samsung SGH-E900 Cellular Phone
LCD Replacement How the hell do you get the casing apart once you have removed the 6 cross headed screws, I know they are clipped together but without knowing where the clips are I am struggling.Obviously I do not want to damage the casings so just need to know where they are.
  • 33 Answers
Http://www.excelldirect.com/images/samsunge900gallery/myalbum.html I'm sure you will know how to use this page.There are pictures how to disassembly and assembly E900. If you don't have a soldering iron you can cut off those soldered pieces (even I hate people what do this :) ), but take care about flex cable. Enjoy and take care, mate ;) Level4 tech.
Posted on Sep 26, 2007
Burned out lcd on epson rx600 - how do i repair?
Probably not worth the cost of parts to repair.
Pick up a 2nd hand one off ebay.
Feb 07, 2011 | Epson Stylus Photo RX600 All-In-One InkJet...
How to open an LCD monitor.
I personally haven't worked on this monitor, but most monitors are held together with plastic clips on either side of the casing.
After removing the stand and all other screws, you will need to use a small flat-head screwdriver (or something of that nature) to pry apart the clips. Find the crease/gap in the plastic where the casing of the monitor comes together. Insert the screwdriver and gently twist and pry the casing apart. When you hear the first click/snap indicating the first clip has come apart, follow the gap with the screwdriver, prying it apart each time you reach an area of resistance. Do this all the way around the monitor.
Keep in mind that after you open up all the clips, the LCD panel and boards may be screwed either the front casing or most likely the back casing. So you must first unscrew the mounting screws inside the monitor to remove the back cover. Also be careful unhooking ribbon or speaker cables that attach the circuit boards of the monitor to the front casing.
Jan 12, 2010 | Gateway FPD2275W LCD Monitor
How do you get the case apart?
chrisc257, Yes, you too, will need to watch some video clips @YOUTUBE !!! Search and view 6 to 10minute clips of "LCD monitor disassembly" and "LCD monitor repair" and stuff relating to "bad capacitors in lcd monitors" . Are you doing this as a SCHOOL SCIENCE PROJECT that you will be graded on? First remove the pedestal stand from the back cover.(screws or some locking TABS) Then remove screws from back cover. If you can see them. then un-snap the cover from the front bezel. Watch how they do it on youtube and be careful not to injure yourself or the monitor LCD panel.. GOOD LUCK GUY, YOU'RE ON YOU'RE OWN NOW!! 12fixlouie
Dec 01, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
How do you take apart an HP w1907 monitor? I have one that the picture only stays on for a split second at power up and then goes blank. I suspect a filter capacitor but can't take it apart to check.
haha, been there. This ones a little tricky. Hope you have strong fingers. start by removing the base. There are 3 screws. First pull the base plate off. Then remove 2 screws. Next remove the little rubber insert in the center of the base bracket. You will need a long phillips to get to the 3rd screw. Slide out the base bracket. Flip the panel over and stare at the lcd with the buttons side on the top. Grab a small flat head screw driver. Look at an angle in each of the corners between the inner black lcd trim and the silver outside trim. There is a ****. Shove the flathead in there and pry outward toward the silver trim while lifting on the black inner trim vertically. The trick is to flex the black trim toward the silver and then pull up. There are 6 plastic snaps on the top and bottom, and 4 snaps on the left and right. If you've taken laptop screens apart, you'll feel the similarity.
Once you pry the black trim off the front. Disconnect the LCD Menu button assembly and power button. Then flip over the LCD and lift off the back shell. Looking at the back, remove the 2 connectors for the speakers. Use a small flathead to pry the 4 Inverter power connectors. These 4 connectors have a clip on them and are usually hard to pull out using the wire. Once thoses 6 connectors are removed, remove the 2 phillips screws holding the AC power plug to the case. Also remove the 4 3/16 posts for the VGA and DVI ports. Next remove 4 screws, 2 screws from each side of the LCD assembly. Hold the panel face down with the aluminum tape in the bottom left. Lift the shield and guide the 6 wires through the cage. While opening, look inside and disconnect the flat ribbon cable as soon as you can. Put the LCD to the side. Remove 2 screws from the Video processing board, and 5 screws from the power supply. Note: 1 of the 5 screws is longer. Rotate/slide the power PCB away from the cage to clear the speaker and AC plug, Then rotate towards the Video board. Disaconnect 1 plug. The OTHER plug is SOLDERED and must be disconnected from the video processing board.
There you have it. It stumped me for about a half hour. No pry marks. Barely noticed the 2 slits in between the trims. Well, good luck. Happy Soldering.
PS: I opened mine because I assumed it had bad capacitors. It only powers on for a short short period of time.
