Question about Garden
Oil leaking from pump
I have a 10 year old Generic pressure washer - 2000 psi. It gets maybe 3-4 hours use each year. On top of the pump is what looks like some sort of brass pressure relief port. This past weekend I noticed a mix of oil and water spraying out from this port. I shutdown the machine immediately and checked the engine oil level (which looked fine). Quite a bit of oil spilled out onto my driveway. I really do not know if this was engine oil or pump oil that was leaking. Can anyone please explain what may have happened and what my options are? Thank you in advance for your assistance. Mark
  • mjh8666 Apr 21, 2009
    Thank you Bill for the feedback. What I subsequently discovered is that this pump has a history of this exact failure. Apparently the plating on the pistons have failed and rust has developed on the pistons as the washer sits in my garage all winter long. As I start up each spring the rust eventually wears away at the oil seals, causing a rush of high pressure water to enter the oil chamber. The chamber fills up until the oil/water spray from the breather vent. This issue combined with the intermittent issues with the high/low pressure regulator has caused me to decide to replace the pump with a quality pump that has brass water manifold and ceramic coated pistons. Thank you again for the timely information. FYI - my pressure washer is a Generac 1292.
  • 10 Answers
Top is a breather you may be overfull of oil most pumps you can use engine oil .drain and put in half litre or if it has a sight glass top up to low side of glass and try it out.possible your seals on way out this usually then leaks at front or gets water in.if you still have good pressure oil seals easy to do.
Posted on Apr 21, 2009
I have a 3000 psi pressure washer and I am trying to find out of the pump need the oil changed or not. If it does how would you do it ?
If the oil is based on zinc-free hydraulic ( there could be also used demolition hammeroil) sometimes the price is very high and the material is metal aluminium/if there is no oil watchglass then its filled to last the life of the pump. But if there is a oil plug and a watch glass so you can watch the oil level then most is used normal oil 15w40 / hdx30 Also the pumps what have used normal oil have allways a special doping oil for the first 60 operating hours it is a colored red or white oil but do not left it longer in the engine than the max 60 hours its can build an incredibal pressure and you should surprised by removing the filling cap,,, So be aware of the pressure and a short but unexpectedly oil gusher . then its mostly to late I've experienced it at a Kraenzle 1150 pressure cleaner was last the first oil in it for 3 years hihiii. but 3 new oil seals and for the using time 15W40 then thats lasting for lifetime , the most pumps of pressure washers are build with a one-time filled long lasting oil for shure if the pump is made on the bottom side of the washer then in the most cases is it long lasting oil for the lifetime. not neccesary to change it.
Jul 29, 2015 | Psi Garden
Got a Dewalt 3800 PSI Pressure Washer with 4.0 GPM with a Honda GX 390 gas engine. Tipped it up to roll it out to my truck and got a big puddle of water with what looked like Pump oil in the puddle. Can...
Could very well be. Did you check the oil level and condition of oil? If its too full or if its light brown milky, then water has entered crankcase. Pressure washer pumps cannot stand to ever let run dry. Even a little. Also excessive idling will overheat pump if it doesn't have a thermostatic relief valve that allows some more cool water to enter pump.If it doesn't have one add one. Find your PUMP mfg and model number. IF it's pumping good now and no leaks, quick replacing the seals will save big future repairs. www.pressure-washer-parts.com has lots of info on many pump manufactures. Or get some seals from dewalt.
Aug 11, 2010 | Dewalt 3800 PSI Pressure Washer
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
We have a leak on the pump around the manafold and the gearbox. Has anyone had this problem that you know of? Could it be that the packing has gone out? The washer is 2 to 3 years old and runs great just...
Usually when water is leaking from in between the manifold and the oil side of the pump, the high and low pressure seals (a.k.a. packings) are worn out.
Dec 17, 2009 | Northstar Pressure Washer 3000 PSI
Excell VR2522 Pressure washer - sudden loss in pressure.
Leaving the engine running for more than two minutes without releasing pressure trigger causes aluminum pump to overheat and causing damage to the purmp, resulting in sudden low pressure. (see page 9 in manual)
Jun 18, 2009 | Karcher 2500 PSI Pressure Washer
Pump oil leak where pump connects to engine
With that few hours, you need to return it as the seal shouldn't leak. Probably was improper pump assembly, so you should take it back, because it will only get worse and fail. Hope this helps you, Rick
May 04, 2009 | Northstar Pressure Washer 3000 PSI
Engine won't turn over
Pull the spark plug back out and try to turn the engine over. If it doesn't move then the engine is probable seized. Was the engine oil res. full of oil and was the color acceptable.
Apr 28, 2009 | Karcher 2500 PSI Pressure Washer
I have had two dewalt pressure washers in the last year. Both ended up having major oil leaks. I have read the instructions over and over and find nothing that I am doing wrong. Now on my 3750, dewalt is...
First off are you taking it to a factory owned or an authorized service center? There is a big difference in the quality of service that you receive. A lot of times DeWALT gets a bad rap because of poor service from authorized service centers. IF you take it to a DeWALT owned center they have guaranteed repair cost and will take good care of you. Next question how old are these units? Where is the leak? How often are you using them-ie how many hours per day, week....Also the oil leak is it in the engine or pump? Neither of those are manufactured by DeWALT they buy the engine from Honda and the pump on yours should be a general-so how could that be DeWALTS fault?
Mar 24, 2009 | Dewalt 3800 PSI Pressure Washer
Honda 2750i Powerwasher
I had the same problem 3 years old, maybe used 10 times - removed the air filter and the washer started fine. The air filter looked fine - I have not tried to replace it or figure out the root cause. I was just happy to get it running again :)
Aug 09, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
1,500 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
