Question about Toshiba Satellite M35X-S311 Notebook
Instantshare keeps popping up on my computer as soon as I turn it on & I can't make it go away or turn the computer off unless I pull the battery. It started when I down loaded advanced optimizer from the internet .
  • john_howard Apr 25, 2009
    I tried that solution & couldn't make it work ,witch help me on to another solution . I used part of that solution witch got me to where I could go & remove everything from the day I down loaded advance optimizer on my computer . The only thing is anything from that day & forward you lose so you need to copy or make sure you have away to put it back before you start . I forgot what it was called but I using a few of the steps from solution & you click on this one thing & a calender comes up you pick the date you started having problems & it removes like it never happen .
  • 221 Answers
All the start up item's are taken out of the registry, you can try doing a registry clean to see if it remove's this item during start up or, you can also disable program's at start up by going to the start tab at the bottom and clicking on it, then go to run, type msconfig in the run box, then click on ok, it will bring up a system configuration utility, there should be a tab that says start up, when you click on that tab it will bring up all the item's that run at pc start up, if it's not shutting down properly you may want to do a security scan, sometimes when a pc does not shut down right away it's because a program is still running in the background, that program need's to end it's process before windows can shut down. Try using (ctrl, alt, del) to bring up the task manager, check to see if there's any application's running.
Posted on Apr 20, 2009
My ascend keeps popping hte turn off option screen. Also it turns on as soon as i put battery in, without having to press turn on button. And i take out battery and connect to charger and turns on as well.
Probably there is sort circuit in your device or may be your battery is expired already. i suggest you look for the same type of battery to test and confirm it..
Dec 19, 2013 | Cell Phones
My washer keeps popping new circuit
You havent given details when the breaker pops. Is it right away, in wash cycle, spin cycle or drain? If it pops right away, there has to be a short circuit, but it fills water up then as soon as the motor starts n it pops, it could be motor. If blows during spin, definately motor drawing too much current. Then it could be the breaker that is weak/faulty. The breaker if not faulty it will pop if the current drawn by the motor exceeds it's rating or there is a short.
Aug 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
How do you remove the RAM?
turn off computer unplug power cord and remove battery. turn the laptop upside down locate the door/panel that either says "RAM" of haves a symbol resembling a RAM card. remove the panel exposing the RAM, there will be two metal holders keeping the RAM in the slot. pull them away from the RAM card and the card should pop upwards then just simply take it out of the slot (remember just touching a RAM card can cause damage from static electricity take proper pre-cautions and be careful not to touch the black modules/chips on the card)
Apr 01, 2011 | Toshiba Satellite A135-S4527 Notebook
Where is the cmos battery located in the computer??????????
#1
Turn off the laptop and remove the AC adapter. Remove the battery from its compartment on the bottom of the computer. Turn the laptop over and remove the screws holding the DVD drive in place and pull out the DVD drive.
#2
Remove the remaining screws on the bottom of the computer. These screws secure the wireless card cover, the memory card cover and the modem card cover. Then remove all of the plastic covers. Remove the wireless card by sliding it gently out.
#3
Remove the corner screws on the bottom of the laptop securing the bottom housing. Remove the housing by pulling it away from the laptop. Remove any remaining, exposed screws on the bottom of the computer.
#4
Turn the laptop over and remove the thin plastic strip that runs along the border of the keyboard with your fingernails. If your fingernails aren't long enough, a plastic card will work as well.
#5
Remove the two screws on either side of the keyboard securing it to the computer. Remove the keyboard.
#6
Remove all of the exposed screws where the keyboard used to sit. These screws secure the top housing to the computer. Remove the housing, exposing the motherboard.
#7
Locate the CMOS battery. It is a small battery about the size and shape of a coin and should be easily visible on the board. Depending on the model of Toshiba you are working on, the CMOS battery will either be secured with a clip or connected to the board by two small cables. Either way, they are easily removable.
#8
Disconnect the battery by pulling gently away from the cables or by popping the clip out. Your CMOS battery can now be removed
Oct 06, 2010 | Toshiba Satellite X205-SLI1 Notebook
My car keeps cutting off and the battery and alternator are fine
I would return to the installer of the remote starter and ask them to remove it. Then see if the problems go away and I'll bet they do.
Oct 17, 2009 | 1997 Nissan Maxima
Spyware InstantShare removal
only avast anti virus can fix this problem just try to install the avast
Nov 12, 2008 | Microsoft Windows XP Home Edition
u need a good anti spyware or u need to format your pc
have you got a camera which connects to your computer possibly an hp camera a friend had the same problem and it turned out to be some software he installed with his new camera
Nov 12, 2008 | Toshiba Satellite M35X-S311 Notebook
Warning: receiver channel changed - wireless keyboard and mouse
I contacted Gaeway Support. They quickly answered and suggested that I change the batteries in my wireless mouse and/or keyboard. I did. It was the mouse. As soon as the new batteries were in, the popup went away and stayed away.
Jan 07, 2007 | Gateway 2520915 Keyboard
Toshiba Satellite M35X-S311 Notebook Logo
79 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
