Question about Hotpoint WD52 Front Load Washer / Dryer
Hotpoint WD52 washing machine door not opening
The fuse in my WD52 washing amchine plug blew..stopping the machine mid way in the program...I did not realize the probleam and tried opening the door but it would not. Then i changed the fuse and the washing machine is running fine but the door would not open at end of the program..have tried numerous times. The door is locked and the Door light light is always on when the power is switched on. PLease advice?
Hi when your fuse blew it welded contacts inside door lock mech replace and all will be fine **** it could have been the door lock that blew fuse but check carbons whilst you have top of ALL THIS IS DONE WITH THE PLUG OUT DONT FORGET
Posted on Sep 20, 2007
Hotpoint Aquarius WD63 door won't open
on some hotpoint models you can remove the front kickplate and on there will be a yellow or green plastic pull toggle, pull this and it will bypass your door lock, if your appliance does not have this then you will need to unplug and leave unplugged for 10-15 mins to reset the door lock, you will however more than likely need a new door lock
Apr 07, 2014 | Hotpoint Aquarius WD63 Front Load...
Hi, I have a Hotpoint Aquarius 7kg WDL520 washing machine. I have just went to open the door to hang out a wash I did earlier. The door is locked and no power seems to be in the washing machine as...
Does it have a separate drawer for the detergent and softener? sometimes opening that will unlock the door. It sounds like it was overloaded and blew an interior circut
Oct 21, 2010 | Washing Machines
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
Hotpoint WD52 Washer Dryer - no instructions
Hears what to do..
In your browser bar type in hotpoint user manual
Then click on hotpoint user guides in the drop down list
Then input yor model number in the box, and download to your hard drive or to your computer.
Plz rate my solution.
Thanks.
Jan 10, 2009 | Hotpoint WD52 Front Load Washer / Dryer
Washer door won't open (hotpoint first editon 800)
I have just had exactly the same problem. 10 seconds of washing, fuse blew, replaced it, cycle completed but now the door lock is stuck on. Like you I tried a new cycle but this has done nothing. In the end (and I'm not suggesting that this a remedy to the problem) I unplugged the machine - pulled the door handle til a gap appeared at the top of the door and forced it open by working a pair of scissors in to the gap and pulling. Of course as soon as I shut the door again and turned on the power the lock light came straight back on the and the door was locked tight. Sorry but this is the best I have come up with short of calling some one out.
Aug 13, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint BWD 129
Hi, full manual is here, you have to register but it seems legit, very useful site, hope it helps.
http://dl.owneriq.net/b/ba32d489-448f-4923-9f5f-26806e5b290c.pdf
May 29, 2008 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint WD62
try fuse on plug this may be gone, also the door interlock switch, try a light bang with fist near door catch see if this will do it, what i do suspect is the door inerlock is faulty, this is a safety device which locks the door when machine is in washig/spinning mode it aso stops machine working when you open the door, this is also a safety device, good luck al. xxxx
Jan 13, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD51 fuse issue
is it the motor that got hot?, if so then check the motor carbons for wear, as these heat up when worn, also if the carbons are fine check the pump and filters for blockages, this makes the motor spin while water is still in the machine causing the motor to overheat, and subsequently tripping and blowing the fuses etc hope i have helped a little
Sep 25, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Kenmore elite front loader washing machine
has the fuse blown, if so replace this to ge the machine up and working to start with, set to drain only if you have the option, if the machine empties then the door may open, if its set to spin and the electric trips then there is a motor fault,, not much information given but now you have somewhere to start from
Sep 23, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint WD52 Front Load Washer / Dryer Logo
151 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
