Question about Electrical Supplies
We have a Honda GX120 engine attached to a 2'' water pump used to pump out the holding tanks of boats. For a while now when we start it will run for about a minute, start running rough and then stall out. It can be restarted again, right away, and the same thing will happen. We have installed a new filter in the tank, replaced the carburetor, removed the head to clean and inspect the valves (they look great) reassembled everything and the same problem exist. I don't know where to go from here. This problem started out slow and has gotten progressively worse to where it is today. After a few starts the spark plug is fouled black like it may be running too rich.
    Scholar:
  • 79 Answers
The one thing you did not mention was the type of spark your recieving at the spark plug. I recommend that a spark tester be used, which can be purchased at an auto parts store. Set the spark plug tester gap for 10,000 volts, or a good 3/8". You should see a nice sharp blue spark. If you are recieving this kind of spark, then with valves closed or at top dead center apply 30 psi into the cylinder. This test will let you know if the valves are seated properly. If valves are not seated properly you will hear the air come out from the intake or exhaust. So, it is either your ingnition coils or warped valves.
Posted on May 07, 2009
I was running in a tank my new 5 HP honda 4 stroke and it quit pumping water...and the water is well above the cavitation plate.There was a stream coming out higher up when I started it.
Many manufacturers recommend removing the propeller to tank test small motors the small stream above is what is called a tell tale so you know the pump is working .
Aug 13, 2017 | Honda Boating
Alarm warning system on '02 Mercury Mariner 150HP E.F.I.-
Engine tank should be plumb full tight. The engine supplies about 2 lbs pressure through one of the 2 lines going to the boat tank. The other line takes the oil to the engine tank. If that line gets kinked or pinched, the engine tank won't get oil, a check valve lets a little air into it, and the oil pump keeps getting oil. When it goes down just a little, the alarm goes off telling you something is wrong.
Sludge in the boat tank could plug up the pickup screen. I've also seen them plugged up by a foil oil bottle seal carelessly dropped into the tank.
Once you find out why the oil couldn't get there, start the engine with the cowl off and loosen the cap on the engine oil tank until it leaks, then tighten it down and clean up the mess. That tank is normally plumb full tight.
If when the engine is running, you crack the cap on the boat tank, you should hear pressure let off. If the cap leaks, it won't build up pressure. If there is pressure, the oil line is plugged or kinked.
If pressure isn't supplied, the problem would be the crankcase check valve on the engine, lower forward starboard side, with the hose going to it.
hope it helps
Jul 05, 2008 | 2002 Mercury Mariner
Have a 2001 bayloner throphey how much fuel it holds
Are you sure you don't have a 2001 Bayliner Trophy? ;>)
7 gallons, but they come in sizes 17 feet to 31 feet and 125HP to 225HP.
2001 Bayliner Trophy Asking Price: $13,999 OR BEST OFFER Condition: Good. Description Location: Ridgewood, New York Seller's Notes: AWESOME BOAT!! Body Style: Power Boat Length: 21 Hull: FIBERGLASS Class: FISH/SKI BOAT Engine: 2010 Hyundai 150 # Engines: one Fuel Capacity: seven gallons Horsepower: 150 VIN: Request the VIN Seller's Comments Great boat, Lots of storage, 270 hours on motor, Well maintained, Reliable, Great for the lake, Depth/Fish/GPS System, Well equipped, Live well, Pump, Anchor, Seats four, Lots of cabin room, Equipped with toilet.
Easiest way is to run it dry with a 1 gallon portable can on board. Stay close to the marina until main tank runs out, top up with the gallon can, and then go to the marina and fill it up. Whatever it takes minus 1 gallon is the capacity. Then refill that gallon can and log how many miles you do on a full tank. I carry 2 x 6 gallon tanks, I know one tank will take my 95 kilometres (I am in Canada)
Red portable fuel marine tanks hold 6 gallons. The size is marked on it. If you have a fixed tank, they are usually 20 gallons, but to be sure use my method and a fill.
Bayliner Trophy 2002
May 14, 2016 | Cars & Trucks
Replacing the pump
There are only 3 things necessary for ignition.
1. fuel
2. air
3. spark
Use a starting fluid spray directly into air filter.
if engine starts but doesn't run the problem is fuel'
remove the carburetor float bowl and then use a screwdriver to remove the jet locking nut in the tube the bowl nut attaches.
Use a small wire to remove the jet locking nut after it is loose. Then use the wire to remove the jet tube. Tube has several jet ports that should also be cleaned. reassemble. Allow carburetor bowl to refill then crank at full choke position. If the engine starts buy some techron fuel additive from an auto parts store and add 2-4 ounces to the gas for the next 2 tanks. this will completely clean the fuel system.
If engine doesn't start check for spark either using a spark tester or removing the spark plug and holding plug against the engine frame and pulling starter rope if spark is present replace the spark plug and try to restart the engine.
If these steps don't work I would replace the carburetor.
Jun 18, 2014 | Homelite Ut80993 Honda Gas Pressure Washer
Mercury outboard problems
The alarm is the overheat horn. It means that your motor isn't pumping water from the bottom of the leg and through the engine cooling ports. You will see water shooting out the side of the motor when it starts getting hot, and if you're not seeing the water shoot out and the horn is on then chances are the pump impeller on the leg is shot. You should never start a boat motor (outboard or any other type of boat motor) without having it sitting in the water or with a water calliper with a garden hose attached on the lower inlets of the leg. If you run it without water you will melt the rubber impeller and damage the engine if it's run too long without water cooling. Take it in to a qualified tech to replace the impeller.
May 25, 2014 | Boating
Honda gx120 starts runs for 45 secs, cut out then will restart 45
Sounds like fuel starvation. there is a small filter insde the tank. if you take the tank off you will see that where the fuel hose attaches to the tank. this spigot unscrews from the take to reveil the filter.
Hope This helps
Oct 01, 2009 | Karcher 2500 PSI Pressure Washer
40 Hp Johnson outboard motors stalls out after a few minutes running then takes forever to start again
May likely be one of two problems:
1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
Sep 17, 2009 | Boating
Pumped up bulb, never does get firm, engine will run 30 seconds
You need a firm bulb. There is a checkball in the gas coupler. There should also be a float valve in the carburetor. If you have a friend with the same brand of motor (or a boat shop) it is easy to attach your tank to a different motor. If your tank will now give you a firm bulb, the floatvalve in your motor is bad.
If the bulb will not get firm with the test motor its your line. They are not expensive <$20.
Aug 12, 2009 | Boating
Having trouble with my 1974-78 outboard marine engine
Just an idea but your water pump is only rubber and setting for the winter it didnt stick to the sides of where it pumps did it.. sometimes these pumps are tempermental.. you might check your water pump again making sure its pumping right.. is it peeing out the sides good like it is suppose to ? also if its getting hot on top it makes me think the pump is not doing its job right maybe just pumping some.. not enough? just a thought .. thanks Jerry
Apr 27, 2009 | 2004 Mercury Mariner
Honda GX120 engine keeps stalling out
The gx 120 is only 3.5 hp, that's not a lot. For a 2" pump I would want twice that. You could look up engineering specs on other 2" pumps to see what they use. I've seen lawn mowers with more hp.
Apr 19, 2009 | Garden
Electrical Supplies Logo
529 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
