32 in RCA turns on and off
Rca 32in" tv turns on and off and on and off ect... then when it does stay on it does a channel search over and over. Then it will let me watch tv for about 5 mins and starts the process all over again. picture and sound are fine. Just wont stay on! Can you help?
  • 2 more comments
  • etcperiod Apr 19, 2008
    tv is great ...shuts off for awhile then tures on ...perfect picture...no searching...if tv is on and I shut it off , it will go on by itself after awhile.
  • shoneyblue Aug 22, 2008
    green power light flashing; no picture. before this tv was cutting off and on by itself.
  • paul16777216 Dec 31, 2008
    Mine randomly turns on/off and sometimes it stays on just fine but the buttons are scrambled for example I must press vol+or vol- to turn it on or off.
    This makes it annoying to turn the volume up or down as I have to hold the button down to get to the volume I want then press it again to turn the tv back on.
    And, this is using the remote or the front panel buttons.
  • Anonymous Jan 15, 2009
    I have the same problem with a Samsung Slimfit 30 inch. I called costumer service and they told me I have to pay from my pocket to fix it. I'm gonna wait and see how much it will cost, but one thing is for sure: I will never buy a Samsung product again.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Your problem is in system control section or there might be a problem of loose connection in system control.
Posted on Sep 21, 2007
SOURCE:
Rca 32in TV Product serial#f483ceok5 RCA 32in
try unplugging the tv from all imputs and power and let set over night then plug everything back in.
Feb 10, 2011 | RCA TruFlat 27F520T 27" TV
DIRECT TV REMOTE WON"T WORK WITH MY RCA 32in LCD
if you want to use a single remote, try buying a learning remote
Aug 13, 2009 | iLO 3200 32 in. LCD Television
Activate RCA Universel Remote with Ascent
this may work for all universal remotes, im using the philips SRU3003/27 universal remote. it doesnt contain a code for my t.v., however after searching the internet n all that. i was able to program my tv. and heres how 1: Manually turn on ur tv 2:hold setup untill red indicator stays on and release button 3: press and quickly release what you wanna program (i.e tv,vcr,ect.) 4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again. 5: press and release MUTE to install the code. i hope this helps for all those who have had to deal with these nice but annoying tv.s
Dec 05, 2008 | Televison & Video
32in. rca lcd tv GOES BLACK
this is the conversion IC chip , it needs to be replaced
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
RCA TV F32650 32in
The colour is set through the hidden service menu. This web page has detailed explanations of how to access and use the service feature http://www.artofhacking.com/files/TVMODES.TXT
May 16, 2008 | RCA F32650 32" TV
RCA 32" wont turn on
It sounds like you may have a bad Horizontal Output Transistor (HOT) and/or a bad Flyback Transformer. The set is trying to start as indicated by the flashing light, but an internal fault is shutting it down right away. It could also be the Power Supply circuit. A 32in. set is not cheap to replace so it may be worth finding a repair technitian and at least getting a quote. The Flyback is the most expensive part, the others are minimal. If it is one of the above problems it could easily be repaired by a qualified technitian.
Mar 11, 2008 | RCA F32650 32" TV
Please help me
I bought one too! It failed in 6mos. I sent the $ and returned the bad one for another of the same "no choice". Now they suddenly "lost" my replacement. Fix that, haha. Do you have a fax# for RCA?
Please help me.
Dec 12, 2007 | RCA L32W11 32 in. HD-Ready LCD Television
Programming my rca universal remote for basic cable the stations wont turn
I can only suggest that you Double check you have the connections correctly set ie. coax ariel to ,(dvd /digi box reciever ect...)
Also check again (& i know this is state the obvious)
your tv manual. IF you havent a manual do a google search for your tv (make & model) & search for a manual.
Ive have had a simmular experience when programming channels to a Vid-Recorder & when i finished the channels dissapeared.
I realised I didnt have the video set to the correct channel with the tv usually channel 9 or the highest channel on the tv.
So i waisted a good half hour for nothing.
Dec 09, 2007 | RCA Universal Remote Control
Televison & Video Logo
373 people viewed this question
Top Televison & Video Experts
Ekse
