Question about Dryers
Dyer no movement/heat on stack unit- washer fine
I have a frigidaire stack washer/dryer - the washer works fine , but the dryer won't make a sound - plug secure and breaker is fine wires tightly screwed - but no dyrer
  • 547 Answers
It sounds like the dryer motor please change thanks
rate me
Posted on Apr 20, 2009
Why frigidaire dyer model fex831cso not heating up?
Good Morning Friend,
I understand the dryer is not heating up on your Frigidaire laundry center, model# FEX831CS0. First, there are two house fuses that the dryer is plugged into. Make sure that both are good and the breaker has not been tripped. If one of the fuses is blown, this can cause your dryer to not heat. Secondly, make sure that the lint filter, lint trap area, ducting leading outside, and the outside exhaust duct are free of lint. This can cause your dryer to not dry, due to lack of ventilation. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Washer/Dryer Combo FEX831CS0 won't work
Hello Laura Clark - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Since it is such a complex unit, I suggest contacting a professional to move forward accurately
Dec 12, 2012 | Frigidaire FEX831CS Top Load Stacked...
Dyer wont spin
Hi - When was the last time the ducting in your home was cleaned and confirmed that it has no debris or build up? Turn the breaker to the unit off for 5-6 minutes. Turn the unit's power back on and try a cycle again. If this does not prove to be successful here are a few possible causes that a technician would be required to check: defective heating element, control board, blower assembly, power supply (240v), high limit thermostat or defective sensor.
Oct 27, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer / Dryer dryer won't start
Hello - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and start normal cycle. If this proves to be ineffective, then contact a professional to move forward accurately. Possible causes could be a faulty power cord or house wiring, defective control board, thermal limiter or door switch.
Oct 22, 2012 | Frigidaire FEX831CS Top Load Stacked...
I have a Frigidaire GLET1031 Top Load Stacked Washer / Dryer. The water valves do not work unless the dryer is turned on. Also the washer drum will not spin with dryer on or off and the dryer does not get...
WHat ya need to check is for proper power going to the entire unit it sounds as if either a breaker is off or their is burnt/broken wire from the main power connection.
All symptons listed i suppose occured suddendly?? and to me its a lack of proper electrical power that is causing all of them.
GENE
Oct 03, 2011 | Frigidaire GLET1031 Top Load Stacked...
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Water won't work but dryer does
Mine did the same thing and it ended up being an overloaded older breaker in the electric box. It would allow the dryer to work, but the washer was too much for it to operate. Had the breaker replaced with a new one and it works fine. Hope this helps!
Jun 14, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dyer on combo won't start
This could either be a bad start switch or door switch
May 29, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Dryers Logo
73 people viewed this question
Top Dryers Experts
