Question about Acer Aspire SA80 (ASA80UC4603) PC Desktop
There is no volume icon on the right hand side of my computer and i have misplaced the sound driver disc that came with the computer. what do i do to reinstall the sound
  • 107 Answers
You should know what exact Motherboard model you have if you are not sure you can use software like Everest. It also has a link to manufacturers website for finding new drivers. Usually Sound driver utility puts an icon in the down right corner of your screen. And you may also have an icon from windows Control Panel Sound applet. If you want it to be visible you go to Start-Control Panel-Sound and you have to put check mark near show an icon in a taskbar. Good luck!
Posted on Apr 20, 2009
Model no# for issue no sound using Windows Xp (home edition) is 1213 V2 Premiere.The recovery disc. used was a Dell pc notIebook,my os originally had sp1 but I installed
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers.
Click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
If his does not fix the problem
Click start control panel sounds and audio devices you can adjust the volume there also select speaker.
volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume.
Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable).
The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity.
Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
Dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
On the home page you should see a search tab just type in what you are looking for.
Tick in either the all software or windows software box
IE: motherboard name audio driver you might have to try a few times to get it right
Nov 19, 2012 | Computers & Internet
Have Koss hd-50 (hand me down) would like a diagram, have no sound, running winxp on dell xperion 8400, says "no active mixer devices"
i will go through the process of setting up sound on your computer
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
if you need more help with this post a reply
hope this helps you
Sep 21, 2011 | Koss HD 50 Computer Speakers
No sound
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if you dont have a motherboard disc you will have to download the drivers
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
hope this helps
Sep 07, 2011 | Computers & Internet
There is no sound coming out of the speakers on the laptop, although the bottom right hand corner Sound icon shows sound being produced.
Hi pat_gill,
Welcome to FixYa! How are you doing?
When was the last time you have sound? Did you install any software or programs recently?
  • Please make sure that the volume is not set to mute.
  • Try to reinstall the sound driver. You can install the sound driver using the drivers disc that came with your computer or you can download it from the computer manufacturer's website (example: http://support.dell.com). Don't forget to restart your computer after reinstalling the sound driver.
Hope that helps. Thank you for using FixYa.
Apr 30, 2011 | Computers & Internet
Sir i am installed sound driver's but sound is not coming this speakers working in another pc and i don't have speaker symbol in task bar bottom right side i saw in control panel but open sound icon it's...
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
don
Feb 22, 2011 | Creative Labs I-Trigue 2.1 3300 Computer...
I want to download vga and sound driver for free...plzz help
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar then
scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
If your computer came with a motherboard disc the drivers could be on it
hope this helps
don
Feb 13, 2011 | Computers & Internet
No sound
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 20, 2011 | Dell 5650 Computer Speakers
My altec lansing vs4221 right satellite has no sound
hope this helps
Jan 20, 2011 | Logitech X-540 Computer Speakers
Pc sound is not working right now hepl me
hope this helps
Jan 20, 2011 | Computers & Internet
No sound
hope this helps
Jan 13, 2011 | MidiLand MLi 691P Computer Speakers
Acer Aspire SA80 (ASA80UC4603) PC Desktop Logo
81 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
