Question about LG 52SX4D 52" HDTV
No video sometimes
I have audio all the time but when using Antenna, direct tv, or vcr I get no video. but if I use my dvd thats connected by componenet video all is good, and when I watch brodcast HDTV all is good. other tv's work fine. the anteena is direct to the tv, the vcr and direct tv are connected throught the composit video. so the only thing i can watch is hi-def brodcast or dvd.
Hey there i seem to have the same problem here. I don't know what is the problem last time i had this problem i called an tech. and he replaced an ballis or something it was board that regulates the volts supplied to the bulb. It fixed the problem but soon after that i had to replace the bulb the old one blew out...since i replaced it...its acting the same way again it turns sometime and it doesn't sometime lately it hasn't been turning on it cycles and can't seem to turn the bulb on or something it flashes the lamp indicator light...i am having a tech. look at it again tommorow...hope we can solve the problem with costing me a fortune.
Posted on Jan 07, 2008
    Problem Solver:
  • 6 Answers
I have had this problem several times i think this is a manufactures default. i am in the proccess of contacting the manufacture email me we can talk [email protected] please let anyone else who is having this problem contact me as well.
Posted on Oct 18, 2007
SOURCE:
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
Sep 15, 2013 | Disney 13" TV
Connecting JVC HR-XVC27U VCR/DVD Combo to DIRECT TV
Here is a link to a line diagram to connect most tv/dvd/vcr/direct tv.
Apr 22, 2008 | JVC HR-XVC27U DVD Player/VCR
I have a problem conecting my sharp 25h-M60 with my DVD plyer.I have found solution on Fixya. They said I have to use VCR. My question is: What does VCR mean?
If your TV does not have AV inputs (RCA jacks for video and audio), you can't plug the DVD player directly in to the set. One solution is to connect the DVD player to a video cassette recorder (VCR) using the "line in" jacks on the VCR, then using the channel 3 or 4 output from the VCR to the TV. This solution may not work with discs that have copy protection, though, and will give you an unwatchable picture.
For sets with no AV input, you need an RF converter. This is a device that takes the video and audio signals from a DVD player or other device and makes a channel 3 or 4 TV signal to the TV's antenna connector. Converters are available at most retailers where you can buy televisions, as well as online.
Jan 01, 2011 | Sharp 25H-M60 TV
Does the RCA model #F19207BC connect to a dvd/vcr player?
Nope. No external jacks for video and audio. You can use the antenna connection with the dvd /vcr player by connecting the antenna out on the player with a suitable length of coaxial cable with F connectors on both ends. Then you would locate the channel 3/4 switch on the player and choose either one. On the TV you would put the same channel on the TV tuner that matches the player channel and you will see the picture.
Aug 04, 2017 | RCA F19207BC TV
HOOKUP A MAGNAVOX DVD/VCR PLAYER TO TV AND DISHNET WORK CA
may be your tv systems don't have an accessory for audio video input. but you can hookup that by using an RF modulator adapter, this is a converter from audio / video to RF signal and connected directly to your antenna connection. you can purchase that RF modulator adapter to an electronics store.
Apr 18, 2010 | Sylvania SRT2319 TV
Cannot connect zenith vcr to zenith tv thru cable box
Hello mcgillicu390,
From your VCR you should have an (RF OUT) and an (RF IN) Connector (these also might be marked as ANT IN and ANT OUT, or CABLE IN and CABLE OUT).
The same goes for your TV (RF IN), (ANT IN) or (CABLE IN).
Now, take your Coaxial Cable (Cable with screw on or Push on connector with a wire in the center of it) and connect it to the TV (RF IN), take the other end of the same cable and connect it to the VCR (RF OUT).
Then connect your cable TV set top box or antenna to the (RF IN) of the VCR.
If you are using a cable box set your VCR and TV to Channel 3 or 4 (depending on your area)
If you are just using the VCR and an antenna set your TV to channel 3 or (depending on your area).
That should do it for coaxial connectivity.
If you are using the composite video and Audio cables to connect to your TV here are the directions for that.
Looking at the back of your TV you will see Three RCA type connectors colored as Yellow, White, and Red. Yellow is Video, White is your Left Audio, and Red is your Right Audio. They should be marked as (Video IN), (R Audio IN), and (L Audio IN). *note these markings may not be exactly like what is written, however the indicators should be close to what you are seeing.
Now look at your VCR, you may see a lot of RCA Connectors (up to 6 of these connectors) don't worry, you are only looking for the ones that say (Video OUT) (R Audio OUT), and (L Audio OUT).
Once you find the connectors on both pieces of equipment, take the Yellow, Red, and White tipped cables and plug the in their respective jacks Yellow tipped cable connects VCR (Video OUT) to TV(Video IN). Red tipped cable connects VCR (R Audio OUT) to TV (R Audio IN), and finally White tipped cable connects VCR (L Audio OUT) to TV (L Audio IN),
Once the cables are connected you will be able to use the composite selection on your remote to view the images from your VCR, the VCR in this case will be acting as the tuner for your TV with out you having to set the TV to channel 3 or 4, you will just have to use the AUX or whatever setting on you remote that allows the composite video to display.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 27, 2009 | Zenith B27A11Z 27" TV
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
Hook up vcr
yes, you need to use an Audio/Video cable (red, white, yellow) to hook to the TV. I've never seen a VCR that doesn't have coax connectors for the antenna input and TV ouput, but maybe the new ones are starting to leave that out. Normally, you run the antenna or cable coax into the VCR's input, then run another coax from the VCR output to the TV's input (or use an A/V cable)
Dec 20, 2007 | Sharp VC-A420U VHS VCR
Connecting VCR/DVD combo
Confusing! TV with NO yellow,red white input ? Buy an RF
adapter Radio Shack about 30.00.....TV has input ? = yellow
video,audio R,L from Insignia source dvd/vcr out ( audio R,L,
video {yellow} ) You don't need to switch cables.As to record
feature,consult owners manual..................................T
Nov 21, 2007 | Televison & Video
Open Questions:
See all LG 52SX4D 52" HDTV Questions
LG 52SX4D 52" HDTV Logo
177 people viewed this question
Ekse
