Question about Zyxel Prestige 334W Wireless Router (WYP334WZYXEL)
Wireless connection working but no data transfer
I installed a ZyXEL 802.11g wireless USB Adapter G-220 v2 with all the software on my desktop. When I select my home network and key in the encryption wep-key I get an good signal strength (7/10) and an excellent link quality (9/10) reading. However, there does not seem to be a transfer of data and I can not start my web browser. Other wireless computers in my house work fine so I assume there is something wrong in the settings. Can you help? Thanks!
SOURCE: zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Posted on Jan 11, 2008
SOURCE: Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Posted on Apr 30, 2008
HAAi
  • 77 Answers
SOURCE: ZyXel P660HW-T1 ... Problem bridging 2 wirless adsl routers
What do you mean by "wireless bridging"? Does it mean wirelessly connecting both routers? (ex. Zyxel is at location A and Micronet ais at Location B and you'll wirelessly connect them). If this is what you mean, then it might not be possible since those are two different brands and possibility is that they will not work with each other when they're wirelessly connected unless one or both routers have the capability to do so.
Posted on May 09, 2008
rahul26485
  • 611 Answers
SOURCE: WEP key for ZyAir B-2000
go to the web page of the router default ip address is 192.168.1.1 and user name is admin and password is 1234. after then go to the wireless option in that seciurty option is there in that u get the wep in that you can get the password you change it that's all
Posted on May 05, 2009
anandg27
  • 1272 Answers
SOURCE: Losing connection to wireless router everytime rebooting
It seems that you have windows XP on this computer. Follow the steps below;
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 14, 2009
I dont have the installation disc to install zyxel G-220 v3 wireless USB drive onto my computer, and I can not find it on the zyxel's support and download library. where can I find this software online and...
You can download the software from http://verizon.net/zyxel There are 3 folders, one for Windows XP, one Windows Vista, and one for Windows 7. You can extract the folder you need for the version of Windows you have. Then you can use the Found New Hardware Wizard to install the drivers.
Jan 21, 2011 | Zyxel G-220 802.11g/b Wireless Adapter
Can not install ZyXEL G-220 driver
I use 1 of these, not had any problems.
Uninstall any previous software for it, make sure you have the correct drivers, plug the adapter in, go to device manager, uninstall the adapter, and when it goes to re install stop it and force it to load the new drivers you have downloaded...
Jul 18, 2010 | Zyxel G-220 802.11g/b Wireless Adapter
Zyxel model G-220 v2 usb wireless adapter won't connect
If you are trying to connect a computer wireless card to a wireless router then follow my instruction on how to configure the wireless router and the wireless card in the computer - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 14, 2009 | Zyxel Computers & Internet
No internet service
the wireless adapter needs to connect to a wireless router which then connects to the internet.
it's the router that is connected to the internet and shares it in your home network.
Dec 20, 2008 | Zyxel G-220 802.11g/b Wireless Adapter
Zyxel Zyair B-220 802.11B Wireless Adapter
This will be happening because of a driver conflict. Uninstall all drivers to do with adapter, then re- install your Zyair software and then plug in your adapter, but force windows to look where you have downloaded the driver in other words not automatically install but manually when the option pops up. It may be you have to connect your adapter first then install drivers.
Dec 10, 2006 | Zyxel ZyAIR B-220 802.11b (91-005-020003)...
Computers & Internet Logo
374 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
