Question about Toshiba Satellite M45-S169 Notebook
In kulankendi client, i got socket error 11004. and am using dial up connection, i disable the anti viruss as well as the firewall. please help
Wii system update code error 32007
Error Code: 32007 There was a problem downloading the latest Wii update.
Please check the following:
  1. Our servers may be down temporarily or experiencing a high amount of network traffic, especially after a new update has become available. Wait a few hours and try again. If you are still receiving this error after waiting, check the next steps.
  2. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  3. Does your internet service provider (ISP) require that you log in whenever you wish to use the internet? If so, your ISP may not be compatible with the Wii console. Please contact your ISP for additional information.
If you are still unable to connect, and have waited a few hours, please try the following:
How are you attempting to connect your Wii console online?
    Wireless Router:
  1. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  2. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  3. Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
  4. If you are still receiving this error code, please click here for assistance.
    Nintendo Wi-Fi USB Connector
  1. Does your PC have any security programs (firewall, anti-virus, anti-spyware, anti-adware, etc.) installed? If you are using the Nintendo Wi-Fi USB Connector, and have a software firewall or other computer security program installed on your computer, there may be additional steps you must complete to allow a successful connection.
      "Trusted" Applications:
      If your firewall or PC security program keeps a list of trusted applications (also known as a "trusted zone"), the following programs are installed with the Nintendo Wi-Fi USB Connector, and require internet communications. If prompted by your firewall or PC security program, add these to the list of trusted applications. This information may also apply to certain computer security applications, such as anti-virus, anti-spyware, etc.:
      • Nintendo Wi-Fi Connector USB (NintendoWFCReg.exe)
      • Setup.exe (when installing the USB Connector)
      • SoftAPInstDrv.bin
      • mdriver.exe
  2. If you are using a router, you may need to temporarily disable the router's firewall to allow the Wii console to connect online and receive a system update. Once the update is received, you can turn the firewall back on. For information on locating and disabling your router's firewall, please consult the router's manual or contact the manufacturer of the router.
Jul 28, 2010 | Nintendo Wii Console
Error code 32007
    Wireless Router:
      • SoftAPInstDrv.bin
      • mdriver.exe
May 22, 2010 | Nintendo Wii Console
Error code 32004
Error Code: 32004 Please check the following:
  1. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  2. Ours servers may be trying to handle an unusually high amount of traffic (especially if a new Wii update is available). Please wait a few hours and try the connection again later.
    Wireless Router:
  1. Adjust the Wii's manual settings. Click here for more information.
  2. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  3. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  4. Try temporarily disabling your router's firewall.* Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
  5. If you are still receiving this error code, please click here for assistance.
      • SoftAPInstDrv.bin
      • mdriver.exe
  3. If you are still receiving this error code, please click here for assistance.
*While Nintendo provides this information for our consumers' use, it is up to each consumer to determine what security needs they have for their own networks, and to decide how best to configure their network settings to meet those needs.
May 15, 2010 | Nintendo Wii Console
AppName: msfeedssync.exe, AppVer: 8.0.6001.18702, ModName: user32
Antivirus and firewall prevent msfeedssync to connect.
You can use next 3 solutions (hope this help you):
NOTE: Before using ones of the next 3 solutions. You can test disabling your Anti-virus and check if the error occurs, if yes, then disable you firewall. But only for testing, AFTER test enable both AV and FW and select the solution from above that suits you better.
1. Disable the app:
Run CMD
and type: msfeedssync disable
2. Disable automatic update in IE
Internet Options - Content - Content Advisor -
"Sources” “Configuration” and disable “Search..."
3. Configure your Anti-virus and Firewall.
It depend of your software used, for the firewall you need to allow connections for msfeedssync.exe located in, C:\Windows\System32
Regards
Mar 01, 2010 | Microsoft Windows XP Professional
Am hooking up our Wii to our wireless inter-net, got an error code of 32oo7? Was up.
From Nintendo.com:
Error Code: 32007
  1. Our servers may be experiencing a high amount of traffic with a particul update, especially after a new update has become available. Wait a few hours and try again. If you are still receiving this error after waiting, check the next steps.
  3. Ours servers may be trying to handle an unusually high amount of traffic (especially if a new Wii update is available). Please wait a few hours and try the connection again later.
  4. Does your internet service provider (ISP) require that you log in whenever you wish to use the internet? If so, your ISP may not be compatible with the Wii console. Please contact your ISP for additional information.
    Wireless Router:
      • SoftAPInstDrv.bin
      • mdriver.exe
    • "Trusted" Applications:
  3. If you are still receiving this error code, please click here for more assistance from Nintendo.
Nov 20, 2009 | Nintendo Wii Console
Socket error 11004 !!!!
Hey...I tell you a fact. Outlook is really a nice software for email management but still i am sad that its poor in handling Internet Connections. Actually, all data transfer takes place using SOCKET networking and Outlook is not nicely programmed to work with various kind of internet connections.
So, for the solution of this I suggest you to use MS Office's Outlook which is far better than Window's default OUTLOOK EXPRESS. And surely your emails will be processed in better way then.
Rate this solution if it was helpful to you...
With Regards,
Shyny
Jun 20, 2009 | Dell Inspiron 6400 Notebook
Socket error 11004
This is a common problem and there are numerous references to it on the Web:
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rls=GWYA,GWYA:2008-31,GWYA:en&q=%22socket+error+11004%22
Just find one that makes sense to your level of understanding- like I have to do :-(
Aug 27, 2008 | Dell Inspiron 6400 Notebook
Socket error 11004
socket error 11004 is totally related to absence of required parameters of a internet dependent application. It can be caused by firewall/security settings. So you may review your settings and also reset or disable the firewall. Please post the details of application that you are using that causes socket error 11004?
Feb 01, 2008 | Toshiba Satellite M45-S169 Notebook
Toshiba Satellite M45-S169 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
