Question about Invacare Pronto M51 Power Wheelchair
Clicking I tried to take the Pronto m51 over a step that was too high. I held the joystick forward to try to go over the step, but couldn;t get over it. I heard a scraping noise thay I thought was the bottom of the chair trying to go over the step. We were able to get it over the step by lifting it, but now it makes a loud clicking noise when I touch the joystick. It's coming from the base of the chair. It happens when I move the joystick or if I tap it. The chair is still working.
  • 1 more comment
  • jmholzwart Apr 20, 2009
    Could I have damaged something when I held the joystick forward and was stuck on the step? I'm not sure of the model but it is about 3 years old.
    Can I disassemble the base myself?
    Thanks for your help. I'll call for service.
  • 10,515 Answers
Hi jmholzwart,
It seems that there has been a damage to few of the cables.There are always few unshielded cables in most of the motorized Invacare wheelchairs.
The only fix is to disamble the machine and then you need to fix the cables.This problem occurs when you use joystick or if you tap it. Because all the movement of the wheelchair is maintained by a set of cables.Any damage to that would cause a loud noise and later on you might face an issue with the movement of the chair ( if the cables are seriously damaged ).
I hope the above solution would be able to assist you in fixing the problem.
Thanks for using Fixya.
Do rate the solution as '"Fixya" if 100% satisfied.
Posted on Apr 20, 2009
  • taran_2005
    taran_2005 Apr 20, 2009
    Hi Jmholzwart,
    Though i love people who love to fix the problem yourself. However, in this case i would not recommend. While trying to fix that, even if there is more damage to the cables, it might make your wheelchair unusable.
    I would advise you to look for local tech to fix the fault for you.
    I hope you do agree to spend 50 bucks rather than trying to fix yourself and in the end losing more than 100 bucks,
    Do rate the solution as 'Fixya' if 100% satisfied.
  • 175 Answers
Powerchairs have electric brakes on the motor drives that automatically engage and disengage when the joystick is activated, or released. A solenoid "clicks-in" releasing the brake, then clicks back to lock the brake. This clicking should have been noticeable before you tried the bump, and it is normal. If it is clicking while the chair is in motion, this is a whole different animal. It could be caused by damage to the gear assembly, or to the electric motor, or to the coupler which connects the two. In this case, you should refer it to a qualified technicial for repair.
Usually, scraping the motor/gear assembly won't cause damage, unless you whack it real hard cracking the gear casing, the frame holding the assembly onto the chair, or bending an axle or wheel.
Posted on Jul 07, 2009
    Brigadier General:
  • 3,917 Answers
Hi
There are a few problems faced with the model of your chair. Please find the resolutions for the most common ones at:
http://www.usatechguide.org/itemreview.php?itemid=668
It shouldn't be making the noise unless you have the QLogic Controller that can make beeps when you move to a fuction.
Thanks
  • e-Guru
    e-Guru Apr 20, 2009
    No not necessarily there has to be some parts broken. Sometimes due to vibration such noise does happen.
    Please try some different places to work with the chair.
How do I adjust the seat height on a Pronto M51 with SPJ+ Joystick
The seat height can be adjusted by removing the seat and raising up the 4 seat pillars on the bottom frame. With the pivot seat model you can raise the center post seat pillar.
Feb 12, 2014 | Invacare Pronto M51 Power Wheelchair
When operating the Pronto M51 power wheelchair with the joystick, it will only move forward and backward. It will not turn. What do you think the problem is?
I would suggest that the micro switches that the joy stick operate have become faulty or got out of adjustment. contact the makers service agent to fix the problem
Sep 23, 2013 | Invacare Pronto M51 Power Wheelchair
Locking a power chair
turn off, press and hold on button til it beeps, push and hold joystick forward til it beeps, pull and hold joystick til it beeps, it is now locked... repeat to unlock
Nov 12, 2012 | Invacare Pronto M51 Power Wheelchair
My pronto m51 sure step service light is flashing seven time and it will only turn to the right
sarah check the joystick cable try unplugging it from the rear of the joystick and plugging it back in then unplug it at the back of the chair and plug it back then turn the chair on to see if you are still getting 7 flashes. If you are then you have one of 2 problems the joystick cable somehow is bad or the joystick itself has got a problem try the cables first to see if it fixes the problem If Medicare paid for the chair then they will pay for most of the repair Contact Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Apr 02, 2011 | Invacare Health & Beauty
Invacare pronto m51 moving very slow. moves free and easy when in neutral
Check that the speed control on your joystick is set to high. If it is then you probably have a battery problem. Even with all the lights lit on the joystick you can have one battery of the two on the chair that is not charging fully. This will cause the M51 to creep and not work correctly
Aug 11, 2010 | Invacare Supply Group Invacare Pronto M51...
My hand control is locked how do I unlock it
Hi. The answer depends on what brand of controller you have, Dynamic or VSI.
Try this.
Push on button to turn on machine.
Push the joystick to full forward until it beeps.
Pull joystick to full reverse until it beeps.
Release the joystick. There will be a long beep.
It should now be unlocked.
Hope this helps. Neil.
Jun 26, 2010 | Invacare Pronto M51 Power Wheelchair
The charge indicator lights flash left to right..when moving joystick the chair does not move.
chair is locked out. turn on then push joystick forward till it beeps then pull backward till it beeps then it is unlocked
Jun 15, 2010 | Invacare Pronto M51 Power Wheelchair
The electric wheelchair is flashing the locked symbol but we don't know how to unlock it so that it will work
Turn on chair, move joystick forward till it beeps, then all the way back till it beeps, and then let go of joystick, it should fire up.
May 20, 2010 | Invacare Pronto M51 Power Wheelchair
Control box on pronto m51 wheelchair don;t work
When you say "control box" I assume that you mean the joystick. If there is no power to the joystick be sure that the batteries are fully charged and be sure that they do not need to be replaced, also be sure that the cables were not put on wrong. If all that checks out then be sure that all the cables are tight.
If all these do not solve the problem then you need to have the joystick tested.
Oct 17, 2009 | Invacare Pronto M51 Power Wheelchair
Invacare Pronto M51 Power Wheelchair Logo
148 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
