Question about Kenmore Washing Machines
The water in my stacked washer is coming out VERY VERY slow. It is also making a humming noise at the same time. What could this be??
    Genius:
  • 1,122 Answers
Does it do it on hot,cold warm?,do a test,put it on hot only see what its does,put it on cold only see what it does,if one side of the water valve works ok and the other does not you need to replace the water inlet valve as it is not opening all the way,thats the sound you hear-mike
Posted on Apr 20, 2009
Washer wont drain
Hello shirley_dods - Is the washer making a humming noise? If so, either the drain hose or pump is clogged and needs cleaning. Try setting the cycle to spin cycle only. Will water pump out? If it does not, then the washer could possibly be experiencing a communication error with the control board, faulty pump, timer or door lock assembly. At this point, I recommend connecting with a professional to accurately pinpoint any potentially more serious issues.
Mar 04, 2013 | Frigidaire FEX831CS Top Load Stacked...
Washer does not go into spin cycle
Hello Michael Callegri - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately.
Dec 16, 2012 | Frigidaire FEX831CS Top Load Stacked...
My washer does everything but final spin and drain
Hello Mathew Smith - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Dec 09, 2012 | Frigidaire FEX831CS Top Load Stacked...
Pant shuck under drum blocking water outlit to pump , how do I get them out
Hello - Is the washer drain pump now experiencing a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, then it could have possibly caused an issue with either the pump or timer. From this point, honestly I would suggest contacting a professional to move forward accurately since it is such a complex unit.
Oct 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
How do I fix the washer if it makes a humming noise when I start it but no water comes out and fills up?
Make sure that the water valves are turned on and that the hoses are not kinked.
Is the symptom the same for all temperature settings?
Feb 03, 2011 | Kenmore 94702 Front Load Stacked Washer /...
Slow flow of water in washer
CHECK WHERE THE WATER LINES HOOK UP TO THE WASHER NORMALLY THERE IS A SCREEN INSIDE THE WATER INLET PORTS
Apr 28, 2009 | LG WM2233H Front Load Stacked Washer /...
Started washing machine; suddenly stopped drawing water
If you are certain there is water up to the inlet valve, and you can hear it humming, then there are 3 possible reasons.
  • The valve is not opening because it is stuck.Replace valve.
  • Check inlet of valve for a possible clogged filter, remove and clean.
  • Insuficient water pressure to open valve.
  • Plz rate my solution.
  • Thanks.
Jan 13, 2009 | Maytag LSE7806A Top Load Stacked...
Rinse cycle problems
ckd cold water inlet may be full of sand ..most washers have a cold only rinse and will not advance to rinse unless fills with water..if good water flow to cold water inlet but still won't let water in suspect inlet valve
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
20 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
