Question about RCA DIRECTV Satellite Remote Control
Now our tv only works when the vcr is on
How can we reprogram the remote to work without the vcr being on?
We have directtv.
    President:
  • 814 Answers
You will have to disconnect all the components from each other and the A/C power source for a few hours. This will allow the microprocessors to discharge their power and reset to factory settings. After letting all the components discharge their power, you can plug them all in to the power source and use the owners manuals to program the set-up to your viewing preferences. You must make sure to disconnect all components from each other and disconnect from the A/C power sources. I hope this information helps you with your problem of resetting you components. Thank you for using FixYa and have a nice day!
Posted on Jun 20, 2009
I have DirectTV and a DirectTV remote RC64. I can
Here are all the codes I have
10171 10096 10187 10020 10381 10024 10030 11314 10186
here is how to set up without a code:
mode switch set to TV
PRESS & HOLD Mute and Select buttons at the same time UNTIL light blinks twice
enter 9911
keep pressing channel up until the channel changes on the tv
Maker sure to test the VOL button, if volume works
PUSH select key to set the code
THESE PROCEDURE CAN BE USED WHENEVER A REMOTE KEY IS NOT AVAILABLE.
CHANGE THE LAST NUMBER, 1 TO
2 for AUX1 (VCR and DVD)
3 for AUX2 (Audio Devices)
Mar 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
Why can't I find the codes for DirectTV remote?
The DirectTV remote should have the option to
scan for the code check the instructions for
the automatic scan method most likely you
turn on the tv, dvd/vcr keep pressing button
until channel changes or set turns off which
ever button you use if you dont have the
instructions try this address
http://www.satex.com/directv/remote_codes.html
Nov 22, 2007 | Polaroid FLM-3232 Television
Tip
DirectTV RC65 Code Search
TIVO DirectTV RC65 Remote Control Programming by Code Search
Here are the steps to program your TIVO DirectTV RC65 remote control using Code Search:
  1. Turn on the TV or component.
  2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
  3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
  4. Enter 9-9-1 followed by one of the following four digits: 0 for Sat box, 1 for TV, 2 for VCR/DVD/PVR, 3 for Stereo.
  5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
  6. Point the remote at the TV or component and press CHAN UP. Repeatedly press CHAN UP until the TV or component turns off or performs the action you selected in step 5.
  7. Use the CHAN DOWN key to step back a code.
  8. When the TV or component turns off turns off or performs the action you selected in step 5, stop pressing the CHAN UP key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available.
If you know the 5-digit code you want to use, follow these steps.
To download and electronic copy of the DirectTV RC 65 manual, click here.
I hope that helps.
on Apr 02, 2010 | Tivo DirectTV Remote Remote Control
Reprogram remote
Here are the DIRECTTV codes for Sansui TV's.
10463, 11409, 11904, 11911, 11929, 11935 / 10236, 10179,
11463, 10178, 10765, 10767, 11684 /
011, 076, 096, 0091, 0099, 0179, 0236, 0463.
Call your Direct TV provider for instructions for your remote or go to Direct TV's website.
Nov 04, 2008 | Sansui D 27" TV275 TV
My phillips universal remote code book is missing and i need to reprogram it work my symphonic tv flat screen
I own a One-for-All universal remote, and my booklet says the setup code for a Symphonic TV (without a built-in DVD or VCR) is either 0171 or 0180. I can not guarantee these numbers will work with your remote, but it is worth a try.
Jul 05, 2008 | Televison & Video
Remote problem Hisense
I GOT A NEW HD WIDESCREEM POLAROID. DIRECTTV CONTROL PUTS ON POWER ON TV,CHANGES CHANNELS BUT DOES NOT CONTROL VOLUME NOR CONTROL DVD ANDVCR PLEASE HELP GODWIN
Jan 08, 2008 | One For All URC-4021 Remote Control
Tivo DirectTV remote problem
I have a Tivo black peanut remote. Can this remote be reprogrammed to power a different receiver?
Dec 07, 2007 | Tivo DirectTV Remote Remote Control
Tv vcr combo cannot program tv
Try pushing the volume buttons in the middle so that you are mashing both the up and down button, your menu should appear. then you can use the channel buttons for moving up and down.
Dec 02, 2007 | Emerson EWC1902 19 in. TV/VCR Combo
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Remote control
If its the original remote for the VCR then NO there is no reprogramming for that device as its built in. You may need a new remote and its available at http://www.remotes.com
Sep 11, 2006 | Hitachi VTM291A VCR
RCA DIRECTV Satellite Remote Control Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
