Question about Engel Freezer 22 Qt. Fridge/Freezer
Im loking for a digram on a 12 fridge /freezer can u post it to me
  • stevan4 Apr 20, 2009
    I want to build my own freezer so what a need is all the things I need to do sow If u can help me I will rely like it
    Thanks stevan
  • Shane Seaman May 11, 2010
    I am a techie and work on a lot of Engel fridges, I have never been able to find any wiring diagrams nor any technical backup. However having said that, perhaps I can help. What is it exactly that you are wanting to do? Or rather what exactly is the problem with the fridge, can you describe some symptoms and also clarify what voltage you are using it on?
  • 400 Answers
Engel do not sell individual refrigeration components. Unfortunately. But you can buy from them a complete evaporator, compressor and condensor pre-assembled. You just need to make up a box. The electronic control box is also available as well as the thermostat. I am not sure who you can contact in the USA but I am sure if you go to www.engelaustralia.com you should be able to track down someone in the US who can supply those parts. Alternatively you can make up one using a Danfoss BD35 compressor with a dual control, which can run on 12vdc, 24vdc and 220vac. You then just need a wide range thermostat -30/+30c and you are away.
Posted on Apr 20, 2009
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
My Kelvinator N245C fridge freezer is ok but fridge not cooling when i open the freezer door , the cold air through to fridge air outlet ok but when the freezer door shut and than no air to the fridge the...
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
Nov 01, 2011 | Kelvinator 12 cu. ft. / 340 liter Chest...
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
We've got a GE American Fridge Freezer. 12 years
time to get a new freezer. check the floor under the freezer for coolant leakage, if none the compressor is ready to deep 6...
Nov 07, 2009 | General Electric Chest Freezer FCM5SU
What is normal temperature for fridge what is normal temp for freeer
for fridge it is 12 degree celcious and for freezer it is 0 degree
Sep 11, 2009 | Freezers
Fridge not getting cold
unplug unit to "reset." pull unit out from wall and blow the coils out on the back of refrigerator. if that does not work- call service man to come check freon level.
Aug 09, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
SMELLY FRIDGE
I would move the fridge and check what is under it.
Dec 07, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge freezer upright
Replaced the thermostat
Jun 22, 2008 | Freezers
Engel Freezer 22 Qt. Fridge/Freezer Logo
316 people viewed this question
Top Engel Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
John Tripp
John Tripp
Are you an Engel Freezer Expert? Answer questions, earn points and help others
