Question about Canon PowerShot A520 Digital Camera
Lens wont open cannot take photos
The power comes on in the lcd screen it says no image. The lens will not open and Ive changed the batteries and cleared the memory card according to the instruction booklet , still nothing...now what???
  • 1,305 Answers
You have the camera in REVIEW mode... your model either has a a switch on the rear panel to select taking photos OR reviewing. Or it may have a button, but it sounds like yours has the swith type...just flip the switch to the opposite direction and try it... the lens should act normally and allow photos to be taken...LET me know what you find out..
KEN
Posted on May 10, 2009
Lens screen stuck open and no image on LCD view screen.
It is jamming, the only really fix is to have it repaired, that costs a lot and it is sometimes better to just replace the camera.
Mar 15, 2014 | Sony Video Cameras
Fuji Finepix F30 Suddenly takes only all pink screens (no image)
This sounds like one of two problems -
Either an LCD screen problem or a bad CCD sensor.
A LCD screen problem would indicate one of two of the following - it was cracked, or the cable inside is either damaged or moved out of the plug and need to be reseated.
A bad CCD sensor would show a pink screen on cameras, but would also show menus on the screen as well, do you see those? The CCD basically captures the image the lens is seeing and translates it to an image the camera can save. Generally the CCD can not be replaced separately from the lens and will require an entire lens assembly for repair.
Mar 16, 2010 | Fuji FinePix F30 Digital Camera
PROBLEM WITH LENS/ LCD SCREEN
problem with the lens,not with the lcd,the image fomation is bad,so replace the C.C.D
Mar 05, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Lens wont open no image in lcd screen
Time to call for repair. You don't state the manufacturer, but I am sure it can be repaired.
Apr 20, 2009 | Cameras
Camera does not go on
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2009 | Canon PowerShot A520 Digital Camera
Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
BLANK LCD SCREEN
The shutter in the lens is stuck closed. You need to take the camera to a shop where they will replace the lens assembly.
Nov 25, 2006 | Olympus Camedia D-580 / C-460 Digital...
Canon PowerShot A520 Digital Camera Logo
131 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
