Question about Indesit Washing Machines
Indesit wil 1635, not emptying water. half way through cycle it stop and three green and a red light flash.
  • lmalcolm15 Apr 23, 2009
    It was a heater relay wire.
    Problem Solver:
  • 3 Answers
Its your fillter that wants emtying
Posted on Apr 21, 2009
Indesit dishwasher idl40 s I have lights 1 and 3 flashing after shortly staring it's cycle. Then it empties and stops but there is no water hardly when I open the door. Any ideas please??
It would appear that the washer is not getting water, though it could be aborting the cycle early for some reason.
Try to google "Indesit dishwasher idl40s lights 1 & 3 flashing", and various permutations to see what others have said. At the least you need to understand what that pattern of lights flashing means.
There is an electric valve that the washer controls to allow it to fill with water when needed. This may be clogged or may have failed.
Pursue the flashing light issue first so you understand what the washer is complaining about.
Pete
Aug 30, 2015 | Indesit Dishwashers
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
I have an indesit wil133 .when one wash finished,the red flashing light came on ,so i could open the door,but also the delay timer & stain remover lights were flashing. now when i try to put another...
I would go to the manufactures website and download the user guide and look in the trouble shooting guide or I would check the water pump to see f there's not an obstruction in the pump preventing the pump from emptying the drum completely as if the water sensor is not telling the machine its empty therefore it cant start again
Jan 17, 2018 | Indesit W 123 Front Load Washer
My Indesit Moon 1400 has stopped working. Shortly after the cycle starts the blue LED lights at start and 40 deg flash rapidly. Washing inside machine is soaking wet but has neither washed nor spinned. ANy...
Tom, I'm having exactly the same problem, Have you managed to solve it? The Service center will no even tell me what's wrong with (they're quite keen to get me to arrange a visit from their engineer for £110 though). Thanks
Jan 30, 2010 | Indesit W 123 Front Load Washer
Indesit washer wil 103
Check your water inlet valves. Seems like the valves have went away. Also check the computer board and inline fuse to make sure everything is correct. Inlet valve are located behind the supply line hoses. Please rate. Thank you
Feb 14, 2009 | Indesit W 123 Front Load Washer
Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Jan 04, 2008 | Indesit W 123 Front Load Washer
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Sep 23, 2007 | Indesit 24 in. DI67 Free-standing...
Washing Machines Logo
262 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
