Question about Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737
Code E05 Heater will light and run about 30 seconds then shutoff and display code E05.
E05 and E06 is the error codes for a faulty stack flue sensor. try changing the sensor first is the cheapest. if that doesn't work check for corrosion on control board in which case will have to change out board.
Posted on Feb 08, 2012
Review the trouble shooting guides in your owner manual. You will find it says to look at the LEDs on the back of your main control board. They are difficult to see with the board installed, if  you can't identify which LED is lit just remove the 4 small screws at the corners of the board,remove it a see which sensor LED is lit. You can bet it will lead you to an area to investigate, ie temp sensors, air flow sensors, water temp sensor etc. Hope this helps. I'm in the middle of the same troubleshooting process.
Posted on May 31, 2009
Error code e05
Heater or heat sensor problem that has to be tested with a multimeter.
Dec 05, 2017 | Whirlpool Washing Machines
I am getting an error code ags
AGS - Auto Gas Shutoff = Because of a problem sensed, the gas valve is closing, stopping gas supply and hence heater shutoff.
Improper water flow through heater! Check filter, pump, water supply lines, anything that will reduce water flow into heater.
A faulty Pressure Switch may cause this problem as well.
or...
In coming water to heater is over 104┬░
If all is good with the above, replace the AGS Switch.
May 31, 2015 | Jandy Laars LX Pool Heater / 400,000 BTU /...
E05 code
e05 error code means shorted stack flu switch or sensor. oder heaters have the switch, newer heaters have the sensor. make sure you know which one you have before ordering a replacement.
Apr 01, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Service light
open tempereture sensor
Dec 22, 2013 | Pentair Mastertemp Heater
Error code e61
Identification
  • GE dryers use three-character codes that display on LCD screens. Every code starts with "E" and is followed by a two-digit number.
Power Failure
  • When your home loses power, the "E01" error flashes on the screen. Reset the dryer memory by unplugging the device, waiting 30 seconds and plugging it back in. The error code will disappear.
Thermistor Errors
  • Errors "E02," "E03," "E04" and "E05" are thermistor errors. The thermistor, when operating properly, reads the temperature of the dryer. Errors E02 through E05 indicate the thermistor must be replaced.
Effects
  • When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
Control Board Errors The control board sends signals from the controls to the dryer. When this fails, errors "E61," "E80" and "E81" appear. Contact GE service or install a new control board for the dryer
Jan 15, 2013 | Electrolux Dryers
EO5 and Service Heater Light on Pentair Master Temp 400 Nat Gas
check gas pressure and supply if too low heater will soot up and overheat that's the flue sensor if gas ok check burn tubes for obstructions
Sep 02, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
Master temp 400 with E05 error message, already replaced stack flue sensor, thermistor, and igniter. Any suggestions?
I have the same exact problem with this unit. Obviously getting gas to the unit, because it runs and pumps out some serious heat for a short time, but then kicks off. Did anyone ever figure this out or did you buy a new heater? :-)
Feb 25, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
Pentair minimax e05
Try changing the "stack flu sensor". It could be the sensor is bad or the sensor could be detecting a bigger problem. The sensor can not be jumped out.
Apr 04, 2017 | Pentair Minimax NT Heater
E05 error message & Service light on What does this mean? Is it something that can be fixed easily?
E05 is Ignition / Flame Failure in this model.
The most common cause of this is a bad ignitor, but can also be a bad flame sensor or ignition module.
Here is a link to the original manual with a very good service and troubleshooting section to accurately describe how to do this. I will put a simpleanswer on here, but it might be neccessary to do some reading too.
Turn off power to heater.
remove both front doors to compartment
Turn on power to heater.
Make sure the mode is set to pool/spa on.
turn temperature up to desired
within 30 seconds the fan should come on.
once the "thermostat" light comes on in the front LCD then pay attention to the ignitor
The ignitor should now be glowing. (if ignitor dosent glow, repeat this process and use a multimeter to ensure power is getting to the ignitor)ignitor part number is 471602
after 30 more seconds you should hear a little "pop" coming from the gas valve.
This is the gas valve opening to try to ignite. If the ignitor is working and the burner ignites, and then goes off with an E05 code, then this would indicate a bad flame sensor (part number 471603)
in rare cases, this code can be tripped by a lose wire on either of these parts.
The parts diagram in the manual on pages 33-34 will help to guide you where to look for these parts. It is always best to familiarize yourself with the heater before work is done.
Link for manual : http://www.pentairpool.com/pdfs/MiniMaxNTOM.pdf
If this post has helped please rate the post positively
if you need more assistance e-mail me @ adamh@newconceptchem.com
Nov 02, 2010 | Pentair Minimax NT Heater
Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737 Logo
3,559 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
