Question about Sony Handycam DCR-TRV33 Mini DV Digital Camcorder
No picture when trying to record
Will play previously recorded tapes. When try to record new material - only audio present - no picture just grey screen with usual tape timing / date etc displayed. Tried changing tapes to no avail.
5 years old - never had a problem before - misplaced manual.
  • roniak Apr 26, 2009
    no picture while recording, just sound, however when you record lamps, sun, any kind of light, there are some green shadows visible but not recognizable. Videos recorded before are nice and sharp.
  • Anonymous May 01, 2009
    black screen with timing / date displayed but no display...
Check the following link. Call them and explain the symptoms and they should send shipping label to you so you can send the camcorder in for repair. I had my TRV38 repaired in about 2 weeks. Good luck.
esupport.sony.com/perl/news-item.pl?mdl=DCRTRV19&news_id=95
this is a known issue with Sony
Posted on Jun 09, 2009
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Dec 09, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Not recording or playing back recorded tapes
first leave your camcorder with the cassete draw open in a warm room for 24 hrs.
then, use a brand new cassette & re try.
if you get the condensation message, it means the unit has detected moisture on the heads, the unit will not operate... hence your problems.
May 09, 2017 | Sony Handycam DCR-HC14E Mini DV Digital...
My video camera won't record or play videos.
I have about 2 to 3 tapes that wont play on any of my cameras. I have lots of footage on each of them.
Dec 13, 2008 | Video Cameras
Canon camocorder thick gray lines on ever recording
Supreemwun,
Canon support was of no help. They ****! To fix the problem this is what I figured out.
  1. Before you start filming what you want record or just advance the tape 10 secs or so.
  2. Record/ video whatever you planned.
  3. Now when the thick grey lines come up on play back don't freak out.
  4. Simply rewind the tape to the beginning and record briefly in the blank portion at the beginning (careful not to tape too long as to tape over your intended recording).
  5. Rewind and play the thick grey lines should now be gone.
How did I figure this out just a fluke. No cleaning, no spray pretty simple. At first did not understand it but it works EVERYTIME for me. I'll deal with it until I get around to buying a new HD video camera and it won't be a Canon. Hope this helps.
Jan 13, 2008 | Canon ZR100 Mini DV Digital Camcorder
Bad recording from any source
The fact that both inputs give you a bad recording indicates its something common to both inputs. First thing I would do is try cleaning the heads. It's the cheapest solution to try. There is also an erase head as well, but that is usually not part of the video head. The erase head erases the tape just prior to the record head recording the new material on the tape. Problems in the erase head will cause you to see both what you just recorded and what was previously on the tape. The picture will be distorted and shifting back and forth between the new program and the previous one.
- Jim
Nov 29, 2007 | Mitsubishi HS-U560 VHS VCR
Recording problem on Sony SLV-R1000
The deck needs a good cleaning. Try using a brand new tape and run it on playback for 20 min or so. You could try using a cleaning tape, but many of them are abrasive. If this doesn't work, you need a deck re-alignment which will cost more than your set is worth.
Nov 13, 2007 | Sony SLV-R1000 S-VHS VCR
How do I remove lines
I had the problem of the horizontal grey lines with some pixels of pink. I ran the dry head cleaner a few times and the lines became solid grey with the sound now skipping worse than before. I cried, cleaned again, then played the tape. I did this about 4 times and still had no luck.
I then decided to try to record with a new tape around the room to see what would happen. After recording I played the tape back and it worked perfectly. I then went back the old tape that would not play properly and it worked fine! Seems like when I used the record button after cleaning it a few times everything worked fine, wierd.
Hope this might help someone.
Oct 22, 2007 | Canon ZR80 Mini DV Digital Camcorder
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Not recording clear.
Hello, please try to playback these new recordings on some other Camcorder. If you experience good picture on the borrowed Camcorder it means that the video head is (partly) damaged. In order to cure this the video head is to be replaced. Please contact the Authorized Sony Service or the technician with the best references. Best regards, Arpi
Apr 18, 2007 | Sony Handycam DCR-TRV250E Digital...
Audio
Does it play back professionally prerecorded tapes okay? Does that VCR have a HiFi stereo option? What is the brand name and model number of the unit?
Apr 24, 2017 | Panasonic PV-C1331W 13 in. TV/VCR Combo
Sony Handycam DCR-TRV33 Mini DV Digital Camcorder Logo
244 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
