Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Convergence board New board was replaced but the blue is to far out causing the tv to shut down. The mute-1-8-3 wont respond to ajustment. Should I buy a new board and start over?
    President:
  • 4,402 Answers
If the blue is too far out you will need to manually adjust these if you never did this before you could make a real mess, suggest calling a tech.
Posted on Dec 18, 2007
6ya staff
SOURCE:
What causes a Blue Vertical Stripe on left side
Can be the t con board or the lcd panel. its only possible to finalise by replacing the t con board. Before going for a new t con board try to check the connections from t con to lcd panel. if its possible remove and reconnect it. sometime bad contact can cause such problems. Also added a link which would be help full for you.
http://electro-medical.blogspot.in/2015/11/lcd-tv-t-con-board-troubleshooting.html
Nov 09, 2015 | JVC Emerald EM37T 37" 720p LED-LCD TV -...
Phillips flat screen has a vertical blue line, about 2inches wide, running from from the top to about a third down the 52 inch screen. What causes this
Take ur hand and pushes all around the tv frame bazel see if the veritical blue line react like flashes or lighter or darker,than this tv can not be repair at all because the LCD screen itself it is the caused,the LCD screen cost same as a new tv if it is require to be replace.If there are no reaction of the blue line at all than ur tv have a circuit board problem.The T-CON board is dying,this board sit in the middle bottom of the LCD screen,must be replaced will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-Con board for the replacement.
Aug 04, 2013 | Vizio Gallevia GV42LF 42 in. LCD...
My Coby 40 inch HDTV wont turn on. The blue light on front (standby?) is on but I can't turn it on. Help I don't wanna buy a new tv
I had a 32" Coby that did the same thing, turned out to be a defective main board. The main board wasn't sending the 3.3v signal to wake up the power supply. In my case I sold the tv for parts because it wasn't cost effective to replace the main board. It sound like your main board
Apr 10, 2012 | Coby Televison & Video
My proscan 42la45h wont get power. no red or blue light
U check the power source like the power a/c outlet?Yes?Tries tv unplug,replug it back like about an hour later.The tv should resetting itself back to the tv factory setting,tv now should have power again.Not.The tv have a power supply board problems and the causes.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 06, 2011 | Proscan 42LA45H 42 in. LCD TV
The tv shuts shuts off by itself and wont come back on until next day, do you know what causes this
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Aug 06, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
When we turn on tv it shut down right away we think it could be the lamp light what else can it be?
Try muting the sound on the tv, if it is a loose circuit the sound vibration can jiggle a connection and cause the tv to turn off as apart of its safety feature.
if the tv functions correctly while in mute then you now know it is a loose circuit.
if the tv continues to turn off even while in mute it is shutting down by the main power stand by safety feature, it may need a new main transformer.
if the muted sound solved the problem then unplug the tv and look in the back for the main transformer, the manufacturer usually places the main board on the box of the main speaker, the speaker could be vibrating a circuit loose from direct contact, the main transformer is heavy and would cause issues over the long run with high fadelity sound systems on big screen tv's. check solder points on main board.
Oct 04, 2009 | Hitachi 51F59 51" HDTV Projection...
TV on/off button keeps blinking/TV won't turn on
Oct 04, 2009 | Toshiba Televison & Video
Certain buttons wont respond
I had a Sony remote that got dropped. Looked inside and found the circuit board broken. The ideal solution is to by a direct replacement--expensive. I had an amplifier remote with learning and lots of buttons. The cheapest ($10-$15) is to buy a universal remote, hopefully with a learning function in case you need to get more that just the numbers, volume, mute, and up/down. They may not know how to change source, TV/VCR, menu, etc. Most will know how to do Sony while many will not know off brands. -Ken
Aug 29, 2009 | Sony RM-Y173 Remote Control
Green & Blue Ghosting Convergance problem
Odds are real good that the cooling fluid in the green and blue picture tube assemblies has become contaminated. You can tell by looking down into the lenses with a flash light. Funny thing is the red never gets contaminated because whatever organism is causing the problem can't survive in red light. BTW this may still not solve all of your convergence problems but when the colors are so badly diffused the convergence sensors for flash focus can't lock onto the beam landing.
Jun 01, 2009 | Samsung HCL473W 47" Rear Projection...
Blue color
as far as alge ...i cant comment on that. it just sound like your blue tube has quit altogther/...yes they can be quite expesive..however it could be crt board..maybe...buy you a new one...LOL
Dec 06, 2007 | Akai PTH5498 54" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
Jerry Greenberg
Jerry Greenberg
Ekse