Nov 17, 2009 | HP f2105 21" LCD Monitor
How to take apart the samsung gravity sgh-t459
Remove battery cover and battery. Using a #00 philips head screwdriver, remove the 6 screws around the perimeter. Slide phone open and carefully pry up on the edge of the green (or blue) trim near the space bar. The colored back should unsnap. There will be two philips head screws visible on the now exposed circuit board. Remove these and carefully pull up on the rectangular ribbon cable to disconnect the main circuit board from the keypad circuit. Carefully peel the two button contacts from either side of the phone. On the spacebar edge, there will be a clip holding the circuit board in place. Gently pry it away from the board and the board should come free (there will be clips on the other side but you should be able to lift the free side of the board up and slide it out from under the clips). Remove the QWERTY keypad. Unglue the remaining ribbon cable from the keypad frame. Undo the 8 silver screws securing the keypad frame to the hinge and lift frame off. There will be 4 screws visible on the back of the LCD case. Remove these and insert a thin plastic spudger at the top of the frame and carefully work your way around. The two halves will separate (should hear two snaps on each side). You will now be into the keypad/LCD section of the phone. Removing everything else is pretty straight forward. Follow these directions backwards to reassemble.
Oct 10, 2009 | Samsung Gravity SGH-T459 Cell Phone
How do you open the back of Thinkvision 20'' LCD Monitor?
NOT FAMILIAR WITH THIS PARTICULAR MODEL BUT EXPERIENCE OF MODERN FLAT SCREEN MONITORS ETC. SHOWS THAT MOST HAVE PLASTIC LOCATION STUDS AND/OR 'CLICK' LOCATORS ALONG THE SIDES + TOP & BOTTOM. THE SECURING SCREWS ON THE MONITOR STAND + CONNECTORS AND MAINS SOCKET MAY ALSO 'DOUBLE' AS CASE SECURING SCREWS.
FIRST ENSURE THERE ARE NO MORE SCREWS HIDDEN UNDER LABELS THEN GENTLY, - REPEAT G E N T L Y - PRISE WITH A WIDE BLADE ALONG THE EDGE, USING CARDBOARD OR PLASTIC WEDGES TO KEEP THE HALVES APART. DO NOT FORCE THE BLADE AS THE PLASTIC CASE LOCATOR SLOTS MAY BE DAMAGED
Sep 26, 2009 | Computers & Internet
The LCD display is black on my EPSON RX600 printer . I am unable to view menu on screen. How do i change the ink cartridges?? Do I need a neww bulb?
If you epson rx600 is installed on your computer, print from the Smart Panel. You can install drivers and programming by connecting it to your computer and letting the "found new hardware" wizard do it's job.
A bubble will pop up to let you know when you are low on or out of ink. Click on the bubble for more information and follow the instructions.
Jul 10, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
How do Iopen the case of an HPvs17x monitor?
The Capacitors on the power board are usually the reason for failure of an LCD. If you open the HP VS17 ( I can provide an exhaustive step by step If I have to) remove the five screws for the power board ( larger of the two boards) and look for an area where there are 4 caps (see pic). Look for exploded, popped up, bulging, or leaking caps and replace with the same or slightly higher tolerances. The one I replaced last night were (2x )1000uf25-50volt and (2x) 470uf25-50volt. Check the rest of the board for similar issues and replace as needed.
Jan 21, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Can't remove cover of Westinghouse LCM-22w2 monitor
Hey Ed,
I hope I can help, It doesn't open from the back, it opens from the front.... carefully! There are four support screws, which hold the LCD screen to the desk stand,after removing all the support screws (4) on the back under the support stand cover.(which pull up to remove) (Remember! the whole case and face frame is plastic, so take your time). Work to separate the black face frame around the LCD from the silver case. Its held together by small plastic clips on the face frame to the wall on the LCD case. Start at one of the corners and slowly pry the face frame and silver case apart. (separate it inch by inch, work your way around the case carefully. If one corner doesn't give, go to another side.
Putting back together works reverse, the face frame and the case snap back together, Carefully! And replace screws (4).
Russell
P.S. I have three LCD models from Westinghouse, LCM-22w2, L2210NW and the L1916HW. They all open the same way.
Dec 07, 2008 | Westinghouse 22" Widescreen LCD Flat Panel...
DS Lite touch screen
You'll need a tri-wing screwdriver, a small cross head screwdriver a new touch screen and a lot of patience.
1) Remove the screws from the botom case, 3 tri-wing, 3 cross head and the battery cover and battery.
2) Carefully split the bottom case and remove.
3) Open the clip that clamps the touchscreen cable from the back of the connector with a small screwdriver, just carefully lever up the back edge.
4) Carefully part the botom screen from the touchscreen.
5) Attach the new touchscreen to the bottom screen.
6) Re attach the ribbon cable to the clip.
7) Carefully refit the bottom case taking care not to break the power switch.
8) Re fit the screws.
HTH
Mar 01, 2008 | Nintendo DS Lite Console
Samsung SGH-E900 Cellular Phone Logo
43 people viewed this question
Top Samsung Cell Phones Experts
John Tripp
John Tripp
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
