Can not connect to internet with ethernet cable in device manager pci modem is yellow and so is ethernet controller
Your drivers are not installed correctly.
try to install the correct drivers.
Posted on Apr 20, 2009
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
I cannot get internet.th pc sais there is no cable, but it is.what can i do. i even bought a new card ethernet and he sais the same thing.
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps or you could download one
cnetdownload.com on the homepage you will see a search bar type in the ethernet controller freeware you want/need
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html
hope this helps
Jun 25, 2011 | Matsonic MS9317E Motherboard
I think I may have deleted my ethernet controller driver and so my internet does not work... How can I restore tisn since I do not ave access on the internet except by using a different PC
hope this helps
Jun 18, 2011 | Computers & Internet
How i can install ethernet controller
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
hope this helps
Jun 12, 2011 | Computers & Internet
Ethernet controller for msi k9n6sgm-v
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet transceiver, PCI Express bus controller, and embedded memory. With state-of-the-art DSP technology and mixed-mode signal technology, it offers high-speed transmission over CAT 5 UTP cable or CAT 3 UTP (10Mbps only) cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented to provide robust transmission and reception capability at high speeds.
hope this helps
May 25, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Benicia GL8e (Asus IPIBL-LA) motherboard in HP pavilion - need a network driver
hope this helps
May 09, 2011 | Computers & Internet
My mini hp doen't be connected through ethernet cable
you might have to open up your network connections click start control panel network connections look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
hope this helps
Apr 28, 2011 | HEWLETT-PACKARD Hewlett Packard HP Mini...
KV8-X motherboard. I have a network card installed, but I keep getting new hardware found for ethernet. I try to disable the ethernet card via system. I can't connect to internet.
hope this helps
Apr 26, 2011 | AMD ASUS K8V-X (MBASUSK8VX) Motherboard
Dell inspiron 530 ethernet controller driver missing
the driver will be on the disc supplied by your ISP internet service provider
hope this helps
lhope this helps
Apr 02, 2011 | Computers & Internet
Ethernet connection
If you are trying to connect through a modem/router the driver it should have come with a disk provided by your ISP
2112_4-91313.htm
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
hope this helps
Mar 21, 2011 | Asrock K10N78M Motherboard
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
