Question about Philips Gemini EQ-3000 Band Graphic Equalizer Car Audio Amplifier
How do I hook up my Gemini PVX30 graphic eq. to my Sony AV Amp
Amp is Sony STR-K502P AV AMP
Checked but this hasn't gott a Tape Loop(Tape2)
Connecting a turntable to Sony STR K502P
Use RCA Cables from the TT to the Aux in on the Receiver. You may need to use a pre-amp inline from TT to Receiver.
http://www.bhphotovideo.com/ has a few.
Mar 17, 2014 | Sony STR-DE485 Receiver
How to hook up external equalizer to Sony STR-DA 2000 ES. Equalizer is a Denon
you need a empty in/out tape slot (jacks in back of Sony, if tape deck is connected you can use "Y" connectors) connect jacks to EQ tape in & out.... (press EQ button Bypass)
Nov 13, 2010 | Sony STR-DA2000ES Receiver
How to connect jacks from gemini stereo graphic equalizer eq2010 to harmon kardon avr40
I couldn't find the manual for this receiver, so you may have to adjust some of the terminology below to the labels used on the HK.
Be advised that the engagement of any device in a Tape Monitor loop will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Mon as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? That logical problem also plays into the decision to defeat digital sources if the Tape Mon is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up: Receiver Tape- or VCR Out to the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-In; Receiver Tape- or VCR In from the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-Out.
If you actually want to use an analog recording deck you could place it within the typical Equalizer's own Tape Monitor loop(s). Many have two to facilitate equalized dubbing between decks.
Apr 11, 2010 | Gemini Sound Products EQ-300 Home...
HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
Mar 21, 2010 | Sony STR-DE675 Receiver
Looking to hook up an older model fisher EQ (EQ-961) to a newer Sony amplifier (STR-697).
Typically you would place an EQ or any processor2_bing.gif in a Tape Loop:
MD/Tape (or Video1) Rec/Out to EQ In; EQ Out to MD/Tape Play (or Video1) /In on the amp. Select MD/Tape (or Video1) on the receiver to place the EQ in-line with whatever source you're playing. Use it's ability to modify the sound sparingly.
Be advised, use of an external processor will only work for analog stereo sources and will likely DISable anything digital as soon as you activate the switch that puts it in the signal path.
Feb 23, 2010 | Audio Players & Recorders
Do you have any manuals as to how to hook this up to a sony str av-710 receiver?
Well, since the EQ-0100 is a stereo analog component you will be able to use it only for stereo analog source material. Of course, once it's inside the av-710, you can manipulate the sound digitally for soundfield and such.
Basically, hook it in like a tape deck, say, in Tape Deck 2's circuit. Then, whenever you want to use it inline with stereo source material just select Tape 2 Monitor and it will be placed inline. Be advised, any digital programming you want to hear will probably be muted if you monitor any tape deck. That's pretty much normal.
You can slave an analog deck off the EQ as it has a Tape Record/Monitor loops of its own and facilities for making the EQ be on the Record OR the Playack side of it.
Normally, the receiver's internal volume, eq or effects controls will not affect the analog loop out to the EQ-100 or attached decks, BUT, this receiver sends processed effects out to Tape Deck 2, if you should desire to record them (page 29 of the manual). Other REC Out jacks pass conventional UNprocessed sound.
I couldn't find the exact instructions for this model but they all work about the same.
Nov 16, 2009 | AudioSource EQ-100 Home Equalizer
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Will Bose 901 active equialiser connect to SONY AV1100 Receiver
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Mar 29, 2008 | Bose 901 VI Main / Stereo Speaker
Can I still used this equipment
Hi Jerome
You will need either a pre-in pre-out connection on the amp to use, A vcr in/out loop can be used in lieu of a "tape" loop. Or alternatively you can put the EQ in line with the bit of gear you want to EQ. In this day and age, of "many more than stereo" systems, a 2 channel EQ has much less application. Although this seems to "outdate" a piece of gear, most stuff from yesteryear still sounds great, so why stop using it. Good Luck and happy listening. A "FixYa" rating from you would help my profile. I am happy to answer any questions you may still have, put them in here and I shall get back to you.
regards
GRaeme
Jan 21, 2008 | ADC Kentrox SS-315 Home Equalizer
Sherwood 460 equalizer hook up
Connect the EQ to the Sherwood as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop.
The CD player should be connected to the receiver though the CD in's and out's (or if your Sherwood doesn't have a CD in/out, then use AUX or TAPE2).
To hear the EQed signal with all receiver sources (like the CD player) you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Jan 09, 2008 | Audio Players & Recorders
Car Audio & Video Logo
162 people viewed this question
Top Philips Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Philips Car Audio and Video Expert? Answer questions, earn points and help others
