Pc has power but nothing shows on screen. motherboard doesnt beep once like it used to when turned on but green light is on indicating its ok.
Athlon 3700+ asus a8n-sli pc has power but nothing shows on screen. motherboard doesnt beep once like it used to when turned on but green light is on indicating its ok.
  • indiej Apr 20, 2009
    Thank you sir but i already have done that! i removed all memories and still no beeping !! right now the only thing connected to the mobo is the graphics cardwhich i recently installed. tried the previous grafix card and still the same problem, i think its a problem of the motherboard,,:(
    Genius:
  • 1,011 Answers
Dear,
Remove the ram and check, is the motherboard beeps or not..
it should beep as long beeps....and should continue beeping after serveral times until u switch off it...
then reconnect the ram after swiching off power...
remove the data cables of hdd and cd/dvd and then try to switch it on...
if it works fine then reconnect it properly...
Fault can be in Ram or data cables perhaps...
regards,
hope it will fix the issue so dont forget to rate it...
Posted on Apr 20, 2009
Monitor screen is black but computer seems to work
That is not enough info, please provide more info so people can understand the issue better. For example, describe what you do and see step by step. When you turn on the machine, after a few seconds it powers on, it should run Power-On-Self-Test (POST) which will end with a beep telling you everything was OK. If you do not hear any beep, the problem is likely to be inside the case, bad video card, motherboard, CPU, etc. Typically bad RAM or Video card will cause a series of quick or long beeps (different for each motherboard) to indicate where the problem is. Bad CPU generally do not generate a beep code and most motherboards also do not give out a beep for motherboard issues, naturally.
If you hear that beep but see absolutely nothing on the screen from the moment you turn it on, then check to see if the status indicator light (assuming it has one) changes color or not:
A) If the light on the monitor changes from red/amber to blue/green but you see nothing on the screen then either the video resolution and/or refresh rate is unsupported, video drivers are faulty or monitor itself is bad.
B) If the light goes back to red/amber or stays that way from get-go, then there is no connection, monitor cable is loose at either end or bad/supported.
C) One other possibility would be the input selection on the monitor which is set to "Auto" by default but if it was manually changed to DVI for example and you are now using a HDMI cable, monitor would not automatically change this setting thus not receiving the signal from the video card. You can check this using the menu buttons on the monitor itself.
This is a generic troubleshooting ideas I just shared, more details you can provide, the better people will be able to assist you.
Nov 21, 2013 | Dell Dimension XPS 400 PC Desktop
My desktop turns on but my monitor doesnt come on its plugged in right but my desktop just shows a light that its on
use other monitor..if it would not work listen for beep codes from your cpu.continuous three beeps meaning change your memory cards or check your memory cards..see if your monitor has light
Sep 01, 2012 | Gateway GT5220 PC Desktop
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
Green light is not on in front of CPU. Monitor shows nothing!
ok memeory problem
try another chip and see..
Nov 14, 2009 | Intel Motherboard
No Display
hi....good day...>try to replace the ATX power supply...< thanks and good luck...^_^
May 29, 2009 | ASUS M2A-VM (0610839149438) Motherboard
My ps3 doesnt work
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Mar 19, 2009 | Sony Playstation 3 (PS3) Console
PC doens't boot up HELP!
There are a few things you can try, the trouble shooting doesnt necessarily have to follow in this order. Best thing I can suggest is try re-seating the processor, and if that is the only stick of RAM you are using see if you can find another to test with. If it still doesnt work after either of those, you might have to try a different processor. Granted, this is if you have those parts on hand. If you still are unable to even get a POST beep, then I would also try snatching the CMOS battery, unpluging it and then hitting the powerbutton reset the CMOS to default settings. If it still doesnt work after you get back then there, then I would snatch every removable piece of hardware from the board down to just the processor/heatsink/fan, memory, and PSU. If you get a POST beep after that, then try adding one piece of hardware at a time until you find the problem piece. If it still doesnt work then there is a pretty good chance that the board is dead.
Jan 10, 2009 | Computers & Internet
Motherboard message LED message is --
Your motherboard has died .
No beep code explains it all .
LED lights and even fans spins only tells me that your getting power to the motherboard , but No beep code is crucial .
Every motherboard will beep once when your first turn on and beep once again before the Opertional System boots up .
Sorry again for your loss ...
Aug 07, 2008 | Evga nForce 680i SLI (122CKNF68)...
BEEPS
just reseat the memory modules it will fix the issue
Jun 07, 2008 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
