hi dear
SAP4.7 Installation On Server 2003
SAP 4.7 INSTALLATION GUIDE1. CREATE C PARTITION 6GB AND D PARTITION 70GB.
INSTALL O.S SERVER. SET SYSTEM YEAR TO 2010 OR
2. CREATE LOOPBACK ADAPTER.
START→ SETTINGS→ CONTROL PANEL ADD OR
REMOVE HARDWARE→ NEXT→ NEXT→
SELECT ADD ANEW DEVICE NEXT
SELECT WANT TO SELECT THE HARDWARESELECT NETWORK ADAPTER SELECT MICROSOFT NEXT NEXT FINISH.
3. CREATE IP ADDRESS MY NETWORK PLACES LOCAL AREA CONNECTION RIGHT CLICK PROPERTIES SELECT INTERNET PROTOCOL (TCP/IP)ADDRESS CLICK ON PROPERTIES AND IN IP ADDRESS 200.200.200. 20 AND OK OK
4. VIRTUAL MEMORY MYCOMPUTER RIGHT CLICK PROPERTIES ADVANCED TAB CHANGE SELECT D DRIVE INITIAL SIZE 2000 MAXIMUM SIZE 2000 CLICK SETOK OK OK
5. COPY ALL THREE DVD IN D DRIVE. SEE THAT D DRIVEMUST HAVE ATLEAST 54-55 GB FREE SPACE.
6. JAVA 1.4 INSTALL [FROM DVD 1] JAVA 1.4 DOUBLE CLICK NEXT I ACCEPT NEXT NEXT NEXT FINISH. JAVA PATH MY COMPUTER RIGHT CLICK PROLPERTIES ADVANCED ENVIORNMENT VARIABLE [SYSTEMVARIABLES ] SELECT NEW
VARIABLE NAME JAVA_HOME VARIABLE VALUE ----------- START RUN BROWSE SELECT DRIVE PROGRAM FILES ANDPASTE IN VARIABLE VALUE BOX {Enter Path of JAVA) OK OK OK .
7. ORACLE 8I INSTALL [FROM DVD 3 ] ORACLE 4 NT I386 SETUP ORACLE 8I NEXT NEXT NEXTGLOBAL DATABASE NAME ORA NEXT INSTALL FINISH [ OREXIT]
8. INSTALLATION . [FROM DVD 3] KER NT I386 NTPATCH R3 DLLN DOUBLE CLICK ON THIS PRESS OK. KER SAPINST NT SETUP.
SAP 4.7 INSTALLATION SELECT THIS AND PRESS NEXT NEXT
SYSTEM ID ----- GIVE ANY DIGIT ALPHABETS [EX: SAI] NEXT
SELECT CENTRAL INTANCE NEXT NEXT
SELECT LOCAL INSTALLATION NEXT NEXT
SELECT C DRIVE NEXT -------
GIVE PASSWORD AS 123 IT WILL ASK TWO TIMES THATPASSWORD NEXT
9. AFTER INSTALLATION OF ABOVE STEP
GO TO : \ RIGHT CLICK ON USR SHARING & SECURITY SHARETHE FOLDER IN SECURITY TAB TICK ALL ALLOW.
GO TO PROGRAMS SAP INST ORACLE KERNEL CLICK ONPREPARE NEW INSTALLATION.
THEN AGAIN GO TO PROGRAMS SAP INST ORACLE KERNEL CLICK ON SAPINST SERVE WITH GUI.
AGAIN FOLLOWS THE STEP IN STEP 8 WITH THE FOLLOWINGCHANGES.
SELECT DATABASE INSTANCE INSTEAD OF CENTRAL INSTANCE
SELECT D DRIVE D DRIVE} FOR BOTH OPTIONS NEXT NEXT
IN PACKAGE LOCATION GIVE THE ADDRESS OF DB1-----ETC.
DB1 EXPORT 1 LABEL.ASC
DB2 EXPORT 2 LABEL.ASC
DB3 EXPORT 3 LABEL.ASC
EXPORT 4 LABEL.ASC
EXPORT 5 LABEL.ASC
EXPORT 6 LABEL.ASC
EXPORT 7 LABEL.ASC NEXT NEXT.
SELECT THE OPTION NO MNLS REQUIRED
AFTER THIS IT WILL TAKE 15 HRS FOR INSTALLATION. ITWILL SHOW SUCCESSFULLY INSTALLED.
10. GO TO GUI GUI WINDOWS WIN32 SETUP. ã NEXT NEXT SELECT ALL NEXT INSTALL.
11. AFTER THAT CLICK ON SAP LOGON IN THAT CLICK ONNEW ITEMS DESCRIPTION ANY NAME APPLICATION SERVER TO KNOW THISOPEN SAP MANAGEMENT CONSOLE, IN THAT CHECK THE NAME ABOVEPROCESS LIST AND FILL WITH THAT NAME.
SYSTEM NUMBER 0012. CLICK ON LOGON USER ID DDIC PASSWORD 19920706.
THEN GO TO SU01 TRANSACTION.
GIVE THE USER SAPUSER (this is the user name to logon to sap) THEN PRESS F8.
GIVE ANY NAME IN LAST NAME INITIAL PASSWORD REPEAT PASSWORD.
THEN CLICK THE TAB PROFILES GIVE SAP _ALL SAP_ NEW &
THEN PRESS ENTER & SEE IT WILL ASK THE PASSWORD ,
THIS IS THE PASSWORD TOLOGON TO SAP, GIVE ANY PASSWORD AND LOG OFF.
13. AGAIN LOGIN TO SAP NEW ID & PASSWORD AND THEN GOTO SE38 AND CREATE A PROGRAM STARTING WITH LETTER IT WILL ASK FORACCESS KEY.
IN THAT TYPE 366 87 66 322126 127 8 694.
Thank you Imrna Pls rank me as possible have nice day
Please help me a hardware problem. What components must contain a print server for 60 devices. He...
(More)
Please help me a hardware problem. What components must contain a print server for 60 devices. He will be installed on a Windows Server 2003 Thanks!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
