Question about Cosco Baby Gear
Cosco Nod-A Way Toddler Bed 10-B01
I cannot find the screws to assemble this bed.
I do not think they make the bed anymore, I bought it about 6 years ago, but love the bed.
How do I assemble a Cosco metal toddler bed Model 10-T-42?
Request assembly instructions from Cosco.
Nov 07, 2017 | Cosco Baby Gear
Dorel #TB-722W
Here is a pdf for a Dorel toddler bed.
It should help you put your one together, even if it isn't exactly the model that you have.
Good Luck
http://www.krenim.org/jeff/WM1646-Dorel-Asia-SRL-Toddler-Bed.pdf
Sep 05, 2012 | Baby Gear
I was given a Nod-a-Way crib (I think Cosco is the manufacturer) that's approx. 20 years old and two of the brackets attaching the metal spring to the frame of the crib are missing. Can't seem to...
I have a nod a way and just gave it to a friend the style was Okla Homer Smith and the manufacter was Dorel Juvenile. My bed was made in 97, Jenny lind style hope this helps.
Sep 06, 2011 | Evenflo Jenny Lind Crib
Jardine Model # DA715BC toddler bed assembly instructions
I have the same crib for my daughter when I went to change it I called the company bc I couldn't find the toddler rails that matched the crib.. They said that it doesn't convert into a toddler bed, just a day bed, and a full-sized bed.. I said NO it's a four in one.. their reply.." yes, a crib, a day bed, a full size bed with foot board, and a full sized without the foot board." I laughed and told them what a joke that was.. So my husband and I took the front off the bed to make it the daybed and went to walmart and bought a toddler bar for like 20 dollars in the baby department. She loves it and it worked for us without having to spend another 150 dollars for a cheap toddler bed.. good luck.. btw this crib has been recalled.. you might want to check it out
Mar 05, 2009 | Baby Gear
Transfer
All you have to do is remove the plastic slider rails on the top and bottom of the front rail and take off the rail. This bed still has 3 rails like a daybed when it is changed into a toddler bed.
Jun 04, 2008 | Cosco 2-in-1 Sleigh 10121 Crib
Convert crib to toddler bed
I finally found my instructions!! It's actually really easy to convert to a toddler bed:
Step one: Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
Step two: Lower the mattress to the lowest setting.
Step three: Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
Step four: You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
That's it.. You've now got a toddler bed!
Apr 26, 2008 | JCPenney All-in-One Nursery Crib
Baby Gear Logo
499 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
