Question about JVC GR-DX97 Mini DV Digital Camcorder
JVC GR-DX97 - problems with picture
The picture jumps on playback, either through the camera or via TV. It does this with tapes recorded earlier which did not jump so assume it is the camera not the tape. It indicated it needed a cleaner tape, used one, but the problem still persisted.
  • DoctorMoshe Dec 24, 2007
    I have the same problem. I tried a tape cleaner and then cleaned the head myself. How do you do the adjustments? I am willing to give that a try also.
    President:
  • 4,402 Answers
Sounds like the guides have moved and need to be readjusted and tightened. need to take in for service
Posted on Dec 19, 2007
JVC mini Dv GR-D720E has small squares on playback
Indeed it seems that there was a really stubborn bit of dirt on the heads. I had to use the cleaning tape several times to ultimately have a clear picture on record and playback.
thanks again ,but successive cleaning can help for an effective cleaning of the tape path and heads.
Feb 04, 2010 | JVC GR-D73E Mini DV Digital Camcorder
No picture. Camer drives tape but does not record
Playback no picture? Try to clean the head by inserting cleaning cassette. During camera mode, i don't know if you see anything in your monitor. What you see is what you can record on tape so may be your problem starts from here, please elaborate more.
Jan 05, 2010 | JVC GR-D290 Mini DV Digital Camcorder
Condensation, operation paused
Try running a cleaning tape through the JVC 2 or 3 times and also wiping all around the tape compartment with a long cotton bud soaked with isopropyl alcohol. It cured my problem in Singapore.
Oct 30, 2009 | JVC GR-DX97 Mini DV Digital Camcorder
Cannot record due to a black screen
OK, that means you can see clear picture in playback of old recorded tapes and camcorder just wont give you live view to record any more.
If its true then it is known problem/ failure of ccd imager in your JVC GR-D33 camcorder.
JVC will repair it free of cost, click JVC CCD Imager Advisory for details.
Thanks.
Sep 17, 2009 | JVC GR-D33US Mini DV Digital Camcorder
How do I connect my digital camera to the TV so I can playback.
gidley,
Hey that is a classic video camera, very cool, one of the first to have PC connectivity, one of the first to use a firewire connection (fast) to a PC, all that in mind the little docking station that came with it should have video (RCA) type plugs on it that would match up to most TV's and VCR's (if you still have one) DVD players, you can play back your movies. It has the ability to store analog to digital onto your computer - if you have a DVD burner on your PC you can make DVD's out of those old movies with your kids, that would be the way to go. I'll dig around to see if one of my sources still has his manual for this camera. I'll check back with you within the next day.
randy320sgi
Jan 08, 2009 | JVC GR-DX97 Mini DV Digital Camcorder
JVC GR-DX76 - No Picture
which view finder? contrast or brightness?
Apr 22, 2008 | JVC GR-DX76 Camcorder
Lens Cap Warning & Gray Distorted Display
CCD Failure/Lens Cap Warning Error JVC has received reports that in certain circumstances, the following models may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at a JVC Authorised Service Centre even if the unit is outside warranty.
Please call our Consumer Support Department on 0870-330-5000 to obtain your free repair. We apologise for any inconvenience and we appreciate your understanding and support.
Please note that this offer expires on 30th June 2009 and is applicable only to failure of the CCD image sensor.
This information applies to the following models:
GR-D18, GR-D20, GR-D21, GR-D22, GR-D225, GR-D23, GR-D24, GR-D30, GR-D31, GR-D32, GR-D33, GR-D34, GR-D40, GR-D43, GR-D50, GR-D53, GR-D54, GR-D60, GR-D63, GR-D70, GR-D73, GR-DX25, GR-DX27, GR-DX28, GR-DX35, GR-DX36, GR-DX37, GR-DX45, GR-DX47, GR-DX48, GR-DX55, GR-DX57, GR-DX67, GR-DX75, GR-DX77, GR-DX78, GR-DX95, GR-DX97, GR-FX15, GR-FX16, GR-FXM39, GR-FXM393, GR-FXM40, GR-FXM404, GR-PD1, GR-SX19, GR-SX25, GR-SX26, GR-SXM29, GR-SXM30, GR-SXM49, GR-SXM50, JY-HD10.
Jan 01, 2008 | JVC GR-D20EK Camcorder
Bad playback
Please try to buy a head cleaning tape and put in your camera and play for three times..Then record a cassette and play,if you are not getting the picture replace the drum assy and check.
Oct 12, 2007 | JVC Cybercam GR-DVP9 Mini DV Digital...
JVC-GR-D371U
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 25, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Jvc 200u problem recording to vhs video tape, from camcorder
Yes, if the camera is a US camera then it is NTSC. That would be your problem, you are trying to record an NTSC signal to a PAL video. THe frame rates and resolutions are all wrong. I am even surprised that it is playing back on your TV okay...
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC GR-DX97 Mini DV Digital Camcorder Logo
121 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
