Question about RCA 25202RE3 Corded Phone
HELP.... My boss just got this phone its BRAND NEW but when i plug it in it turns on fine but there is no dial tone, I have 2 lines in one and i have it all plugged in right. What am i doing wrong?
    Problem Solver:
  • 9 Answers
Check the power or battery of this phone. and make sure the tel jack is wire up for 2 line phone,if you using 2 dial tone from carrier.
Posted on Sep 21, 2007
Good day to you...my handset #2 is not working at all....not even dial tone. can you please assist me since i don't have my manual?
As Silly as it sound's ensure device is plugged in to the wall and the power is on.If both of these are ok start by a process of elimination.Disconnect device from the wall and plug into a different wall socket in a different room. If there is no change ensure land lines in your immediate area are other wise ok by asking your neighbour if their land line is on.If so ask if you can connect your unit into their phone line and wall unit.If u still aren't getting dial tone your phone unit is stuffed. If it is a brand new unit you may need to register it to the mother unit.If it a battery powered mobile it may be a flat battery or the battery has burnt out.
If hand set one works fine but not #2 after all this I would suggest you need to replace it.
Hope this helps.
Aug 13, 2010 | GE 27934GE1 Twin Cordless Phone
Fax wont' go through. Plugged phone jack into phone line and when I try to fax it doesn't connect. Any suggestions? Thanks
Can you receive any faxes. Run a Fax Test from the Tools menu. Is the problem with only one fax receipient? (Check the phone number and make sure they are set to receive. I have dealt with one fax receipient where the call-waiting service caught the fax call.)
Does the Fax see a dial tone? If there is no dial tone, use a single line phone (corded) to listen for a dial tone at that jack. If there is no dial tone, check the incoming service for a dial tone. (If you have no dial tone at all, contact your service provider.) Try a new phone cable (2-wire RJ-11) Try calling the number from another phone line with the single line phone attached. If the phone doesn't ring with a new cable, check your wiring and then contact your provider. Is the signal analog or digital (the all-in-one is designed for digital)?
Go back through the fax settings and set it as directed in Step 2 here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458259&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3643612 . You need the fax error reporting setting.
Disconnect any items that are plugged into the 2-Ext port.
Try reinitializing the unit. Unplug the power cord with the unit on. Make sure that the phone cord is fully seated in the 1-Line port. Then reconnect the power cord.
Try resetting the all-in-one, this may require 2 people. With the printer on, unplug the power cord and wait at least 20 seconds. Press and hold # and 3 while plugging in the power cord. Release the buttons after the unit starts up.
If none of these steps help the unit may need service.
Jun 27, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
My GE phone 27958 just stopped working. I originally thought the cordless handset needed a new battery, but upon replacement that did not help. I found that the base which is plugged into the land line...
check power ?
Is Ac - DC converter pack plugged into power point ?
Is the DC plug plugged into the phone ?
does power point work ?
Check correct dc voltage being produced from the AC - DC power pack converter ?
Isolate other phones on other extensinos to see if uniden is cause or not of no dial tone.
You may have another phone off hook and phone line has timed out .
Jun 11, 2017 | Uniden Cordless Phone
No dial tone on Uniden Dect 6.0 land line and portable phone
We've had the same problem with our new Uniden phone. Sounds like someone's on the other line - no dial tone and answering machine doesn't work. The telephone line works though because we plugged our old phone in and it works fine. Any solutions anyone?
Jul 17, 2009 | Uniden Lands Phones
No dial tone, just buzzing noise - should be 2 line phone, 1 jack
What you need is a dsl filter since you are working off a splitter. You can usually get these for free from your phone company.
Mar 20, 2009 | Uniden TRU9466 Cordless Phone
No dail tone
Check the cor and cos setting of the phone It shold have the permissions to call outside
Dec 02, 2008 | RCA 25414RE3 Corded Phone
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Dial tone in fax mode
Is the phone wire from the wall jack plugged into the slot in the back of the machine marked "line" and not "phone"?
Nov 14, 2007 | Lexmark X9350 All-In-One InkJet Printer
RCA 25202RE3 Corded Phone Logo
305 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
