Question about Whirlpool SF367 Gas Kitchen Range
GAS RANGE / SF368LEPT
Hello folks i have a whirlpool gas range about a year and a half old. the oven or broil will not lite , but the stove top burners will lite. there is just one igniter board for all ignitions. i believe i think it is the probe that is the problem. there are no broken wires or loose connections the stove looks brand new. if im correct when you push the bake cycle and if the probe is calling for heat it should send a ignition and gas until satisfied ( the same for the broiler). as i said there is only one ignition board and the only thing common is the probe.
    Scholar:
  • 146 Answers
Your probably right. The oven sensor, or what you call a probe, when open will not light the oven. Take it out and check for 1 to 1.5K ohms. at room temp. if you don't have that replace the sensor.
Posted on Dec 21, 2007
SOURCE:
My whirlpool SF265LXTS oven turns on properly, but the oven itself isn't getting hot. The gas stove top and broiler both work fine.
It sounds like you might have a clogged burner plate or manifold. You should call a certified gas repair service. This could be very dangerous, even deadly.
Dec 15, 2013 | Whirlpool SF265LXTS Kitchen Range
Oven won't heat, display out, gas burners on stove
Hello, you will probably need to pull it out and put it on something. Make sure the breaker is off to it before you test it. There is a thermostat in the very back that could be bad,check for continuity on that. Also check for continuity on the bake and broil element terminals itself,even though you have checked it to ground. If those check good,then the problems is in the control board.
Thanks
May 31, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I have a Whirlpool GS773LXSS gas range. You press bake, it clicks once and doesn't heat up at all. Press Broil, clicks twice and doesn't heat up.
Is the gas turned on to the stove? Is the pilot light lit?
Any special circumstances surrounding this incident? like this stove is new or old. Or you are new to gas stoves etc.
Apr 09, 2010 | Tecnik TKC195/3 Electric Single Oven
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Oven will not come on
whirpool gold gas stove tops not lite up
Aug 24, 2009 | Whirlpool Gold GW399LXU Gas Range
F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
May 11, 2009 | Whirlpool RF315 Dual Fuel (Electric and...
Gas stove with electric starter
regardless of electrical supply to home you can always match light you stovetop incases of power failure, your bake and broil would be compromised by lack of electricity.
Oct 23, 2008 | Ovens
Gas range
I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
Can you help ? Thanks, Tom
Apr 07, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Oven not working after controller beeping
if ihe oven is not working. ck ihe igeniter in side ihe oven it trun red hot when you trun the oven on
Dec 31, 2007 | GE JGBP33 Gas Kitchen Range
Whirlpool SF367 Gas Kitchen Range Logo
392 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
