Question about Garden
Hi i have inherited a karcher kb9040.it has only been used 4 or 5 times so i dont realy know how it should sound when. water is suplied to it it surges when you pull the trigger you only get the presure of a good hose pipe jet should the motor speed up when trigger is pressed regards ****
  • 374 Answers
Hi there!
when you got as good as pipe pressure,you need to accelerate the speed motor to have a good pressurise water for your purpose,the pressure washer has a surge regulating valve as you trigger water gun the pressure blow up,as long
as you pull the trigger on the pressure build up pressure it has also equipt with pressure switch to regulate pressure and for safety purpose.you can also adjust the nozzle by rotating gradually to slim the pressure water out put.have a nice day,don't forget to rate me.thank's
Posted on Apr 20, 2009
Karcher 360M pressure washer pulsating problem when idleing
unfortunately these little units have this problem commonly, 9 times out of 10 it will be the plastic head or the plastic valve block on the unit will be cracked and leaking slightly... it builds up pressure then leaks out and tries to build up the pressure again and this just reoccurs over and over...
you can get this repaired but is normally about half the cost of a new unit, if the pressure is still okay i would probably recommend just keep using it until it proper dies...
If you do get this fixed, we have studied into this and believe the main cause of heads cracking is warm water say if your inlet hose is in the sun for a period of time this can cause the water to become quite hot or if the unit sits and water trapped inside the head assy freezes can also cause this. Hope this helps Kind Regards Brad
Dec 16, 2009 | Karcher PSI Electric Pressure Washer
I have a 3000 psi karcher pressure washer with honda engine, the problem is for a while the pressure would kick in and out, now only water hose pressure, the water supply is fine, what is the problem
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
Sep 15, 2009 | Karcher G3025OH Pressure Washer
Karcher pressure washer 411A. loss of pressure...
411a when i turn on it gos for 1 min then i have too press it on and off 3or 4 times befor it works and it only stays on for 1 min.
Mar 07, 2009 | Karcher K2.26 Electric Power Washer
Can i covert a acer L100 to a gameing councle and where do i do that thanks
Because the l100 is a mini computer that comes equipt with home basic, i would suggest against it. You realy dont have alot of space to work with, and a small power suply realy limits your options. The first step in making a gaming pc is to get a good video card, and you realy just dont have the space or power. If you want to make a gaming pc, start with a mid size case at minimum, that will give you the room for a good video card (maybe even sli), and a good power supply and cooling mechanism.
Jan 25, 2009 | Computers & Internet
Cold water suply filling up header tank in loft thru hot water suply on shower.
hi did you run a seperate cold water supply from the storage tank to the shower pump & also a seperate hot supply from the hot water cylinder, it sounds as though the cold water is crossing into the hot service & pushing its way up to the tank as its the only way it can go, sounds as though the cold water connection to the shower is not tank fed & possibly directly off the water main.?
Oct 05, 2008 | Home
KARCHER HDS 1000 de
Hi Jim,i have the same unit to,can you tell me are you connecting to mains water via the small black header tank at the back next to the boiler or is it connected straight to the pump head inlet?
Theres more than one reason i'll just start with this one 1st.
chris
Aug 08, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 601c
i don't know what a car boot sale is but sounds as if relief valve is stuck open.if this car boot thing is a car lot they use all kinds of stuff to clean cars in the water they use to wash a car. this washer has probably been let set up without being flushed after use. the problem isn't in the pump most likely but a corroded relief vale. remove and clean.
May 15, 2008 | Karcher 2500 PSI Pressure Washer
Wont heat up
I know that Karchers steam cleaners have had issues with the thermal overload. I have repaired Karcher machines that got turned on with no to little water in the tank and it would heat up really fast and trip the thermal overload. The thermal overload is to reset it self when it cools down but the problem has been the thermal overloads get stuck and dont reset. When they stick, they will give the same signs you have said. In those cases the thermal overload has needed replaced. The thermal overload did its job to trip, but it fails when reseting. I understand you don't want to throw more money into it, but that is the only thing you can do. You can get the part and do it your self, but they are tricky machines to get into and you dont want to break something trying to get in. Hope this helped.
Mar 25, 2008 | Karcher DE4002 Steam Vacuum
No picture or sound
hi guys! i have a tn61x81 and the probleme with this tv is when i plug the tv the tv try to open but shut down y try to push the power botom it's make no difference the light near the power botom is flashing no power no image no sound noting. i think it's the power suply but i'm not realy shure. if aneyone can help me it will be realy apreciate.
Oct 29, 2007 | Toshiba TN61X81 61" Rear Projection...
Inherited coffee maker I have a Faberware ?138? Automatic Peculating Coffee Maker I inherited from my Grandparents. It's in great shape but I have no idea how old it is. It's a great little unit, but...
There realy not much of a manual for this type of coffee maker. put water in to water line, put coffee in the metal basket, put the lid on the metal basket, put lid on the coffee maker, set it on the stove until it starts peculating let do it for 10-min then stop.
Sep 06, 2006 | Faberware FCP412 Coffee Maker
Garden Logo
269 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
