Question about Printronix Line Matrix P5210 Printer
Tech menu for hammer phasing
Hammmer phasing is out how do i get into tech menu
  • 628 Answers
You can check the user's manual for the information. Here is the link for downloading:
http://www.printronix.com/products/productmanuals.aspx?id=4108
Posted on Apr 20, 2009
I replaced the shuttle and need to do the phasing adjustment. Can you tell me how?
IMPORTANT The printer must be printing the Phase pattern of “H’s” when the Phasing Value is changed, or the New Phasing Value will not be written into NVRAM. If the value is changed when not printing, the printer will return to its default phasing
value when powered off then back on.
1. Install the ribbon.
2. Load full width (136 column) paper.
3. Power on the printer and set top of form.
4. Press Stop to put the printer into NOT READY mode.
5. Press Scroll + Scroll to unlock the Enter key.
6. Press Scroll + Scroll + Return + Enter to enter the CE Tests menu. (Press all four keys at the same time.)
7. The display will show “SERVICE / PRINTER MECHANISM TESTS”, the first menu item. Press Enter to enter the
mechanism tests menu.
8. Press Scrollor Scrolluntil
“PRINTER MECHANISM TESTS / HAMMER PHASING” is on the display.
9. Press Enter. The printer begins printing all H’s, each line preceded by the phasing index number.
10. Press Return. The display will show
“SERVICE / PRINTER MECHANISM TESTS”.
11. Press Scroll or Scroll until “SERVICE / HAMMER PHASE VALUE” is on the display.
12. Press Enter. The top line of the display will show
“HAMMER PHASE VALUE” and the bottom line will show the current phasing index number.
13. Press Enter. The phasing index (followed by an asterisk) will move up to the top line of the display.
14. Press Scroll or Scroll to increase or decrease the phasing index, then press Enter to activate the value as it prints.
Continue to increase or decrease the phasing index until the pattern of H’s appears.
15. When the print pattern is acceptable, press Stop. Printing stops, and the printer automatically enters the current phase
index value into NVRAM. The display shows “NOT READY”.
16. Press Scroll + Scroll to lock the Enter key.
17. Close the printer cover. Press Start to put the printer into READY mode.
NOTE: If you changed the phasing value, power down the printer, remove the shuttle cover, and write the new phase value on
the aluminum shuttle casting.
Oct 06, 2009 | IBM 6400 Matrix Printer
I have a Bosch brute jackhammer, I need the tool to remove the screw plug and my hammmer motor runs but it dosen't hammer
You can use an adjustable face spanner wrench to remove that cap. I don't remember the pin size but you can measure the holes and get the appropriate size. You can remove the whole plate with the armature by undoing the 4 cap screws. Prior to removing the motor plate you have to remove the handle plate from the axle that goes through the body. Undo the nut that holds the assembly on and slide it off. You can now remove the Armature plate. After removing the cap screws pull the assembly out about 1-2 inches. You will see the wires that go to the field attached to the brush holders. Remove the screw that holds these wires to the brush holders. You can then safely remove the whole assembly. This also makes it easier to remove that cap plug with the spanner wrench, because you can now put the whole assembly in a vise. I always heat around the cap with a torch before doing anything. Then I tap on the plug with a hammer a couple of times and voila it turns alot easier. Corrosion almost always builds up on this cap because of the different metals. (Steel and Aluminum respectfully)
Your hammer may have a broken connecting rod. To inspect this make sure you ping the cylider and body with marks so you line them up the same way. Then remove the 4 cap bolts that hold the cylinder to the body. Remove the cylinder and inspect the hammer cylinder and rod. If the connecting rod is not broken you will have to inspect the gears and pinions to make sure they are ok.
Aug 31, 2009 | Bosch Hammering
Cutler hammer a10ano series a-1 contactor
There should be 2 contactors for forward and reverse. you have to wire them so that the power coming in will switch 2 opposite phases to reverse.
Apr 10, 2009 | Plumbing
Cant get drum off to change rear brakes?? 94 chevy berreta
you can hammer it off but i suggest you use a rubber mallet to break it loose then a pry bar to wiggle it off.
Mar 25, 2009 | 1994 Chevrolet Beretta
Code
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done
This will bypass the video safety.
Thanks for using FixYa - A FixYa rating is appreciated.
Nov 02, 2008 | Phase Linear UDV9010 Car DVD Player
Bosch Jack Hammer
I worked at a tool rental center while I was going to college and learned a great deal about equipment and power requirements for tools. Large electric hammers draw a great deal of amps thus created a problem on construction sites. Bosch and other brands made hammers such as yours that would would work on long extension cords that worked off of special generators such as this one: http://www.southern-tool.com/store/multiquip_gdp-5000h_generator.html . This miltiquip generator has a special outlet for three phase at 230v. Your hammer was probably designed to work on a generator such as this. Hope this helps, enjoy.
Sep 30, 2008 | Drills
Need specifications
hi Laura
see the signs around the operating mode button.Drilling,drilling and hammering,just hammering.Try it and see what happens.
regards savumihai71
Print is clear and fuzzy
I'm sure you have fixed this by now... But solution is...
Check the hammer phasing. Adjust hammer phasing if
necessary.
6. On the control panel, press the = + > keys to unlock the ENTER key.
“ENTER SWITCH UNLOCKED” briefly displays. (If “LOCKED” displays,
simply press = and > again. This is the default key combination. The lock/
unlock key combination can be programmed by the user. If = + > does
not unlock ENTER, get the combination from the user.)
7. Press the ; key. “OFFLINE / DIAGNOSTICS” displays.
8. Press >. “DIAGNOSTICS / Printer Tests” displays.
9. Press >. “Printer Tests / Shift Recycle” displays.
10. Press ; until “Printer Tests / Phase Printer” displays.
11. Press ENTER. The display shows “Printer Tests / Phase Printer” and the
test begins. The current phasing value is printed on the left of the printed
pattern of all H’s. As the pattern prints, compare the H’s to the figure
below. If the phasing needs adjustment, go to step 12. If the phasing is
OK, go to step 15.
12. Press >: The current phase index displays. Press > again: An asterisk (*)
appears next to the phase value.
13. Press < to increase or ; to decrease the phasing index value, then press
ENTER to activate the value as it prints. Continue to increase or decrease
the phasing index until the pattern of H’s is acceptable.
14. Press = twice: “Printer Tests / Phase Printer” displays.
15. Press ENTER to stop the test.
16. Press CLEAR. “OFFLINE / CONFIG. CONTROL” displays.
17. Press = + > (or the key combination set by the user). “ENTER SWITCH
LineMatrix
Sinca Printers, Parts, & Repair
www.sinca.biz
Jun 11, 2008 | Printronix Line Matrix P5215 Printer
Printronix Line Matrix P5210 Printer Logo
179 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
