Water filling problem. Load size switch seems mis-aligned
I have a whirlpool top loading washer model number LSQ8520JQ1. A problem occurs seemingly with the load size selector switch. If for example you select "large" for a load size, then start the washer, instead of the washer beginning to fill with water, nothing will happen. But then, I can immediately turn the load size switch to a point maybe half way between "large" and "super plus" and water will begin to flow in. I would have to hold the switch in that half way position if I wanter water to continue flowing, because the switch does not "lock" between the size selections. It's as if there is a mis-alignment within the switch. The same problem will happen during the rinse cycle. Do you think that the problem lies with that switch?
  • 11 Answers
SOURCE: Front loading washing machine
you have a three armed support that holds the tub in place, this is not an easy fix, you would have to be very knowledgable of appliances and how to work on them to replace this. Basically one of your supports have either broken or the bolt has come lose. If you release the baffles inside the tub you should be able to see the mounting bolts for the support and you would be able to check the tightness of the bolts or whether or not the mount is broken. If the mount is broken in won't be cheap to fix. Hope this helps.
Posted on May 20, 2007
  • 76 Answers
SOURCE: Maytag washer PAV2300 water over flow
tidalwave If the water continues to flow even when the washer timer and the power to the washer are off then you are right and the water inlet valve has to be replaced. If it does it only when the washer is on then it could be different problems. In that case the first thing you have to check is the water level switch. This is the device which controls the water level. Remove the power first.Open the control panel and you will see the switch on the left side. There is the clear plastic hose connected to the switch. Make sure the hose is not loose. This is one of the most common cause of overflow. If it got loose, drain out all water from the washer before you reconnect the hose. If this is not the issue then you have to check the continuity across the water level switch therminals. When there is no water you should measure the continuity across therminals 11 and 12 (gray and orange wires). Whet the tub has filled up with water you should measure the continuity across therminals 11 and 14 (gray and light blue wires). If the continuity is wrong replace the water level switch. If you are going to do it, make sure there is no water in the tub before you will remove the clear plastic hose from the old switch. Good luck. Gendos. post back...
Posted on Jul 08, 2007
I had the same problem and went out to a website for Maytag washers. That website advised that the problem could be mechanical or electrical. In my case, the problem was a clogged tube and it took only ten or fifteen minutes to fix.
0. Unplug the machine.
1. Open up the front of the washer. Along the left hand side is a long transparent tube. The tube connects to a wallet size container on the side and near the bottom of the tub.
2. Inspect the transparent tube. It may be clogged where the tube meets the wallet sided container.
Note: When the tub is full, it creates pressure in that wallet size compartment which sends air up that tube to a pressure switch located within the panel at the top of the washer. The pressure switch flips and tells the machine - stop filling the tub with water. My machine had a visible clog in the bottom of the tube that carries the air from the bottom of the tub up to the pressure switch.
3. Disconnect the tube and clean. I used a pipecleaner to get most of the mold out. To completely clear the tube, remove the top panel and disconnect the tube from the pressure switch in the top panel and blow air down the tube.
4. Reconnect, test - and you should be good to go. If not, your pressure switch may be dead.
Posted on Dec 06, 2008
localwonder
  • 6784 Answers
SOURCE: Whirlpool LXR9245EQ2 tub won't fill at beginning of cycle
HI, you have a combination issue. the Water fill level pressure switch and, the cycle selector switch are both damaged and, they should be replaced. the total cost of these switches will run you about $90.00.
We recommend the hands of a skilled service tech when repairing this type of electrical issue.
Posted on Jun 18, 2009
  • 53 Answers
SOURCE: my washer vibrates like crazy
Make sure it is perfectly level. If it is, you may just have a weak floor in your new place?
Posted on May 21, 2010
I have a Whirlpool ZUltimate Care II Washer, Model 3XLSQ7533JQ2. Washer keeps filling in the medium and the super wash level and will not go into the agitation cycle. Works on small load level only.
SInce the washer works ok on the small load size yet overflows on all others the problem is going to be with the water level switch and it should be replaced to remedy that problem.
The part number for that water level switch is W10339229 it could be purchased at your local appliance parts store or online at
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Oct 13, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool ultimate care II that won't fill with water it just starts agitating. Sometimes if you hold the load size switch in between load sizes it will start filling but you have to hold the...
The problem is quiet obvious and it is the water level pressure switch behind and connected to the load size switch knob. The pressure switch is stuck in the full position that's why the machine doesn't fill and it goes directly to agitate. Holding the load size switch in between load sizes releases the contacts from full position and allow the machine to fill as long as the switch is held on.
Disconnect power then release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Behind and connected to the load size switch under the console is the water level pressure switch with a clear hose attached to it.
Remove the pressure hose from the pressure switch then reinstall the console and reconnect power. Start The pressBlow air forcefully into the pressure swic
Feb 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer leaking water
Hi there.i have a feeling that maybe the thin tube that runs from the water level pressure switch has come off the righthand side of the bowl & water is coming out of it.if thats the case the machine would never stop filling even at lowest setting.can you let me know what you find.
Jun 03, 2010 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool washer model #LSQ8520JQ1 won't spin or drain
there is a possibilty the drain pump maybe locked up by a small foreign object such as a small nail tooth pick drill bit or even a coin check that.if that does not solve them problem then the timer or control board may need to be replaced
Sep 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Jun 18, 2009 | Whirlpool Washing Machines
Hi. My water level knob is very hard to turn and the water level is not correct when filling the washer. Any thoughts?
if it has been quite some time since you turned the knob it is possible that it is starting to sieze up, you may have to replace the switch behind the knob
May 09, 2009 | Whirlpool WTW5560SQ Top Load Washer
Does not spin
The close pin most likely broke the switch. Unplug the washer, remove the screws that hold the top and flip it back and remove the cabinet. with the cabinet off it is easy to replace the lid switch. Cost should be $20. to $30.
God Bless and Happy New Year.
Dec 31, 2007 | Whirlpool LSR6334LQ Top Load Washer
Washer only fills
it sounds as if its your lid switch. on some top load whirlpool washer it will fill even if the lid is open. if you open the control panel and open the jones plug you can check for continuity on the lid switch
Jul 22, 2007 | Whirlpool LSR6334LQ Top Load Washer
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
