Question about Samsung SPH-M500 Cellular Phone
Were to find software
Cant backup anything from my phone because dont have disc.
  • 4 Answers
What Timebandit3 means is that there is an option to connect your phone to your PC via the USB cable provided out of the box. Once you connect your cellphone to the computer, it'll pop up a device found wizard and ask if you want to try to find the drivers for it... all options will fail miserably.
BUT, once that is done, keep it connected and flip open your phone. Go to these menu options:
Menu > Tools > Mass Storage > Connect to PC
...and *PoOf* now you are able to transfer your files and mp3s to and from your cellphone from your computer. The driver for the mass storage is initiated through the computer itself.
Have fun!!
SelfXplanatory
<a rel='nofollow' href="http://www.OneNightlife.com" target="_new">OneNightlife.com</a>
Posted on Dec 25, 2007
Dude there is a setting that says connect to pc.
Posted on Dec 04, 2007
SOURCE:
How do I make a recovery disk?
Which operating system ?
there are some you can download
If you computer crashes and your hard drive fails, you can lose a lot of data and spend a great deal of time trying to find all your discs and re installing all of your information.
It can be very difficult to find and re-install your operating system if you do not have the original CDs that came with your computer.
But if you create a recovery CD for your computer, the restore process can be much faster and quite easy.
Put the blank CD in your CD writer.
Click on the Windows Start button.
Click on the Control Panel option.
Click on Backup Your Computer from under the System Maintenance section option.
Click on the Backup Your Computer button on the Backup and Restore menu.
Select your CD drive from the drop-down list and press the Next button.
Click the Start Backup button to begin the backup process.
you might need to use dvd rw depending on the size of the backup
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you dont have a Windows installation disc, cant find your Windows installation disc, or cant access the recovery options provided by your computer manufacturer.
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click Next.
Note If you are using the Windows7 Install DVD then at the Install Now prompt (Do not pick the Install Now option) instead choose the Repair your computer option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that Windows found problems with your computers startup options.
Do you want to apply repairs and restart your computer ?
d) Click Repair and restart and reboot again to the Windows 7 System Repair environment.
e) Click Next at the keyboard selection prompt and when the System Recovery Options screen appears verify that the Use recovery tools that can help fix problems starting Windows is selected.
Note that on your Dual Boot system there now should be only one operating system listed.
Click the Next button.
f) Now from the menu list select the Command Prompt option.
g) At the DOS prompt type the following three commands
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an Eliment not found message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the Startup Repair option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages Windows cannot repair this computer automatically and Startup
Repair cannot repair this computer automatically.
These messages are the result of the radical changes made by removing the other drive.
Ignore the Send/Dont send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Dont send window.
Next click on the View advanced options for system recovery and support option and from the main menu once again click Startup Repair.
This time the repair process may only that a few seconds and when prompted Startup Repair could not detect a problem, click Finish and run the Startup Repair option one more time, click Finish, and then remove the System Repair DVD and click Restart.
Reboot the computer.
http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
vista recovery disk
not longer free
hope this helps
Oct 22, 2012 | Compaq Presario CQ70 Laptop AC Power...
Need step by step instructions on how to save contacts to sim on a nokia n95 with a broken screen phone still turns on but cant see anything
Hi, as the LCD screen of the Nokia N95 is broken, I suggest that you use Nokia PC Suite to backup the Contacts to the Computer.
Please download the Nokia PC Suite from the below link:
http://www.nokiausa.com/get-support-and-software/software/nokia-pc-suites
Apr 13, 2011 | Nokia N95 Cellular Phone
I cant delete contacts from dailled list and cal log
x3 has lots of software bugs, just power off phone , remove battery , repower and try again, if still not working do a factory reset from settings, beware this will delete contacts also, so back up phone memory from memory card option an contacts option and pc suite backup to be on safe side.
dont forget to comment
Dec 22, 2010 | Nokia X3 Cell Phone
Ive lost my pc disc to my phone can i get a replacemant
u dont need the disc.. if u need the software for your phone to work with ur computer try searching ur phone make and model on
mininova.org
Jun 09, 2009 | Samsung SGH-U700 Cellular Phone
Phone memory gets ocupied with something that cant find to delete
First Master Reset like this
Master reset
1) *#7370#, then enter 12345 (This is the default security code unless the user has changed it) and then Yes. The phone then wipes all apps and phonebook contacts on the internal memory.
otherwise upgrade ROM from Nokia the new Rom will fix the issue from www.nokia.com
download the software update utility from nokia and then connect the internet and update ur ROM thru cable supplied with phone u will get all software for backup and drivers from the nokia website
pls rate well for free help !
Apr 15, 2009 | Nokia N81
Cant get my phone to hook up to the computer
maybe the Disc is damaged.
u can download the software from motorola.com
download section.
Feb 12, 2009 | Motorola Mobility KRZR K1m Cellular Phone
I dont have device driver
you can use any third party software (ERD COMMANDER) for your data backup. frist you should backuped your data in any other external hard drive then restore your laptop through system restore wizard.
2 after data backup you have alerady a laptop recovery disc or recovery partition in tour laptop drive through these option i think you should succeed.
Feb 02, 2009 | Microsoft Windows Vista Home Premium with...
My comp wont reconise my phone
u can get it from official website of sonyericsson
Jan 08, 2009 | Sony Ericsson K790i Cellular Phone
I need to format idot have a backup disc
canaria,
u rili nid a backup disc..or simply the operating system itself..coz its not wprth it if u format ur pc but dont have the installer of ur software..and the best u can do is to buy a operating system..but,its cost..especially windows..nut i heard that kinux is free??try to site the web for it and try to download the software..thats all i can advice u..if ur near me,i can help u with that..
Apr 09, 2008 | Computers & Internet
Samsung SPH-M500 Cellular Phone Logo
61 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
