Question about Microsoft Standard Wireless Optical Mouse
Mouse buttons not always detected
Clicks (either on left or right button) are often not detected and multiple clicks are needed before it is detected. I've changed the batteries, but it's still the same. Pressing the 'connect' button on the mouse doesn't help either. I've only had the mouse a few months.
  • pbarnz May 02, 2008
    Same problem
    Scholar:
  • 151 Answers
Clean your mouse with cloth and remove all dirt. Then unplug it and again plug it.
Posted on Sep 25, 2007
  • 35 Answers
Is there any metal (desk) close to the receiver or mouse? This can interfere with reception. Try putting the receiver close to the mouse and see what it does
Posted on Sep 22, 2007
SOURCE:
Tapping on gateway nv 53 trackpad not working
This just happened on my HP2730P. I always used the click on the touchpad, plus used the right click button at the bottom. Yesterday it just decided to stop working and went haywier...it started doing the selecting and dragging while I was moving the mouse around and my left click stopped working. Obviously my enable tap click was already on cuz I used it all the time.
My solution was disabling the buttons under the "buttons" tab. Then my mousepad tap started working again, I regained function in the scrollbar on the mousepad again, and if I need to right click I can use the point stick buttons right above the pad.
OR
Does it start working when you reboot? If so, try changing the "Touchpad Sensitivity" option :)
Jan 24, 2012 | Computers & Internet
When I left click on anythin the mouse almost
Is it an old (as in used a lot) mouse, I had a similar problem a while back and it was down to a worn out micro-switch, it would still work but because something inside had work out it would always double tap.
It may not be the answer to your problem, but at least if you can test another mouse it will rule out any mouse control panel issues
Mar 13, 2010 | Microsoft Wireless Notebook Optical Mouse...
I've got a optical mouse 3000, and a bunch of batteries in the junk drawer, I'm sure at least one of them has good life in them, but the mouse keeps flashing red....also it seems to work when I right...
The red light is connectivity to the dongle on the PC.
Check your mouse settings in Windows for the left mouse button settings.
Does the mouse move on the screen?
You can try reversing the mouse buttons to see if the button is defective. If you swap the buttons and now right mouse clicks do not work, the button is defective.
Nov 29, 2009 | Microsoft Wireless Notebook Optical Mouse...
Mouse keeps double clicking even when I click one time. I've checked in the control panel under the mouse settings and it should be fine where it is at. But 90% of the time when I click an X to close a...
You checked the settings. Most likely the micro-switch in the mouse is "bouncing" which means the output of the switch contains noise that is interpreted as multiple
closures. This means the micro-switch is worn out...
You can reverse the left and right switches in the control panel and if the right button works without adding ghost clicks then you just need to get a new mouse...
Good Luck
Oct 10, 2009 | Computers & Internet
The mouse pad right and left clicks do not always respond
nope! the whole board matrix needs replacing. use a usb mouse
Aug 19, 2009 | Computers & Internet
Both my keyboard mouse buttons act as right clicks
Hi
Access BIOS settings and search for mouse / peripheral settings, you may find one to activate left and right mobo clicks.
Cheers cbacer
Aug 12, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Change mouse clicks
Please click on control panel and click on mouse settings. The first tab would help you to swap the right and the left buttons of a mouse.
Thanks
May 27, 2009 | Computers & Internet
Microsoft Standard Wireless Optical Mouse Logo
103 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
