Question about Raymarine St8002 Smartpilot Autopilot Hydraulic Inboard Pack
Raymarine st8002 wired to furuno
Trying to hook up raymarine st8002 to furuno 1732. need to know if raymarine is compatable to the RS-232 that the furuno puts out of data 3 port. when connected them together the Smartpilot computer went out...was showing "no data" on display ..When i get pilot back i would hate to hook them back together and mess up again.
  • 3 Answers
Seatronix1 is correct use NMEA for the connection. Set your waypoint in the furuno, hit auto on the 8002 then track track. The 8002 will ack with next waypoint at xxxx then hit track again.
Posted on Jun 25, 2009
    Problem Solver:
  • 10 Answers
The st8002 is not compatble with rs232 data. You need to supply it with nmea 0183 data. You will need to wire it to the "NMEA port IN" on the pilot to NMEA out on your Furuno and turn on the mnea sentances "out" on your Furuno. You will need to turn on at least the following sentances GGA GLL RMB RMC.Hope that helps.
Posted on Jun 15, 2009
WHAT TRANSDUCE GOES WITH THE DS600X COLOR ..WHERE CAN I BUY ?
Hi
Airmar makes almost all of the transducers for Raymarine. From the Airmar FAQ section, your unit is listed. See the link below. Pretty much any marine chandler or Raymarine dealer should be able to order it for you.
Hope this helps
-Steve
Airmar FAQ What Airmar transducers are compatible with the Raymarine...
Feb 26, 2015 | Raymarine Ds600x Digital Fishfinder With...
What is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
I'm taking this as you want to send the gps information to your C80 not receive from the C80? If this is the case the brown wire on the garmin is the nmea data out +. The Black wire is considered nmea out neg (-) of the garmin. So hook the garmin brown to the white on the raymarine. Hook the black from the garmin to the green on the raymarine. That means you are outputting lat/long info to the raymarine from the garmin.
Jan 14, 2012 | Raymarine C80 GPS Receiver
Connection to PC for Nav software
Assuming you have GPS input to your 1732 (i.e. GP310/320 sensor), you'll need a 7 pin NMEA data cable (000-154-028) wired to a D-sub 9 pin (serial) plug. The shield goes to pin 5, blue to #3, & white to #2. Jumper pins 7 & 8 together. The 7 pin cable goes to Data port 3 of the 1732.
Jul 12, 2010 | Furuno Navnet 1732 GPS Receiver
Trying to connect a furuno fcv-585 to a raymarine a-65 via nmea with difficulty !!
Just remember this tip Nmea out + goes to NMEA in + and so on. After that you have to make sure the unit is set up to send those sentences and or receive them. Aside from that it should be pretty easy. However if you hook them up wrong you may blow the port (you won't know that you did it either) No smoke no nothing it just wont pass or receive data.
Nov 27, 2009 | Raymarine NMEA 0183 (E55059)
Connect Furuno 1732 to st8002 autopilot
It will handle the voltage. as far as the wiring goes, you'll have to decide which port to use. the wire coloring is different. you'll have to send your nmea out data from port 3 white and shield ( Like you said) to the pilot and receive your heading data from the pilot on port 2.
Apr 11, 2009 | Furuno Navnet 1732 GPS Receiver
Raymarine autopilot swings hard over immediatly i select auto
CHECK RUDDER REFERENCE UNIT FOR CONTINUITY(IT IS A POTMETER) CHECK IF MOTOR IS RUNNING IN THE CORRECT DIRECTION ,CHECK CONNECTION OF RUDDER REF UNIT.
Apr 04, 2009 | Raymarine St8002 Smartpilot Autopilot...
Installing a Raymarine 8002/6001 on my 2005 Sea Ray 270
If you have a basic knowledge of electronics and can follow instructions. It's easy the hardest part is connecting the pump and bleeding the system.
Feb 19, 2009 | Raymarine St8002 Smartpilot Autopilot...
Auto pilot
difficult is it to install Raymarine 8002 autopilot in 270 Sea Ray
Jan 14, 2009 | Raymarine St8002 Smartpilot Autopilot...
Raymarine St8002 Smartpilot Autopilot Hydraulic Inboard Pack Logo
303 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
