Question about Creda W120VW Front Load Washer
Door can't be opened
Ran through wash cylce unable to open door on this front loader, tried unplugging & re-run cycles, clothes are getting smelly now....Help
  • Anonymous Mar 25, 2014
    tried to run on fast wash again,but door still not opening
  • Anonymous Mar 30, 2014
    the door wont open following the end of a No.7 cylce
    President:
  • 1,294 Answers
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure First disconnect the machine power cable from the wall socket. You should remove machine's top cover and then you will have an access to the door lock unit.
Posted on Sep 21, 2007
6ya staff
SOURCE:
Washer won't work and door is locked shut with clothes inside. Can I get the door open manually?
turn off . turn off power point. Wait 3 minutes then turn on power point. Try blowing on drain pipe then turn dial to spin cycle .
See if water pump is engaged during spin cycle.
Don't know if you can manually open the door
Had a similar problem and found the water pump was not pumping the water out and spin cycle was failing to complete.
Check filter of front loader as well .
Mar 19, 2016 | Washing Machines
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
I have a front loader washer...it was in the middle of the cycle and starting beeping. The dr (door) signal is flashing. Cloths are wet and i can't get any cycle to go now. Any suggestions?
Unplug your machine.
Open the top of the machine.
Open door
Remove the door lock assembly
Check contacts of the door switch.
Replace if faulty or try to clean with electronics cleaning solvent.
Jun 23, 2010 | Frigidaire Affinity ATF6000F Front Load...
Smelly clothes
It is because of the front loading door..
It seals shut - so after you do a load and shut it,, midew forms in certain areas..
Run a white load and use bleach..
After wash - (as all washes) leave the door open..
This might have to be repeted a few times - but it WILL go away..
Remeber to leave the door open after every load..
Have a nice day ;o)
Aug 14, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Apr 09, 2009 | Whirlpool WFC7500VW Washer
Can't Open the Washer Door---Our Clothes are held Hoatage
Check and ensure that the tubes and passages to the water level pressure sensor are not blocked by caked detergent, lint , etc.
( this may have caused the water overflow in the first place)
clean up the internal parts that are wetted by the overflow.
clean the door lock mechanism. ( this normally works on a temperature delay mechanism, if cleaning does not work, replace)
all the above done with the power unplugged and water inlets unplugged , of course
Apr 17, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Creda W120VW Front Load Washer Logo
283 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
matt
matt
jimorris77
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
