Question about Toshiba TP55H95 55" Rear Projection Television
Convergence how much does it cost to fix a convergence on a toshiba tp55h95
  • Toshiba Master
  • 3,459 Answers
About 35.00 - 70.00 to do it yourself depending on parts.
Posted on Mar 25, 2010
It get no power when i plug it up
If toshiba tp55h95 either google the model number for this or ask me based on what is wrong
Mar 20, 2012 | Toshiba TP55H95 55" Rear Projection...
From looking at the pictures of the problems. it look like I have a convergence issue. what type of cost are involved? Toshiba 65 inch.
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 02, 2011 | Toshiba 65H82 65" Rear Projection...
Focus error 50h81 toshiba red line problem
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or have 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to fix it.To solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 01, 2011 | Toshiba 50H81 50" Rear Projection...
Ihave a toshiba 43 inch hd 2002 rear projection the picture has shiffited to the right can I fix this
This tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows picture or 3D picture? The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,require changing to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 16, 2010 | Toshiba 51H84 51" Rear Projection...
I Have a major convergence problem. It is a 55 inch Toshiba ColorStream Projection TV(tp55h95). It was fine until we moved it into the other room, and now it's like the color is bending at both sides of...
Color arching.... Ahhh Yeah they eventually do that after a few years. Good news is all you need is a screw driver and some of your time and patience.
The color gun is a small box with 3 screws on it. (Blue, Red and Green. Turning the screws (Slightly) on the gun will get rid of the color arching. I had blue arching on a sony 65" Rear projection a year later it was red arching if you leave it long enough it will be arching and in and out flashing of solid color. Whole mind trip you don't want to venture on.......
The box on my sony was in the very front of the tv. I removed the front speaker panels and accessed it very easily. The hardest part is getting the front panel off. Yours may be in the back.
Best regards and Semper Fi...
Aug 06, 2010 | Toshiba TP55H95 55" Rear Projection...
My Toshiba 42H83 (2004) has double (or triple) images. Is this something that can be fixed? Is the repair some sort of lamp? If so, is that an easy fix?
This tv have a problems known as a convergence problems,it dead.The tv convergence booard the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board, must be replaced to solved the tv convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 18, 2010 | Toshiba 42H83 42" Rear Projection...
When I turn my TV on no pic no sound Flashing red light
Look for Loose Solder Connections in and around Deflection PCB, also Check connections at convergence IC's
Dec 15, 2009 | Toshiba TP55H95 55" Rear Projection...
Where can I find a High voltage tripler for this Toshiba TP55H95
Sears Parts Direct claims to have one part number is 24082877
Oct 16, 2009 | Toshiba TP55H95 55" Rear Projection...
Hi I have a toshiba 50h82 tv that is 7 years old with a convergence problem with the red and green lines that is going to cost $400 to fix but now that I am thinking about it before the convergence problem...
You are describing 2 different problems. The convergence problem can be fixed by either resoldering the convergence ICs or replacing them. These ICs cost about $25 each and there are 2. I suspect that the $4oo is for replacing the convergence board. This should not be necessary as the board can be fixed. Also, the brightness problem can be dirty CRTs, dirty mirror or faulty coolant fluid on the CRTs. If the picture was good prior to the convergence problem, the set is probably worth the repair if you can get the board fixed. While the board is being repaired, the service shop should be able to tell whether or not the brightness can be adjusted.
Dan
Oct 12, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba TP55H95 Shutting Off
the power supply board may not be the problem as that only provides the voltages that go to the other areas of the chassis. Where as a manual will explain where the voltages go and what has to happen for the set to start. the power supply could be good but a leaky diode on say the signal board could allow voltages to increase thereby shutting the set down. Unless youre really good at troubleshooting, I would highly recomend getting a manual.
Mar 17, 2008 | Toshiba TP55H95 55" Rear Projection...
Toshiba TP55H95 55" Rear Projection Television Logo
117 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
